Fuel pump options
Csarneson
My BN4 sat in a field for 40 years and is slowly coming along. The engine will hopefully run again later this summer but I need a Negative Ground fuel pump. Originality is not necessary and cost probably isn’t a decider either. I’m doing lots of modern upgrades so solid state doesn’t bother me. What I want most is reliability. A pump that bolts into the original location would be helpful too. I will most likely add a second small flow through pump in series like Lin did as well.
Fuel pump options:
Hardi solid state- $129
https://www.bpnorthwest.com/austin-...ual-polarity-bn1-bn4-mg-tf-mga-mgb-to-64.html
SU solid state - $157
https://www.ahspares.co.uk/austin-h...ts/fuel-boot/petrol-pumpelectronic-earth.aspx
SU points - $134
https://www.ahspares.co.uk/austin-h.../petrol-pump-dual-polarity.aspx?&currency=usd
Rebuild my original? Is that even an option? It sat in a field for 40 years so i’m skeptical. If so can I do it myself or should it be sent off to someone?
What option would you choose?
SU pumps are easy to rebuild; disassemble yours and see how the internals look. The shop manual has instructions on setting the points. Moss has kits, so does this outfit (NFI):
https://www.sufuelpump.com
I've fought the battle with SU fuel pumps for over 3 decades. I was happy with Dave DuBois' rebuilds but he's gone and one of his failed on me recently. The replacement points sets I bought years ago were of inferior quality--Dave D. agreed--but Moss and others may be sourcing from SU Burlen now. Given you're doing a resto you have plenty to do, if I were you I'd buy the SU solid state and install it, and if I want to fiddle with SU fuel pumps I would do it when the rest of the resto is done and you can enjoy your car (you'll want to carry spare if you do a lot of out-of-town driving, backup pump or not).
Harold
Bronze
I've installed "Airtex E8016s" on 5 British cars over the past 10 years--also A "MR Gasket" fuel pressure regulater--negative ground--easy installation--
Warren
Have also used this,same as above, aftermarket fuel pump\Spectra E8016S\SP8016U(Autozone Lifetime) since 2005. No regulator. First one went bad. Autozone replaced and has been trouble free many years. I do carry a spare. Easily switched if necessary. Ticks away like SU.
WD 67 BJ8
Michael Oritt
As you've discovered your options are many including real SU's (both points-type and solid-state, single and double-headed), SU clones such as the Hardi pump, and many aftermarket units such as those made by FACET and others.
For my Healey I prefer a solid-state SU just because it's correct and it will also have that nice, intermittent clicking sound. Since I am a fan of redundancy I have a double-headed version installed with an on-off-on switch mounted inconspicuously behind my seat.
If you're not a slave to originality your choices are many. Lots of people like the cube-types sold under the FACET and other names but I have had some fail on me, plus I don't like their constant clicking noise. On my Weber-carb'd race cars I use Carter 2040's and have never been let down by one and they put out plenty of fuel at 2-4 psi.
Good luck on your choice.
Harold
Bronze
I should have mentioned--the pump body is isolated, so that it can be either negative or positive ground---"airtex" pump in my previous posting
Michael Oritt
Michael - Maybe the Facet pumps are getting a bum rap. IIRC you mentioned some kind of mounting issue where they both didn't work.
I had forgotten about that incident where a number of years ago I tried mounting two FACET pumps in parallel without any check valves and one of the pumps seemed to allow part of the other's output to flow back through it, resulting in partial fuel starvation when running on that pump. Rather than going with what seemed like an overly complicated installation I went to having one FACET in series with an SU with a selector switch, which worked just fine, the FACET able to push through the SU and visa versa. Perhaps operator error was involved.
As said in my earlier post I have since gone to a double-headed SU which I simply find philosophically preferable....
steveg
....which I simply find philosophically preferable....
It comes down to this - ultimately, the cars are performance art. :smile:
I mounted mine in series with an on1-off-on2 switch - works as advertised.
With both mounted on rubber isolation mounts, the ticking is only audible with the engine off. Have lately moved the fuse to the bottom slot on the Charlie Hart fuse box.
T Wedge TR8 fuel pump options Triumph 11
B TR4/4A AC Fuel Pump Priming Lever Stuck Triumph 14
Q TR2/3/3A 61 TR3A Fuel Pump Triumph 4
D Wanted Square body LCS fuel pump Austin Healey Classifieds 13
D Wanted Wanted square body fuel pump Jaguar Classifieds 0
D TR4/4A TR4a Fuel Pump Triumph 10
RJS TR4/4A Fuel Pump Gasket Triumph 8
D MGB Fuel Pump MG 2
Martinld123 Electric Fuel Pump Austin Healey 6
S TR2/3/3A Fuel Pump??? Triumph 14
D Fuel Pump Ticking but Not Pumping Austin Healey 8
A Spitfire Fuel Pump Triumph 5
A Spitfire Spitfire Fuel pump issues Triumph 5
K TR2/3/3A Fuel line routing from pump to carbs Triumph 7
A GT6 Fuel Pump Leaking at out port GT6 MK3 Triumph 0
wkilleffer MGB 1974 MGB SU fuel pump voltage issue MG 11
S fuel pump upgrade Spridgets 0
S Sprite Fuel Pump Upgrade Austin Healey 1
F TR4/4A New to forum - Rebuilt Fuel Pump and weeping float bowl Triumph 9
P XJ12 Fuel pump relay 85 Jaguar 4
petnatcar Fuel Pump Upgrade Austin Healey 2
R Electronic Conversion on an SU Fuel Pump? Restoration & Tools 2
T TR6 Fuel pump lines Triumph 2
1 TR2/3/3A TR3 Fuel Pump Thread Type? Triumph 4
R Electric fuel pump wiring Spridgets 4
T SU Fuel Pump Mounting Austin Healey 5
D TR2/3/3A More Fuel pump questions. Triumph 10
Donald1107 59 TR3A Fuel Pump Triumph 48
BobHaskell SU Fuel Pump Pressure Austin Healey 1
Cutrog1 Fuel Pump Ticking Austin Healey 13
MGTF1250Dave T-Series MG TF fuel line from tank to pump MG 3
S SU fuel pump servicing Austin Healey 4
71TR6 TR2/3/3A AC Fuel Pump Lever Triumph 10
E MGB 1965 mgb fuel pump removal MG 2
D For Sale Su fuel pump Other British Classifieds 5
D For Sale Su fuel pump Austin Healey Classifieds 5
G Inertia Cut-Off Switch - E-Fuel Pump to Ignition [Key] Switch Austin Healey 3
vette A Quiet SU Fuel Pump Austin Healey 2
A TR4/4A AC Fuel Pump stuff Triumph 11
AngliaGT Fuel Pump Problems Spridgets 2
B SU Fuel Pump Parts Austin Healey 8
B TR4/4A Mechanical fuel pump vs electric Triumph 16
P TR6 TR6 fuel pump question - glass bowl pump correct? Triumph 8
J TR4/4A Fuel pump saga Triumph 4
longbridgehealey Fuel pump racing, no gas Austin Healey 26
D General TR Fuel filter before the pump. Triumph 2
T 66 Austin Healey fuel pump replaced Austin Healey 30
C Well I Tried with a new SU fuel pump British Motor Corp 0
T TR2/3/3A Questions on fuel pump installation Triumph 7
sundown TR6 Fuel pump Triumph 10
