Page 2 of 2 FirstFirst 12
Results 21 to 27 of 27
Thread: Engine dies slow left turn.
  1. #21
    Join Date
    Jan 2011
    Location
    stamford, CT
    Posts
    2,641
    Thanks Thanks Given
    Thanks Thanks Received
    35
    Thanked in
    Re: Engine dies slow left turn.
    In the case I know about, it was that foil-covered flat spacer from under the cap of a bottle that fell into the tank and would shift and block the outlet.
  2. #22
    Jedi Trainee Tosh's Avatar
    Join Date
    Jan 2006
    Location
    New Alexandria, PA
    Posts
    205
    Thanks Thanks Given
    Thanked in
    Quote Originally Posted by pdplot View Post
    Ok...s**t is really getting weird. An aluminum seal from a bottle cap??
    Guess it won't be surprising when someone reports finding a condom somehow blocking a fuel passage.
    Heh...
    1969 TR6
    1973 MGBGT
    1988 Mustang GT Hatch
    2013 Impreza Sport
  3. #23
    Jedi Trainee Tybalt's Avatar
    Join Date
    Feb 2007
    Location
    Marietta GA USA
    Posts
    269
    Thanks Thanks Given
    9
    Thanked in
    Quote Originally Posted by Tosh View Post
    Heh...
    And when that happens you will know that you have definitely been, err, uhh, well, you know.
  4. #24
    Join Date
    Jan 2006
    Location
    New Alexandria, PA
    Posts
    205
    Thanks Thanks Given
    Thanked in
    Hookay,
    After a lot of great suggestions I have found the fix. Unrelated while this thread was underway, I washed the car including pressure wash of the engine compartment. After that...no start. We've probably all been there. Push the car into garage let it set overnight. It has been really hot here in western PA. AM the next day, still will not start. Spins but won't start.
    Begin to suspect an ignition module problem. Go to Advance Auto..the module checks out OK. Pull and reseat all spade terminals, check fuses, remove ECM check connections, check the circuit board for that overheated smell, resoldered one questionable connection on the starter.
    After 3 days with cranking but no start and replacement of distributor cap, rotor, coil, spark plugs. Resetting the air gap between reluctor and magnetic pickup inside the dizzy I finally checked continuity from the ignition module to to the coil negative (white wire)...there was none. WHAT?? Turned out the wire was broken behind the spade connector but was invisible because the insulation was mostly intact and keeping the wire in one piece. More or less an invisible break that made occasional connection.
    I repaired the wire with a new connector, hooked it back up and the car started right up. Take it out for a drive, no more stall on the left handers. RPM's still drop somewhat more than I think they should but it looks as though TR3 driver may have pretty much called this one in more ways than one. Fact is, it looks as though that wire was responsible for two separate issues. We all know how difficult intermittent electrical issues are, but, by finally failing it became possible to zero in on the source of the problem. Definitely a relief.
    Thanks to you all for being so helpful. What a resource you are.
    1969 TR6
    1973 MGBGT
    2013 Impreza Sport
  5. #25
    Join Date
    Jan 2011
    Location
    stamford, CT
    Posts
    2,641
    Thanks Thanks Given
    35
    Thanked in
    9 out of 10 times, it's something simple and stupid like a broken wire. The 10th time...you don't want to go there.
  6. #26
    Join Date
    Jan 2006
    Location
    New Alexandria, PA
    Posts
    205
    Thanks Thanks Given
    Thanked in
    From Wikipedia:
    Occam's razor (also Ockham's razor or Ocham's razor (Latin: novacula Occami) is the problem-solving principle that states, "Entities should not be multiplied without necessity."
    You know "Keep It Simple Stupid" (KISS). Was never very good at that.
    Thanks.
    1969 TR6
    1973 MGBGT
    2013 Impreza Sport
  7. #27
    Yoda glemon's Avatar
    Join Date
    Jun 2007
    Location
    Nebraska, USA
    Posts
    3,596
    Thanks Thanks Given
    15
    26
    Thanked in
    The classic electrical problem, hard diagnosis, simple and cheap fix.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
