TR2/3/3A What's wrong at The Roadster Factory?
Status
Not open for further replies.
karls59tr
Bronze
In the middle of June I ordered a condensor and points from them. What I received was the blue wire condensor instead of the uprated yellow wire condensor.(I was told the that the blue wire one was the same as the yellow wire one?) In the box marked points was a voltage regulator? I phoned TRF and they said they would mail me a set of points on July 8 and I and I would not have to send the the voltage stabalizer back. OK sounds reasonable as sometimes mistakes are made. So I received the set of points today,July18th and there is only a half set of points in the box????
Has TRF hired stock room employees,perhaps summer student help, that are unfamiliar with auto parts or is someone trying to sabatoge their operation?
dklawson
There probably is a state of change and confusion since the death of Charles.
I am sure you have already done this but be sure discuss with TRF all the problems you have had and how unhappy you are. Things won't get better if problems are not brought to the front and discussed.
groupdeville
The blue wire condensers ARE uprated ones, sourced from the USA. So there should be no worries about that particular part.
RJCOX
From what I know, the Roadster Factory's ownership and direction is in limbo until July 31st since Charles didn't leave a will.
The Coventry Inn (owned by Charles) just went onto market.
Albert, Charles' son, has been running TRF since December, unable to make any changes or changes in the company until the legal stuff is resolved. Even their Summer Bash is on hold until the shysters get done talking (no offense to any lawyers on this board).
Charles' beloved collection of cars (in the TRF museum) are also on the block. My deepest fear is that everything gets liquidated and the big three become the big two, but don't let me start rumors. I don't know other than in May Albert told me that the company was in a holding pattern until the estate got settled. There's at least a fair amount of family working there. I am personally hoping that nothing changes other than they get bigger. At one point they were contemplating adding upholstery to their list of services and taking back the rebuild business.
Administrator
Boss
I'm not deleting this thread, but I am going to lock it. As others have said, there is likely a lot of turmoil going on due to the unfortunate death of the owner. Just an unfortunate fact that the family left behiind has to deal with. One of our long-standing guidlines here (see rule 7) is to try and resolve vendor issues with the vendor directly. Sounds like you are doing all the right things and I imagine they will try to make it right, but as Doug suggests, be sure to let them know all that as transpired.
Status
lram59 TR4/4A What's wrong with this picture? Triumph 4
B TR4/4A What did I do wrong? Triumph 19
Merlin63Tr4 TR4/4A Triple to dual exhaust valve spring conversion done wrong? Triumph 7
S TR2/3/3A I've been wrong for 60+ years: it looks like it's NOT a 1959 Triumph 8
SD Bugeye What is wrong with people Spotted 4
D Which part is wrong... Spridgets 9
B All the coolant in the wrong place Spridgets 17
Got_All_4 TR2/3/3A Something is really wrong? Overdrive Tranny Triumph 7
Jim_Gruber So what did I do wrong here with Bugsy. Spridgets 2
CJD TR2/3/3A Wrong OD Relay? Triumph 16
I 1954 BN1 - Bump Rubber [shock stopper] wrong length?? Austin Healey 8
TomMull Off Topic BAT: I know this is in the wrong category but It's following the BAT discussion here. Triumph 6
TomMull TR2/3/3A Wrong SU jet? Triumph 0
P Coolant level indicator wrong? Jaguar 4
KVH TR4/4A Wrong Threads on New Fuel Pump? Triumph 13
B TR2/3/3A I think I've got the wrong seats. Now what? Triumph 13
L TR5/TR250 Brake bleeding….what am I doing wrong? Triumph 4
K TR2/3/3A Clutch Operating Shaft with bolt hole in wrong location? Triumph 3
TRMark What could possible go wrong? Restoration & Tools 4
DanLewis Wrong dipstick? Spridgets 37
M TR2/3/3A Indiactor light wiring. Is this what I'm doing wrong? Triumph 7
catfood Whats wrong with this BN1 Austin Healey 14
C TR2/3/3A Wrong slave cylinder Triumph 3
A What's wrong with my TR4a? Triumph 6
RickB I was wrong. Again. Not ignition switch! Spridgets 16
M TR2/3/3A TR3 slave cylinder, What I'm I doing wrong Triumph 2
tinman58 TR2/3/3A somthing's wrong. Triumph 10
DNK Wedge What's wrong with this Pic? Triumph 12
Jim_Newman Where did I go wrong? Austin Healey 37
SMGoose Wrong Clutch Disc? Triumph 2
Hap Waldrop wrong forum, opps, Spridgets 1
R First timer posting in wrong section.. Spridgets 2
M Cutch Slave Cylinder what am I doing wrong [pics] Triumph 6
T Torque steer from the wrong end of the car Triumph 7
T pistons wrong way round Austin Healey 22
JPSmit Wrong bleeping coast again Spridgets 5
regularman What was wrong with the 1500 mechanical fuel pump? Spridgets 20
I Bare metal respary going horribly wrong Austin Healey 8
I Bugey 948 engine rebuild gone wrong - need help Spridgets 12
T T-Series MG TF Notchy Steering - What is wrong? MG 4
J Cost for front suspension refurb right/wrong? Spridgets 8
Got_All_4 TR2/3/3A What's wrong with this brake fluid? TR3 Triumph 19
swift6 Correct me if I am wrong... Please... TVR 20
texas_bugeye oops stack on the wrong end Spridgets 5
TR6oldtimer TR6 What's wrong with this carb '73 TR6 Triumph 7
A sloppy shifter !! somthing must be wrong Triumph 7
G I bought the wrong oil pump Spridgets 5
UmmYeahOk I dont know if this is really cool or really wrong Triumph 18
S wrong fueling Restoration & Tools 5
D Wedge TR7 Parts f/s what am I doing wrong? Triumph 7
