Quarter light glass removal
RestoreThemAll
It seems like this came up recently but I don't find the post. I need to remove the glass from the wing window on my BJ7. Do I drill out what look like rivets on the bottom to take out the locking handle then slide out the glass? Any tricks to this?
PeterB
I recently took mine apart to send it out to be re-chromed. I didn't need to drill out any rivets to get mine out just a lot of patience. I believe I did spray some WD40 or PB Blaster around where the glass goes into the rubber and like with everything else let it set for a little while.
R
RestoreThemAll
I am so happy that I asked. I was convinced late last night that I had to drill. Thanks PeterB. I'll soak it for a couple of days then use a razor on the rubber.
Are you satisfied with the chrome work? Who did you use? Cost?
PeterB
The chrome work can out very nice. I used Red's Parts Attic in TX. I contacted several companies before my decision. Joe the owner was great to deal with, he kept in constant contact about want was needed to be done and when they would be ready. His communication is excellent. I did send a part back to be redone because of a defect and he was great about it. I feel we all make mistakes but its how you correct them that sets you apart. Chroming is not cheap. His prices were right in line with the other quotes I got. He did have to take out those rivets you were mentioning to chrome them. They can be purchased at British Car Specialist in CA. Each whole vent window runs about $400 to $450 depending on work needed. I had a crack in the driver's side outer frame that need to be repaired and that came out great.
R
RestoreThemAll
Oh my. Sticker shock! I'm glad that you told me. It would have been embarrassing to faint right there in the chrome shop office.
Healey Nut
I had two interior door opener handles done for my BJ8 .
they were original handles and the chrome was pitted etc .
250$ CAN later they are perfect . I had a boot lid luggage rack done as well I think that was in the region of 750$ CAN ,
Smiley mouth surround and lip was at least 1K CAN
Rechroming is expensive but its way way better than buying the repro junk the suppliers sell .
R
RestoreThemAll
I was able to pull the glass out. soak it, carefully carve out rubber, work it free. One came out in 3 min, the other 45 min.
I am rethinking the rechrome. Large parts, yes rechrome. Smaller parts maybe not. We'll see what the est. come in at.
Thanks guys!
B Windscreen Pillar/Quarter Light Relationship Austin Healey 2
M Quarter light rubber replacement Austin Healey 6
T For BJ7/8 Safety: add a quarter light mirror [or two] Austin Healey 6
T Quarter light removal Austin Healey 5
chicken Quarter light position to high Austin Healey 2
HAN8L1965 Windshield Quarter light alignment? Spridgets 1
v8mgbal quarter light mirror Spridgets 2
Stewart Windshield alignment quarter light issue MG 9
G Quarter Light Frames Cracked! MG 0
G Quarter Light Frames MG 3
G Looking for Quarter Light assembly MG 4
B Disassemble quarter eliptical leaf springs Spridgets 6
chicken BJ7 Rear Quarter Panels Austin Healey 6
J Tips for quarter elliiptic spring install Spridgets 3
Joe Schlosser Quarter Eliptic spring bushing Spridgets 6
maxwedge5281 BN6 rear quarter panels installation Austin Healey 4
K TR2/3/3A Cockpit quarter rails? Triumph 11
R Rear quarter elliptical suspension changing Spridgets 12
bugedd Quarter Elliptical Springs Spridgets 6
B BJ7 & BJ8 Interior Rear Quarter Panels Austin Healey 12
CessnaTPA Rear Quarter Panels Austin Healey 14
PatGalvin TR2/3/3A PS Quarter Panel Repair - need a patch panel? Triumph 6
R Removing rear quarter elliptical Spridgets 5
drooartz Bugeye quarter panel structure Spridgets 5
B BJ7 Rear quarter panels Austin Healey 0
PatGalvin TR2/3/3A TR3 PS Quarter Panel Dog Leg needs a good home Triumph 2
Mickey Richaud T-Series GT Rear Quarter Window Catches MG 4
T BE Quarter Elliptic Mounting Bolts - threads gone Spridgets 5
P GT6 GT6 Repairing Rust in Rear Quarter Triumph 8
T Question regards Quarter Elliptic Rear Springs Spridgets 6
chicken How do the rear trim quarter panels fit Austin Healey 25
germanmichel How I can dismount the rear quarter panels ....? Austin Healey 4
davidk Quarter Master Throw out Bearing Triumph 8
H door and rear quarter panels BN 7 Austin Healey 1
G TR2/3/3A QUARTER PANEL, L/H [dogleg] for TR3 Triumph 1
B Need BJ-7 Rear Interior Quarter Panels Austin Healey 2
AUSMHLY Attaching the quarter panel Austin Healey 6
AUSMHLY Attaching the quarter panels Austin Healey 8
RobSelina Rear quarter pannel replacement/conversion Spridgets 4
AUSMHLY Attaching the quarter panels Austin Healey 1
M bugeye quarter panel question Austin Healey 0
M bugeye quarter panel question Spridgets 2
D TR2/3/3A 3D printed tail light Triumph 12
B For Sale GT6/Spitfire License Plate Light Assembly Triumph Classifieds 0
B Positive-Ground LED Light Strip Austin Healey 8
bigjones TR2/3/3A Rear tail light not budging Triumph 5
jfarris TR2/3/3A Light show in the turn signal indicator bulb Triumph 2
F TR2/3/3A head light buckets Triumph 3
tr6nitjulius For Sale TR6 tail light assemby & Resurfaced/New Ring Gear Flywheel Triumph Classifieds 0
G Brake Light Switch Failure Austin Healey 24
