Weirdness With My BJ7
60TR3A
Earlier this week, I noticed a long drip running down my driveway right after I had parked the car in the garage. The drip was heaviest as the car got close to the garage and was heading downhill and then tapered off to nothing just as the car entered the flat garage. A picture of that drip will be attached. It's still very visible despite many rains so it's not water or antifreeze but is petroleum-based. It's not brake/clutch fluid as that reservoir is full to the top. And it's not radiator runoff as it wouldn't still be a stain in the asphalt after being rained on many times in the past 5 or so days. This shows the drip in the driveway: https://www.youtube.com/watch?v=0DnMnBvhV84&feature=youtu.be
As you can see, it gets heavier as the car approaches the garage on the incline of the driveway and then peters out just as the car enters the garage.
I checked the oil and was down a quart so I added oil. I checked the radiator and added about a quart of antifreeze. I pulled the car out this morning and examined the garage floor. There was no evidence of any leaks on the left side of the car. There are plenty of puddles in the center and right side, though. Typical for the age of the car.
I drove it to the local mechanic and got it on the lift this AM. The engine and transmission and differential all had the usual wetness of slow leaks which were wiped off and the engine was idling for a good 20 minutes while on the lift. No leaks or drips occurred. However, we lowered the car to the ground and noticed white smoke coming out of the rear carburetor's air filter (from the back part of the filter nearest the firewall). You can view a short video of this smoking air filter here: https://www.youtube.com/watch?v=gcsOP_en12M&feature=youtu.be
We also noticed that the breather pipe was loose at the carburetor so we clamped it. Someone suggested a worn rocker shaft allowing too much oil into top, being sucked into the breather pipe by the carb.
Could the drip line in the driveway have been caused by fuel that the rear carburetor dumped due to a problem with the carburetor? Or oil being sucked into the carb and dripping onto the ground? All advice will be most appreciated. Thanks!
UPDATE: I found this online which probably explains what needs to be done. Please comment if you disagree and have a better diagnosis. "The Healey rocker shaft is located under the valve cover on top of the engine and can be a readily remedied source of trouble. The function of the rocker shaft is to hold the rockers in place on the valve train and to keep the valve timing intact. Oil is fed through the oil feed pipe into the shaft and along each rocker to oil the top of the engine and return. There is tremendous pressure here and what may occur is simply: Rockers turning on the shaft sometimes score it and the resulting gap allows oil in be forced out of the rockers and through the breather pipes to the rear carburetor. Therefore you are fouling your carburetors, mixing oil and gas in the engine, apparently using an excess of oil which your local repair shop will tell you is caused by everything but a rocker shaft."
You can rule out gas by smelling it--yeah, your neighbors will think you're nuts (they probably do anyway since you drive an old British sports car)--and, for the most part, modern fuel formulations don't leave a stain. White smoke usually indicates brake fluid burning, but apparently you're not burning any. The smoke out of the rear carb could be blue-sh; so, oil.
That 'drip line' is typical of coolant coming out of the overflow pipe.
60TR3A
60TR3A
I poured pure antifreeze next to the drip line a few days ago to see if it would last and be visible after rain but it's gone & the drip line is still very visible, so I doubt it's coolant.
BoyRacer
Assuming you have a very worn rocker shaft, it will spew oil out of the breather pipe into the rear carb air filter. However, all of that oil will not get sucked in and get burned up. Instead, it will load up your rear air fliter. I suspect that when you made the climb up your driveway, some of that trapped oil escaped.
Fuel will evaporate somewhat quickly. Oil will leave a stain that lasts months. I had a leak that looked just like that. It turned out to be a leak in the oil line to the lower part of the engine and easily replaced and cheap fix. I was originally frightened it was a crack in the block. The funny thing is that it the oil line "looked" perfect.
B Brake light weirdness Dodge Ram Other Cars 5
roscoe Intermittent weirdness Austin Healey 20
John Moore Rear Brake Cylinder Weirdness Spridgets 8
5 WTB: BJ7 Squab Austin Healey 13
5 BJ7 Boot Rust-Through Austin Healey 13
B For Sale Too many Healeys - BN2, BN4, BT6, BJ7 For Sale Austin Healey Classifieds 0
Walter74 BJ7 Throttle Linkage "Support Panel" Austin Healey 5
T BJ7 Trim Recession (Convertible Top) Austin Healey 2
ModifiedBJ7 BJ7 Windshield Surround Rubber Seal Austin Healey 2
R New Hood for BJ7 Austin Healey 3
chicken BJ7 Chrome Trim Austin Healey 15
JMACENGINESHOP BJ7 Engine Rebuilding Austin Healey 23
R BJ7 Rear Axle Maintenance Austin Healey 5
B Wanted Grill Top Cowl and Surround - BJ7 Austin Healey Classifieds 1
R Changing BJ7 Differential Ratio Austin Healey 10
X Trouble shooting trafficator - 1963 BJ7 Jaguar 9
T BJ7 Hard to find First Gear when G/Box is hot Austin Healey 3
B BJ7 Rear View Mirror Mounting Hardware Austin Healey 7
chicken BJ7 Door Fit Austin Healey 27
T Wanted BJ7 parts needed Austin Healey Classifieds 0
T Weight of BJ7 Transmission/Overdrive Austin Healey 10
D BJ7 Clutch Austin Healey 6
R BJ7 Back Seat-Rest Austin Healey 1
HealeyRick BJ7/8 Convertible Top Issues Austin Healey 5
HealeyRick BJ7 Side Window Alignment Austin Healey 31
B BJ7 Interior Finishing Details Austin Healey 2
chicken Healey BJ7 door (i think) Austin Healey Classifieds 0
chicken BJ7 Rear Number Plate Mounting Austin Healey 3
chicken BJ7 Door Seal Austin Healey 5
chicken BJ7 Rear Quarter Panels Austin Healey 6
B BJ7 Boot Trim Austin Healey 7
T Early BJ7 Vent Window Seal Austin Healey 2
D BJ7 Underdash Trim Austin Healey 9
G Steering Arm Installation Recommendations - BJ7 Austin Healey 2
D BJ7 Rear rail trim Austin Healey 0
D BJ7 Hood frame mounting plate Austin Healey 7
D Wanted BJ7/8 front grill top cowl Austin Healey Classifieds 4
BLong63AH BJ7 Hard Fuel Lines Austin Healey 20
T Spin-On Oil Filter Removal [BJ7] Austin Healey 12
T Installing Garmin GPS in a BJ7 Austin Healey 19
pbraun How much does a BJ7 or 8 transmission weigh? Austin Healey 3
P BJ7 Upholstery Austin Healey 1
B BJ7 back end rebuild Austin Healey 1
Marvin Gruber BJ7 door panels Austin Healey 4
Marvin Gruber BJ7 Top Installation Austin Healey 1
B Rear shroud connection to the floor pan on a BJ7 Austin Healey 21
P BJ7 HS6 Carb Baseline Setting Austin Healey 10
Marvin Gruber BJ7 tach cable location. Austin Healey 3
T Toyota 6 cylinder eng & trans in a BJ7 Austin Healey 0
