Results 1 to 18 of 18
Thread: What is correct wire harness outer wrap
  1. #1
    Jedi Warrior red57's Avatar
    Join Date
    Apr 2008
    Location
    Washington, USA
    Posts
    627
    Thanks Thanks Given
    11
    Thanks Thanks Received
    29
    Thanked in
    It seems like most of the new wiring harnesses available are cloth wrapped but the 1960 BT7 I'm working on has wire harnesses wrapped in black vinyl tape.
    I bought the car in 1987 and there was no evidence of prior restoration when I got it so I always assumed the wire harness was factory. I prefer a black vinyl wrapped harness because I can add new circuits like driving lights and wrap with vinyl tape and it all looks uniform - if I use the cloth wrapped harness, any added circuits will be obvious.
    Does anybody know how to identify which type of outer covering for which years/models of car?
    Thanks,
    Dave
  2. #2
    Great Pumpkin Keoke's Avatar
    Join Date
    Apr 2004
    Location
    LosAngeles Calif.
    Posts
    12,706
    Thanks Thanks Given
    13
    Thanked in
    Re: What is correct wire harness outer wrap
    HIave
    I have seen wire harnesses wrapped in cloth predominantly on original cars, additionally I have seen what I think are after market ones wrapped in blue vinyl
    I have not seen replacement harnesses wrapped in black vinyl
    Wrapping a harness in a non breathing outer cover will further reduce It's current carrying capability
    1966 Daimler V8 Saloon; Safely Fast, Built to Last & and; Smooth as Glass.
    1966 BJ8 [ 2 ] Lil Red & Miss bLU
    1985 XJ6 Saloon
    1948 & 70 Lincoln continentals
    1973 Volvo P1800ES
  3. #3
    Jedi Warrior BigGreen's Avatar
    Join Date
    Feb 2011
    Location
    Netherlands
    Posts
    573
    Thanks Thanks Given
    40
    4
    Thanked in
    Black Bicycle handlebar tape (cloth version) might be an option
    The least I can do is keep my CarClean.com
    Jaguar X type 2.5, 2003 Carnival Red Metallic
    Austin Healey HBJ8L/40871,MkIII ph2 April 1967 Original MGBeige, now BRGreen
  4. #4
    Yoda steveg's Avatar
    Join Date
    Sep 2007
    Location
    Altadena, CA
    Posts
    4,245
    Thanks Thanks Given
    173
    201
    Thanked in
    For wiring harness ID, see this and pick your model:
    http://www.britishwiring.com/Austin-Healey-s/4.htm
    Steve Gerow
    Altadena, CA, USA
    Maker of most complete Big Healey rear disc kit
    1959 BN6 / 1974 TR6
    http://www.pbase.com/stevegerow
  5. #5
    Join Date
    Apr 2008
    Location
    Washington, USA
    Posts
    627
    Thanks Thanks Given
    11
    29
    Thanked in
    Thanks for the replies. As I said, I bought the car in 1987 and it had a black vinyl wrapped harness that appeared to be factory.
    Keoke, I haven't heard about capacity restrictions from vinyl wrapping (all the American cars of the 50s thru 70s I've had were vinyl wrapped). I actually figured cloth was a poor choice for road dirt and holding water along the bottom of the car??
    BigGreen, The tape you are referring to, I think is what I used to know as friction tape and you are right, if I have a cloth wrapped harness then it would match better than typical PVC tape.
    Steve, Finding cloth covered wiring isn't the problem. I'm more interested in why I have a car with vinyl and most suppliers only offer the cloth. The only supplier I have found
    offering optional vinyl wrapped is SC Parts here:
    https://www.scparts.co.uk/sc_en/brit...ness-8690.html
    The real question is did the factory use vinyl wrapped harnesses and, if so, when & on what models - heritage cert says nothing about this and I can't fined anything in Clausager's Original Austin-Healey.
    I'm not going for concourse but have become curious.
    Thanks,
    Dave
  6. #6
    Join Date
    Apr 2004
    Location
    LosAngeles Calif.
    Posts
    12,706
    Thanks Thanks Given
    13
    Thanked in
    Well Dave Lucas Was doin the Engineering N he had some unique ideas---
    A more accurate reason is:
    wire's current handling capability is determined on a individual wire basis in free space , consequently when we bundle , wrap in PVC, enclose in sleeving we alter its operating environment which lowers it's current carrying capability.
    1985 XJ6 Saloon
    1973 Volvo P1800ES
  7. #7
    Luke Skywalker vette's Avatar
    Join Date
    May 2002
    Location
    Pa.
    Posts
    1,915
    Thanks Thanks Given
    1
    21
    Thanked in
    I'm not sure it this pic came thru I was trying to enlarge it so you could read it. It is from Anderson & Moment and shows the woven fabric on the BT7 just as Steve's source says. Anderson & Moment says nothing about any distinction between cars and only discribes that the harness had black woven fabric with a yellow fine line cross hatch on it. It also says the rear harness was all black woven with no cross hatch.
    About TV Shows-
    "...you really can't restore a car in 10 days. I don't want to watch a race where people have to restore it in a week. It's not going to drive, and those cars never work. In real life, it takes years to get it right. " Jay Leno.
  8. #8
    Join Date
    Apr 2008
    Location
    Washington, USA
    Posts
    627
    Thanks Thanks Given
    11
    29
    Thanked in
    Quote Originally Posted by vette View Post
    Thank you vette. I think you have solved the mystery for me. Apparently a PO must have rewired the car sometime prior to 1987 - a lot can happen in 27 years..... I know it had been re-painted at least 3 times so who knows what else it had gone through.
    Anyway, I will proceed with a cloth wrapped harness. I'm not going for concours, but I'm probably better off doing what the factory did in this case.
    Thanks to all for the help.
    Dave
  9. #9
    Join Date
    Sep 2007
    Location
    Altadena, CA
    Posts
    4,245
    Thanks Thanks Given
    173
    201
    Thanked in
    The next page has a chart with color trace descriptions.
    Steve Gerow
    Altadena, CA, USA
    1959 BN6 / 1974 TR6
  10. #10
    Join Date
    May 2002
    Location
    Pa.
    Posts
    1,915
    Thanks Thanks Given
    1
    21
    Thanked in
    Quote Originally Posted by steveg View Post
    Yes it does but I wasn't sure if the print would be large enough to read and it is mostly redundant to what was just said including the supplier that you linked to would surely show what was needed. Since I was trying to enlarge my other pic I didn't want to add to the size of my up load. But I think I got now.
    Bye the way if it can be seen, this pic shows the harness as it should b strapped to the off side inner structure brace.
    About TV Shows-
  11. #11
    Join Date
    Jan 2017
    Location
    Chesapeake, Va
    Posts
    14
    Thanks Thanks Given
    Thanked in
    All original 100's had fabric covered wiring except for the one from front to back along the chassis rail for the rear lights. It is vinyl wrapped for protection.
    Years ago the only replacement wiring was vinyl wrapped. I think that might be what you have.
  12. #12
    Join Date
    Jun 2008
    Location
    Floe Ice, Antarctica
    Posts
    6,418
    Thanks Thanks Given
    28
    Thanked in
    Quote Originally Posted by Keoke View Post
    Well.....Lucas Was doin the Engineering N he had some unique ideas---
    Yes, current handling capacity is determined by the wire size, shape, and composition. The real issue, however, is heat (something you generally don't have n non-Lucas 12V automotive systems). You bundle tightly, heat builds up, you start having issues with current handling.
    NOT because they are bundled.
    If so, all those 60-pair Key System phone lines would have burned up last century.
    And, that's mostly AC...and we're DC.....tightly bundled never made a difference. However, if you are worried about Lucas heat and the possibility of smoke escaping, probably a wiring tray would be best, where one wire going up in a mushroom cloud won't affect the rest.
  13. #13
    Join Date
    Feb 2007
    Location
    California USA
    Posts
    4,249
    Thanks Thanks Given
    5
    67
    Thanked in
    Quote Originally Posted by gladhill1937 View Post
    I used non-adhesive harness tape to wrap the wire for the rear lights (just couldn't leave the fabric exposed down there). Not sure if it's technically correct for a Healey, but it's period correct:
    https://www.amazon.com/Factory-Elect.../dp/B06Y2KDQRN
  14. #14
    Join Date
    Jan 2017
    Location
    Chesapeake, Va
    Posts
    14
    Thanks Thanks Given
    Thanked in
    Quote Originally Posted by Bob_Spidell View Post
    Non-adhesive tape is correct. The ends were wrapped back twice and tucked under itself.
  15. #15
    Join Date
    Apr 2004
    Location
    LosAngeles Calif.
    Posts
    12,706
    Thanks Thanks Given
    13
    Thanked in
    You bundle tightly, heat builds up, you start having issues with current handling.----YEP
    1985 XJ6 Saloon
    1973 Volvo P1800ES
  16. #16
    Obi Wan RAC68's Avatar
    Join Date
    May 2010
    Location
    NJ Shore
    Posts
    2,160
    Thanks Thanks Given
    29
    Thanked in
    Hi Dave,
    Although it is obvius that you can purchase a new harness, back in the '80s, I sent my original harnesses to have them rewrapped by (I believe) British Wiring with the original woven pattern (fabric). Since my harnesses were electrically in good condition but looked weathered, having the haranesses wrapped greatly improved its look and also retained the original bends making reinstallation much easier. Although I can't remember the price (and it would not be relevant if I could), I can tell you it was quite a bit less expensive then purchasing new harnesses.
    It's an alternative you may want to consider,
    Ray(64BJ8P1)
  17. #17
    Join Date
    Dec 2010
    Location
    West Bloomfield, Michigan
    Posts
    205
    Thanks Thanks Given
    4
    4
    Thanked in
    I replaced my BT7 wiring with a harness from Moss in 1980. It is wrapped with black vinyl tape.
    And it was not exactly correct, but I made it work. Still does.
    Good luck.
    Douglas
  18. #18
    Join Date
    Apr 2004
    Location
    So. Cal.
    Posts
    30
    Thanks Thanks Given
    Thanked in
    Concur with RAC68, back in 1977 when I restored my 1960 BT7 I had the original harness recovered with the original fabric with the yellow tracer. Was done by a company called YNZ Yesterday's parts, which at the time was out of his home garage about a mile from where I was living. He subsequently opened a real shop and is still quite busy and has a nice website. If I recall he charged me $35 at that time. You can see some of the harness in this picture. He knew exactly what it needed when I showed it to him. He told that 22 year old kid (me) to take it home clean it thoroughly by removing all the fabric, cleaning the wires and then putting electrical tape every six inches to keep it together in the correct shape.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
