TR2/3/3A rubber seal go towards the inside of the trunk
sp53
Does the drip edge or overhang of the rubber seal go towards the inside of the trunk on a pre-60K or does the edge point out? I remember the debate and that someone had the gas tank out and actually looked inside with a flashlight and found the seal was better with the overhang end pointing inside the trunk which sounds counterintuitive; what way was it?
steve
2liter4cyl
Bronze
I am the one who crawled inside in 2-2-2015 and tried gasket both ways . lip inward vs outward. Like no fit if outward. After much cutting and fitting the height of the mounting flange I, gained an inward fit. I have the measurements and solution on file. Now, 4 years later, I tried the $1 bill test. I have only one section that needs adjustment. should have tested my work 4 yrs ago!! Any one with gasket lip outward, please try the refrigerator test. I would like to know if either way works equally. I have a '60 tr3a TS75773. can make copy of my notes. LeT
mrv8q
I’ll play along... I replaced the original trunk weatherstripping a couple of years ago, using the TRF seal, pre 60K car. Using the original as a template, the seal “points” outward. After a couple of years, the top seal now points inward to the trunk, I’m guessing the trunk has naturally forced the seal this way.
The sides and bottom of the seal remain pointing outward. In my car, the seal was cut in 2 pieces: across the top was one piece, the sides and bottom were all one piece.
The TRF seal works fine in my experience, and fit perfectly in the channel.
ModifiedBJ7 BJ7 Windshield Surround Rubber Seal Austin Healey 2
D Top Door rubber and fuzzy seal Spridgets 5
T Windscreen wiper wheelbox rubber shaft seal Austin Healey 4
Rut Windshield rubber seal Spridgets 6
Rob Glasgow Hard Top Rubber Seal Austin Healey 3
Tinkerman TR2/3/3A Wiindshield - top rubber seal. Triumph 3
R TR2/3/3A Source for rubber seal on A/M side curtains Triumph 4
Tinkerman TR2/3/3A 1960 TR3A Boot rubber seal installation? Triumph 7
M TR4/4A windscreen frame bottom rubber seal......help please. Triumph 3
M TR4/4A Trunk/Boot rubber seal. Triumph 8
W TR6 fuzzy rubber door seal Triumph 3
J TR2/3/3A Lower windshield rubber seal Triumph 3
Tinkerman TR2/3/3A 1960 TR3A Bottom Rubber Seal on the Windscreen Triumph 3
Tinkerman TR2/3/3A Handbrake lever rubber seal installation Triumph 3
Lbp TR2/3/3A Question about TR3 Rubber Windshield Seal Triumph 9
NutmegCT Source for rubber door seal material? Restoration & Tools 9
Lin Big Healey Roadster Windscreen to body Rubber Seal Austin Healey 0
H TR4/4A tr4a rubber trunk seal Triumph 8
A TR2/3/3A TR-3A Trunk Rubber Seal Triumph 10
I TR6 TR6 windscreen rubber seal help Triumph 2
chicken Door brush and rubber seal Austin Healey 2
T windshield rubber seal Austin Healey 7
K TR2/3/3A TR3...Gas cap rubber gasket/seal in cap lid? Triumph 1
S new vent rubber seal Triumph 6
W TR2/3/3A TR3 Door Seal Rubber Question photo request Triumph 4
CraigLandrum Rubber seal installation? Triumph 4
J Gas tank seal rubber. Austin Healey 8
bighealeysource Rubber trunk seal for BT7 Austin Healey 6
bighealeysource Rubber seal on windshield frame of BT7 Austin Healey 0
bighealeysource MGB Refitting rubber window seal on 65 MGB MG 1
MadRiver TR6 Rubber seal on top of grill on TR6 Triumph 5
jjbunn Another "Which way round" rubber seal question! Triumph 8
R BJ-7 window rubber seal Austin Healey 2
NutmegCT rubber sidecurtain seal source? Triumph 7
Lin Boot Lid rubber seal Austin Healey 10
John Loftus Rubber seal around gearbox? Austin Healey 20
Lin Disc brake dust shield rubber seal glue Austin Healey 1
JPSmit rubber door seal question Other Cars 2
bluemiata90 replacing the rubber seal on windshield Triumph 18
D For Sale GT6 Rotoflex Axles: clean, beadblasted, coated with POR15, excellent rubber couplings. Triumph Classifieds 0
K TR2/3/3A Exhaust bracket rubber "top hat" bushings? Triumph 3
L Red Rubber Brake Grease Austin Healey 2
C MGB Rubber Bumper cover removal MG 5
algot1901 1950 Prefect E93A-946480 - door bottom rubber Other British Cars 14
algot1901 Weather stripping and rubber parts Other British Cars 1
LAW75 Rubber Tubes for Choke Cable Austin Healey 11
B TR4/4A Rubber wiper motor mounts Triumph 4
BoyRacer Rubber Fender Buffers Austin Healey 2
S TR2/3/3A Cutting the finish end on the windshield top rubber Triumph 4
