Results 1 to 14 of 14
Thread: Modem Help
The Pub is: Forum to generally shoot the breeze. It is NOT: a debate forum (NO Politics, religion, or controversial topics.) Keep it clean, fun and lite!
  1. #1
    Yoda Gliderman8's Avatar
    Join Date
    Jun 2008
    Location
    PA
    Posts
    8,113
    Thanks Thanks Given
    11
    Thanks Thanks Received
    25
    Thanked in
    Modem Help
    I need to replace an outdated modem as it is not compatible with my level of internet speed. I recently upgraded to 250 Mbps. Currently I am getting approximately 30-50 max.
    My needs are basic internet surfing as well as streaming for three TVís. No Voip.
    Should I get a modem/router as one unit or get a separate modem and a separate router?
    Your thoughts and suggestions welcome as well as product to stay away from. By the way my isp is Comcast/Xfinity.
    Elliot
    Central PA
    1973 TR6 Damson Plum / Biscuit interior, HVDA 5-speed, Good Parts Hubs
    1976 TR6 White/Biscuit interior SOLD
    Nostalgia isn't what it used to be.
  2. #2
    Yoda John Turney's Avatar
    Join Date
    May 2002
    Location
    Concord, CA
    Posts
    3,540
    Thanks Thanks Given
    41
    28
    Thanked in
    Re: Modem Help
    You don’t get one from Comcast/xfinity?
    John, BN4
  3. #3
    Yoda TOC's Avatar
    Join Date
    Jun 2008
    Location
    Floe Ice, Antarctica
    Posts
    6,059
    Thanks Thanks Given
    14
    Thanked in
    Re: Modem Help
    I did that three, four weeks ago. Did NOT use Comcrap, as I ain't paying them $10/mo rental and have something I cannot access like Frontier's was.
    Look on Amazon, it will tell you in the item description speed AND if it's compatible with Comcrap, Frontier, or whatever.
  4. #4
    Join Date
    Jun 2008
    Location
    PA
    Posts
    8,113
    Thanks Thanks Given
    11
    25
    Thanked in
    Re: Modem Help
    I would rather buy than rent from Comcast. I have looked on Amazon but I thought it best to get recommendations from people who are more knowledgeable with this equipment.
    Elliot
    Central PA
  5. #5
    Great Pumpkin NutmegCT's Avatar
    Join Date
    Jul 2004
    Location
    Connecticut USA
    Posts
    10,924
    Blog Entries
    1
    Thanks Thanks Given
    39
    87
    Thanked in
    Re: Modem Help
    Hi Elliot - I think you're asking if you should get a single modem/wifi unit, or two separate units?
    When I upgraded speed (Charter/Spectrum) from 30 to 100 mbps, I was glad I had my own modem and separate wifi router. The modems Charter "approves" are inexpensive, and my wifi router already supported the faster speed. So I spent $39 for a new Hitron E3 modem, and kept my Belkin wifi router.
    Hey - I'm an old "component" guy. None of those fancy-dancy single unit stereos for me and my buddies!
    Mac & Phyllis Take a Trip: http://nutmegflyer.com/trip-details-daily-updates/
    History: 1976 MGB, 1959 Triumph TR3A, 1960 Mercedes-Benz 190b, 1958 Rambler American.
    Current: 1953 MG TD27318.
  6. #6
    Join Date
    Jun 2008
    Location
    PA
    Posts
    8,113
    Thanks Thanks Given
    11
    25
    Thanked in
    Re: Modem Help
    Thanks Tom. Your living room looks great; there isn’t anything there that can be hacked or that requires a monthly subscription.
    Elliot
    Central PA
  7. #7
    Join Date
    May 2013
    Location
    southwest Ohio
    Posts
    1,147
    Thanks Thanks Given
    7
    Thanked in
    Re: Modem Help
    Quote Originally Posted by NutmegCT View Post
    Hey, if there isn't enough wire in back to redo a 747 and you can't rely on it to heat the room in the dead of winter, what's the point...
  8. #8
    Yoda TOC's Avatar
    Join Date
    Jun 2008
    Location
    Posts
    6,059
    Thanks Thanks Given
    14
    Thanked in
    Re: Modem Help
    My only addition to that "Wall of Sound" is a Graphic Equalizer. Reel-to-Reel, amps, AM/FM tuner, 8-track, even a CRT Television.
    Where's your turntable?
    Oh, my
    WiFi/Router is an Arris SBG6700-AC. Recommended brand...can't recall the dis-recommended brands off the top.
    Mine has two Ethernet ports, have more than that to plug in, so I dug out an old Workgroup Switch and plugged that in.
  9. #9
    Join Date
    Feb 2016
    Location
    Macon Georgia
    Posts
    2,399
    Thanks Thanks Given
    10
    30
    Thanked in
    Re: Modem Help
    Using a separate modem and Linksys Mesh router + a switch to give me some wired connections. It is a Linksys Velop intelligent home mesh WiFi router I have 2 base stations and you can have more if you have a larger home. The Mesh router covers the whole house with a single WiFi channel.
    Works well
    David
    TR3A TS75524L
  10. #10
    Join Date
    Jun 2008
    Location
    PA
    Posts
    8,113
    Thanks Thanks Given
    11
    25
    Thanked in
    Re: Modem Help
    Thanks David
    Elliot
    Central PA
  11. #11
    Great Pumpkin DrEntropy's Avatar
    Join Date
    Sep 2005
    Location
    Elsinore, DK
    Posts
    32,766
    Thanks Thanks Given
    16
    50
    Thanked in
    Re: Modem Help
    I'm with Tom: A component for each function. My setup (and most business clients I have) is to run coax to the set-top box for TV, from the provider's unit (Arris here, but that doesn't matter much), run a Cat-5/6 cable directly into a firewall computer with the provider's WiFi turned off and their modem set up as a simple bridge. The firewall (2 NIC's) gets it's "public" NIC IP addy from the provider's modem, via DHCP. Has the second NIC, on the "inside" LAN, assigned a Class-C LAN addy (192.168.xxx.xxx). That is wired to the switch/router inside, along with a WiFi router for our use: "Hidden" SSID and a key from Hades to access. The house is plumbed with at least one RJ-45 port to use in each room. In our case, using a a 24-port patch panel to connect all room drops to a 24-port Cisco switching router. All machines on the "inside" are manually assigned Class-C addresses with the firewall as their gateway. With this or a similar setup, all the provider (and the rest of the innerwebs) sees from their end is the provider's modem and if they can get through that (VERY unlikely), the firewall appliance. At any given time a client can be running from six to two dozen machines. At th' hovel only an average of seven or eight.
    WiFi routers can range in cost and ...err... range. I put Buffalo WiFi units in commercial setups, good coverage, good R.O.I. An "El Cheapo" AirLink 802.11G here at th' hovel. Even that will stream video to Herself's iPad, no sweat.
    For residential use, I like Linksys WiFi units. Easy to configure any way you want, through the GUI. Most all WiFi routers are running a Linux kernel. From the EXTREMELY expensive (but they're RED!) Watch Guard ones, to this lowly AirLink.
    '64 MGB, '67 Lotus Elan S-3 DHC,'69 Lotus Elan +2
    '78 Alfa Romeo Spider-undergoing surgery: O=\*/=O
    '84 300D Turbo-"Diesela"-Now my Daily: Oo|≣|oO
    '02 Toyota Camry- SWMBO's 'new-to-her' Daily. <sigh>
    Chaos & Mayhem PTY, LTD..C.I.O. & Floor Sweepervisor
  12. #12
    Join Date
    Jun 2008
    Location
    PA
    Posts
    8,113
    Thanks Thanks Given
    11
    25
    Thanked in
    Re: Modem Help
    Thanks doc. I had already made the decision to go with separate units for modem and router as that makes the most sense to me. I've decided to put the purchase on hold for a little bit as other priorities have arisen.
    You think you have a cheapo router?.... I've been using a TP-Link with an "N" designation. I bought the router on Amazon for less than $20!!!.
    It's functioning with our three streaming TV's and three laptops but as you know it needs to be replaced soon.
    Elliot
    Central PA
  13. #13
    Yoda TOC's Avatar
    Join Date
    Jun 2008
    Location
    Posts
    6,059
    Thanks Thanks Given
    14
    Thanked in
    Re: Modem Help
    Quote Originally Posted by Gliderman8 View Post
    Just make sure only one unit is wireless WiFi. Run into all sorts of issues if two units are WiFi, or so I have been told, like Modem with WiFi and Router with WiFi.
  14. #14
    Join Date
    Jun 2008
    Location
    PA
    Posts
    8,113
    Thanks Thanks Given
    11
    25
    Thanked in
    Re: Modem Help
    Thanks for the heads up. I’m looking at an Arris SB8200 which is strictly a modem.
    Elliot
    Central PA
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
