What is this broken part in my transmission/OD?
kozelding
My overdrive has started to lose pressure (again) when hot. I pulled off the cover to the accumulator, and out flowed a sea of metal shavings along with this....
My transmission was "rebuilt" < 10k miles ago, and I've always noticed a good amount of metal shavings (steel and brass) in the oil before now - but nothing quite this large.
Csarneson
That is the overdrive bronze thrust washer. Moss lists it as 866-560. It is pretty troubling that it's broken because I can't think of a mechanism that would do that. I think you're going to have to pull it apart again.
Csarneson
That washer isn't really a wear item. I suspect your overdrive was improperly shimmed at the last rebuild and you didn't have the proper clearances. It was probably too tight. You are almost certainly going to have to remove the overdrive from the tranny but accessing it shouldn't mean and complete stripdown of the overdrive. The question is whether there could be more damage from the too-tight clearances hidden inside. At a minimum I wouldn't take it back to that shop.
K
kozelding
Ah, thank you so much - I see it matches the Moss photo too.
I have to admit part of me was tempted to clear out the shavings from the ball valves and accumulator and hope for the best, but I see now that would be asking for serious trouble.... I have noticed an occasional "thrum" at low speeds (40-45 MPH) with the OD engaged, so there have been other clues that not everything is healthy.
Healey Nut
Its possible ???? That when they mated the OD to the transmission it was not done carefully enough and the thrust washer was broken due to misalignment during assembly and it was just a matter if time before it failed .
When you mate OD to transmission everything has to line up perfectly (yes even the stars) as well . You cant force anything or you will bend break twist or generally F something up .
D TR2/3/3A repairing broken hardboard seatback Triumph 8
Bayless How to repair broken vent window studs? Spridgets 1
M TR6 1973 TR6 - broken choke cable Triumph 6
P Broken Overdrive Switch in Gear Knob Austin Healey 14
AH67AH Broken Shock Mounts Austin Healey 23
T TR2/3/3A Seeking advice on how to repair TR3 steering wheel broken spoke. Triumph 8
tahoe healey Broken Spokes Austin Healey 8
H broken sway bar link - again Austin Healey 8
K TR4/4A Replacing a broken 4A turn signal switch indicator? Triumph 2
KVH General Tech Clutch Fork and Broken Pin Triumph 8
RJS TR4/4A Broken Cylinder Head Stud Triumph 10
T Philosophizing on keeping cars for more decades - prompted by a broken throttle cable Spridgets 3
B wire wheels and broken spokes Austin Healey 19
I TR6 Broken front suspension bracket Triumph 3
D TR4/4A broken trans fork pin Triumph 14
mcmillal TR4/4A Broken Vertical Link Triumph 17
D BJ 8 Side window broken - Help !! Austin Healey 9
K TR2/3/3A Broken exhaust manifold TR3b Triumph 13
K TR4/4A Performance Cam=Broken Rings??? Triumph 9
C TR6 Broken Throttle Shaft Triumph 4
TomChar TR6 '74 TR6 - Broken Top bow Triumph 1
B TR4/4A TR4A Head off for broken manifold stud - What else to do ? Triumph 13
J Healey 100 -- Broken rocker and bent push rods !!! Austin Healey 7
P BJ 8 broken hood frame screw Austin Healey 6
TomChar TR6 '74 Clutch & various broken bits Triumph 20
M Broken off dip stick plastic tube, stuck oil pan, and I think too much... Spridgets 10
J TR2/3/3A Broken pinion gear tooth, I am sad! Triumph 2
A Broken Axle Question? Spridgets 11
Gliderman8 Help with restoring broken aluminum logo badge Restoration & Tools 6
J Need some expertise, broken exhaust maniford Triumph 9
jharrison77 Broken Heater Control Tap [valve] Austin Healey 9
K Anyone experience a broken crosshaft pin.... Triumph 6
H broken sway bar link Austin Healey 13
K TR2/3/3A Crossshaft broken taper pin removal? TR3 Triumph 5
P broken oil cooler fitting MG 1
R TR2/3/3A TR-3A Rear Leaf Spring Broken Triumph 3
nevets Points failure - broken cam follower Austin Healey 3
W TR6 broken bleeder on rear brakes tr6 Triumph 12
Westfield_XI Three broken spiders later..... Spridgets 54
tahoe healey broken spoke Austin Healey 12
V Help: key broken off in ignition! Triumph 18
BugeyeNJ58 Gas Gauge Broken on '58 Bugeye.?? Spridgets 9
B High Torque Starter Broken mount Austin Healey 1
T TR4/4A Broken disc wheel stud on TR4A IRS hub. Triumph 3
S TR2/3/3A TR3 clutch pressure problem - not a broken spring! Triumph 3
middie Is this sender wire broken?? Spridgets 2
K BROKEN ROD BOLT has any body had one? Triumph 9
davester Help needed...broken exhaust manifold stud MG 15
jvandyke hood [bonnet] release broken cable Spridgets 34
M Broken Ball Joints Spridgets 14
