Results 1 to 6 of 6
Thread: What?
Ask your questions about using the forum. Find useful video tutorials in tutorial sub-forum Please post car-related questions in the appropriate car forum (e.g., Healey, Jaguar, MG...etc.)
  1. #1
    Yoda TOC's Avatar
    Join Date
    Jun 2008
    Location
    Floe Ice, Antarctica
    Posts
    6,409
    Thanks Thanks Given
    Thanks Thanks Received
    27
    Thanked in
    What?
    Forbidden
    You don't have permission to access /bcf/ on this server.
    WARNING: Repeated attempts to access this directory will result in your IP being blocked on this server.
    If you are trying to access www.Britishcarforum.com but are getting this error, try this: clear your browser cookies, then type in the domain name directly into your browser, like this: www.britishcarforum.com
    Still having trouble? Contact bcfadmin@britishcarforum.com for help
    Additionally, a 403 Forbidden error was encountered while trying to use an ErrorDocument to handle the request.
    __________________________________________________ ________________________________________
    On the TR forum, I can see everything just fine, until I click on the one link (so far)
    https://www.britishcarforum.com/bcf/showthread.php?117078-Up-date TRF-points-issues-resolved
    You're gonna block my IP address?
  2. #2
    Administrator
    Join Date
    Dec 2000
    Location
    Turn left at Albuquerque
    Posts
    24,418
    Blog Entries
    7
    Thanks Thanks Given
    62
    105
    Thanked in
    Re: What?
    Try now.
    “The smallest act of kindness is worth more than the grandest intention.” - Oscar Wilde
  3. #3
    Yoda TOC's Avatar
    Join Date
    Jun 2008
    Location
    Posts
    6,409
    Thanks Thanks Given
    27
    Thanked in
    Re: What?
    yeah...you must have been editing the post or something, but it was that way for some time.
    That's TWO I've somehow managed to come across when you were fiddling with posts.
    Strange.
  4. #4
    Administrator
    Join Date
    Dec 2000
    Location
    Posts
    24,418
    Blog Entries
    7
    Thanks Thanks Given
    62
    105
    Thanked in
    Re: What?
    Quote Originally Posted by TOC View Post
    Strange.
    I have a set up security rules (several hundred rules actually) that are intended to prevent a hacker from injecting malicious code into the forum database. When you clicked on that link, it put the title of that thread into your browser address bar. There is a word in that title that the security rules saw as data-base related and thus blocked you from sending that thread address to the server. I have modified things to allow that thread to be accessed. Let me know if you run into any similar issues.
  5. #5
    Yoda TOC's Avatar
    Join Date
    Jun 2008
    Location
    Posts
    6,409
    Thanks Thanks Given
    27
    Thanked in
    Re: What?
    and here I thought you did all this to keep us on our toes while you were awaiting the new grandkid to make it's appearance.
  6. #6
    Administrator
    Join Date
    Dec 2000
    Location
    Posts
    24,418
    Blog Entries
    7
    Thanks Thanks Given
    62
    105
    Thanked in
    Re: What?
    The issue was the use of the word "update" in the thread title. When you would try to go to that thread, one of the many security rules would see the word "update" in the thread title, which of course puts that word in your browser address bar. One of the security rules installed on the server to prevent hackers looks at the word "update" in your browser address bar, and assumes it could be a possible database injection attack ("update" happens to be an SQL database command used to modify a database). The security rules, not wanting to allow a possible database injection attack, prevents your browser from accessing the server with that word in the browser address bar (thus the "forbidden" error).
    So as not to have to disable that security rule, I have done a mass update of thread titles and replaced the word "Update" with "Up-date" in all threads with "update" in the title. That should prevent the security rule from being triggered. I'll make a separate post about this, but just FYI, here is a list of words to avoid using in thread titles:
    union|select|create|rename|truncate|load|alter|del ete|update|insert|desc
    Using any of these words in a thread title, will cause anyone clicking a link for that thread to trigger the security rule and be blocked from the site.
    If you must use, for example, "update" in a thread title, then hyphenate it, like this: up-date.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
