TR5/TR250 Steering Self Center
glemon
My TR250 has very weak to no return or self center for the steering. Nevertheless it tracks straight and things seem to be fine with the front suspension and steering other than that.
I have adjusted toe in and camber with fairly simple but accurate home made tools, but not sure how to measure caster. So couple of questions.
Is the vere weak self centering normal for 4A-6? I should mention I have wide (205/60) tires and 1/4" spacers on the front wheels.
Second, some forums have suggested there is not an easy way to adjust caster on these cars. Wouldnt swapping a lower a arm shim from front to back on the suspension mounts on both sides adjust caster?
Thanks in advance for any experience/input.
poolboy
It might be inadequate backlash between the pinion and the rack. When I was adjusting mine, one less .005" shim under the damper cap put enough of a bind between the two to keep the wheels from recentering after a turn..
sp53
I know little about a tr250 suspension other than general stuff, but I did put some wide tires on a tr3 once and did more damage than good, but again they do not have rack steering and suggest a very skinny tire.
glemon
glemon
It is the same as 4A and 6, so yeah, rack and piniond and different than TR2-4. But yeah, I think the wide wheels and tires make a difference. I generally like the feel of an old sports car on skinny tires better than wider, with a stock suspension the steering is easier and the car starts to slide earlier before you get all sorts of load and lean of the car beyond what the car feels comfortable with.
But my car is modified a bit and I need the extra grip to keep up with the stinkin Miatas at the Autocross.
tr6nitjulius For Sale SOLD 3/7/24: 4$ale Hi-ratio quick steering rack Triumph Classifieds 0
T TR6 Steering Wheel Lock Triumph 2
D Removing the steering wheel hub Spridgets 12
J MGB 1970 MGB Steering Lubrication MG 1
C Steering Arm Castle Nut Torque Austin Healey 5
PAUL161 T-Series TF Steering Rack MG 0
G Steering Disconnected Austin Healey 2
R TR2/3/3A Jammed Steering Box Triumph 10
R TR2/3/3A Steering Box Gaskets Triumph 4
K 1968 Midget Steering wheel Spridgets 1
olarson TR2/3/3A Steering Column Bracket Triumph 2
Guido36 Electric Power Steering Austin Healey 2
Rut MGB 62-67 upper MGB steering shaft MG 3
Editor_Reid Wrapped Steering Wheel Austin Healey 9
E TR6 Strange Steering Rack Cap Triumph 3
B TR4/4A Steering Wheel Hub Issues Triumph 0
K TR2/3/3A Who sells steering wheel control head "Allen head'' grub screws? Triumph 5
S TR6 Steering question you will not hear every day Triumph 1
T "Flashpower" Steering Wheels Austin Healey 3
EWD For Sale ā€˜74 TR6 original steering wheel Triumph Classifieds 0
S SOLD!! Mike Lempert 15" slotted Derrington Steering Wheel Austin Healey Classifieds 1
M Midget steering column Spridgets 3
kodpkd Leather Steering Wheel Cover Austin Healey 3
JAV For Sale non adjustable steering box Austin Healey Classifieds 3
S Steering Wheel Brand Austin Healey 5
71TR6 TR6 Replaced steering rack in my TR6- very twitchy now Triumph 15
B TR4/4A What is this Steering Wheel Center? Triumph 6
M MGA RHD twin cam steering pinion MG 0
W BN1 Steering Box Removal Austin Healey 11
B Steering Column Wiring/Sealing Austin Healey 1
M TR6 Redesigned Steering Shaft TR6 restomod Triumph 4
Martinld123 Steering Wheel Alignment [Lost centering on steering box 1956 Austin Healey, BN2] Austin Healey 14
C Wanted 1970 XKE power steering pump. Or substitute? Jaguar Classifieds 1
Celtic 77 MGB Steering wheel fitment MG 11
S TR2/3/3A Steering Triumph 4
S TR2/3/3A Steering wheel removal. Triumph 4
MikeAH100M BN2 Tight Steering Austin Healey 4
W BN1 Steering Box Austin Healey 3
Walter74 Steering Column Felt Bushing Austin Healey 3
Sopwith_Camel how do i know if my power steering pump is going Jaguar 4
LAW75 Derrington Steering Wheel Austin Healey 19
Martinld123 Steering Box Leak Austin Healey 27
waltesefalcon New steering wheel Other Cars 2
M T-Series TD/TF Steering Free Play Question MG 6
R TR2/3/3A Steering Wheel hitting my belly Triumph 22
bighealeysource T-Series My older Brooklands steering wheel is leaking ! MG 4
D Steering Column Adjustment Collet Austin Healey 8
W Steering Arm Colors Spridgets 1
BritBite Stiff steering effort Daimler SP-250 Other British Cars 11
Simmo TR2/3/3A Steering with Escort rack Triumph 5
