Seat belts
Rut
I know this is not very smart, but the only LBC that has seat belts is the 1970 MGB and I installed retractable 3 point belts in it. The Bugeye and TR4A have nothing and the more I drive the more uncomfortable I get. The TR4A came with 2 point belts and the Bugeye with nothing, so 3 point would be the safest. Any suggestions on installing 3 point belts in a Bugeye?
Thanks, Rut
Jim_Gruber
Rut. Got them in Bugsy. I drilled floor and used large fender washers to spread the load. Drilled wheel well from underneath IIRC. Comfy, feel as safe as you can in a BE. Since everything is out I could post pics of hole locations. Got to keep you safe guy. Steering column is awfully close to my chest. Heavy over to paint primer on bonnet right now. Dash is done. Glue I used 3M90 Adhesive has a scatter gun type glue applicator and set up too fast. Got some spots where glue did not adhere or cured too fast. Once instruments are installed will probably be just fine.
Rut
Rut
Jim,
Thanks for the help and glad to hear you’re making progress!
Rut
SaxMan
I upgraded my '69 Sprite to 3-point non-retractable belts, and then later 3 point retractable belts. Like you, I just feel uncomfortable in a car without seat belts. My daughter kept slipping out from the non-retractable belt, so that's why I went to retractable units.
I plan on recycling the 2-point and 3-point non-retractable belts that I replaced on the Sprite for use in my '53 Plymouth project, which is completely devoid of any seat belts.
drooartz
I've got 3-point belts in the Morris and MGB, using the factory mounting points. Not sure what I'll do in the Bugeye. I'll at least do lap belts, not all the way convinced on shoulder belts given the low mounting points for the shoulder belts. We'll see.
Deleted member 8987
Retractables don't do you any good unless they lock with accelerometers as in a collision, they will extend out and you slip out, Been my experience anyway.
On using your old ones on the 53 Plymouth.....better czech length and waist size first.
When I put lap belts in my 50 Ford Tudor, lord, 45 years ago, got some out of a 67 Galaxie, retractable, non-adjustable, and the seat is taller, bigger, barely connected. Then 45 years of waist expansion, I'm there. They still work, but just.
My guess is, OTTOMH, the seats being much lower and smaller in the LBC, you may not have enough belt to extend out. Better to czech first than drill and fit and find out you can't even belt in a rolled up newspaper.
My Jag has front three-points, lap and single shoulder...to adjust, get out of the car, on yer knees in the pouring rain, and work the belt through the adjustment buckle near the floor mount.
I have driver's side set, passenger we just move the seat back and forth to set.
SaxMan
The retractables from VB seem to work reasonably well. Sometimes a little too well as once they lock, I've had to do some serious fiddling with the adjusters to get them going again.
Yes, I'd definitely will take some measurements before I start drilling holes and installing belts. I'm not overly concerned about an expanding waistline, riding a bike 3 times per week seems to have held that in check.
twas_brillig
I've mentioned trying to develop a 'roll bar' for our bugeye (not for protection against rollover, but against pickup trucks running red lights) and here is where we are at the moment. The intention is to have:
- something that will fit under the 'hood', so it follows the outlines of the hood support
- the horizontal bar is to provide additional lateral strength for the mythical pick-up truck
- it also provides an anchor point for four point seat belts, which was my original plan but my concern is that other drivers might consider them too finicky and just go with a lap belt, so we're going to go with three point belts initially
- we'll be using the later split hood supports, as the original BE won't fit with the roll bar in place
Dunno when we're going to get the car finished up and on the road (the 84 year old chap building the engine has been at it for two years...!!!, but the body isn't ready just yet) but when the body/rollbar etc. is complete and we've had a chance to drive it (hopefully the existing engine will be capable), then I'll ask the shop to build another one for our Yellow Bugeye, and to document what it would cost to bend/cut/trim all the metal pieces but not weld them, and we'll see if anyone else wants one.
Rut - if you're interested, phone me 403 890-7143 cell and I can give you additional pictures. And I could also provide somewhat imprecise measurements if you wanted to try dummying one up yourself, and save you some of the development costs that have gone into this. Our first fitting was based on bending/cutting/tack welding a prototype out of electrical conduit, and you may want to consider the same. Doug
nomad
Well, I'm a great one to talk since I'm running two Spridgets with just lap belts and one with no belts but wanted to mention that Bill M made a great point to me years ago. The earlier Spridgets that I drive do not have a collapsible steering column and though mine have decent brakes many do not. In a front end collision the only protection we could get from that steering column would be with 3 point belts. I remember seeing cars that had been in a front end collision from "in the day" where the driver had hit the steering wheel. Not pretty!
Just mentioning it.
The wife insists the one with no belts gets some. Might as well go 3 point.
Kurt
Bayless
I will definitely go for 3 point on mine before it hits the road.
tr6nitjulius For Sale 4$ale: 3 Point Seat Belts Red Triumph Classifieds 0
T Three-Point Seat Belts Austin Healey 8
JohnGone Wanted '80 MGB without seat belts? MG Classifieds 3
M For Sale vintage 3-point retractable seat belts MG Classifieds 0
R 3-point seat belts on late production BT7 MKII Austin Healey 7
S Wanted MGB Static Seat/Shoulder Belts MG Classifieds 0
S Retractable Seat Belts Spridgets 3
T Looking for two part, three point seat belts Austin Healey 6
D TR6 '74 TR6 Seat Belts Triumph 6
BN6_2197 Seat belts in BN6 Austin Healey 15
69MGC MGC 3-point Seat Belts MG 3
RAC68 Are 3-Point Seat Belts Safe in a Healey? Austin Healey 38
B TR6 Seat belts Triumph 2
T TR4/4A Tr4a - 3 point seat belts with Miata seats Triumph 8
Got_All_4 TR2/3/3A Suggestions for shoulder harness retractable/inertia seat belts Triumph 4
S Seat Belts Installed This Weekend Austin Healey 43
D Seat belts on a BJ8 -64 Phase 2 Austin Healey 20
L Rear seat belts Austin Healey 26
JimTR4 TR4/4A Securon 500/30 seat belts Triumph 0
S Seat belts Austin Healey 2
B TR2/3/3A seat belts Triumph 7
glemon General TR Nice Deal on Seat Belts Triumph 11
A TR2/3/3A Tr3 Seat Belts Triumph 3
M TR2/3/3A Seat belts, what style? Triumph 17
W I really wanted these seat belts... Spridgets 2
D TR6 76 TR6 Kangol Reflex Seat Belts Triumph 3
W 1966 Sprite seat belts Spridgets 7
Lotuswins BJ8 3 pt retractable Seat Belts Austin Healey 10
7 Retractable seat belts - BT7 Austin Healey 8
B 60 TR3 Seat Belts Restoration & Tools 0
Boink Best Seat Belts option for Bugeye? Spridgets 21
T TR4/4A Retractible 3-point seat belts for TR4a Triumph 6
HEALEYJAG 73 etype roadster seat belts Jaguar 1
T 3 point seat belts options / location Spridgets 9
doates Spitfire Spitfire Seat Belts Triumph 4
JRC Seat Belts Triumph 3
GreenOne TR6 TR6 Replacement Seat Belts Triumph 1
jhva MGB 71 MGB Seat belts MG 5
L Original seat belts? Austin Healey 11
ronzet 3 point Seat Belts - Installation Austin Healey 4
L BJ 8 Rear seat belts Austin Healey 2
B Seat Belts in a MKII? Spridgets 4
B 1960 Healey 3000 Seat Belts Austin Healey 10
tinman58 3 point seat belts Triumph 7
nevets Installing seat belts on a BN6/BN7 Austin Healey 5
Johnny AH Seat belts Austin Healey 6
R Seat Belts Question Triumph 5
mjobrien Seat Belts for 100 Austin Healey 10
TR4A_IRS TR4/4A 3 point seat belts on a TR4? Triumph 10
R TR2/3/3A TR3 seat belts Triumph 7
