Results 1 to 11 of 11
Thread: What to replace when engine is out
Discussions of MG Sports Cars
  1. #1
    Moderator drooartz's Avatar
    Join Date
    Mar 2005
    Location
    Utah, USA
    Posts
    10,763
    Thanks Thanks Given
    Thanks Thanks Received
    3
    Thanked in
    As mentioned in my other thread, I'm currently swapping in a known decent engine into my '70MGB so that I can get it back on the road. With everything out there are a few things I know I should replace. Here's what I'm thinking:
    Clutch (hydraulics are already new)
    Throwout bearing
    Transmission and engine rubber mounts
    Oil cooler and lines
    Anything else I should be thinking of? I'm not looking to rebuild this donor motor, just want to be smart if there are easy todo's with it out.
    Drew Frink
    '59 RHD Frogeye Sprite - "Penny" sleeping for now
    '66 RHD Morris Minor - "Maggie" awaiting a non-cracked transmission
    '70 RHD MGB - awaiting a donor engine
    '19 Triumph Bonneville T100 - good to have one that runs
  2. #2
    Moderator Mickey Richaud's Avatar
    Join Date
    Mar 2003
    Location
    Townsend, Tennessee
    Posts
    14,830
    Thanks Thanks Given
    1
    23
    Thanked in
    Re: What to replace when engine is out
    Define "decent" - was compression good? How long do you expect to run it?
    That said, an easy chore would be to clean up/refresh the carbs. Not a full rebuild, but new gaskets and needle/seat; maybe jets, too. And as long as you're replacing the clutch, might as well pull the flywheel and pop in a new rear main seal. Front as well, especially if it's been sitting a while.
    Anything else, and you're getting into machine work.
    Oh, and don't forget to check the tappet cover plates and seals; oil pan gasket, too.
    "There are three kinds of men. One who learns by readin'. The few who learn by observation. The rest of them have to pee on that electric fence for themselves." Will Rogers
    Mickey Richaud '73 MGB, '69 MGB GT/V6 (SOLD! ), Victor TF, '03 Jaguar XK8
  3. #3
    Join Date
    Mar 2005
    Location
    Utah, USA
    Posts
    10,763
    Thanks Thanks Given
    3
    Thanked in
    I'm going to use the carbs and distributor from my old engine -- both were rebuilt a few years ago (carbs by Hap, distributor by Jeff).
    Engine compression was okay, nothing to write home about but fine. Car had been sitting for a couple years but was a daily driver before that even with the rust. My goal is to get 2-3 years out of it, so maybe 5k miles reasonably given the other cars in the fleet.
    Seals make sense.
    Drew Frink
  4. #4
    Join Date
    Jul 2018
    Location
    Austin TEXAS
    Posts
    123
    Thanks Thanks Given
    5
    Thanked in
    Quote Originally Posted by Mickey Richaud View Post
    I had considered putting a new rear main seal in my engine while it is out and on the stand (even ordered 2 since I expected to screw one up trying to do it), but the instructions in the manual started talking about taking bearing journals apart and such, so I opted not to go that far since it had not been leaking last time it ran. There was NO oil at all between the flywheel and engine backplate so my feeling was don't fix what isn't broken. I did put a new oil pan gasket on since I had to pull the pan to straighten a dent in it, plus I wanted to inspect the innards of the crankcase while I had the chance. I did remove and clean the oil pump pickup screen while in there since it had some solidifed goop at the very bottom. Replacing those little cork blocks at the main bearings as part of the new pan seal was a pain (well technically getting the old ones OUT was the pain).
    When replacing the clutch don't forget about that little bronze journal that goes in the hole on the flywheel. Good idea on the tappet covers - I think I ordered those but if not I will. Much easier to do while its sitting on the engine stand. Also since its almost impossible to get to any other time, I'd replace the rubber plug with the metal disc in the center that covers an opening in the engine backplate. Mine fell out in peices and it took me quite a while to even figure out what it was and where it these odd metal parts floating around in the bell housing came from.
  5. #5
    Yoda TOC's Avatar
    Join Date
    Jun 2008
    Location
    Floe Ice, Antarctica
    Posts
    6,212
    Thanks Thanks Given
    20
    Thanked in
    I have owned my own shop, run several more.
    Rule of thumb (ignored by "expert" mechanics to their sorrow), change as little as possible at first.
    Swap parts over, especially if they worked, because if it doesn't work with a rebuilt distributor, alternator, starter, carburettor, and who knows what else...it's a LONG process sorting out what doesn't work right/
    Then, after it's running, if you need, swap out one bit at a time.
  6. #6
    Obi Wan Stewart's Avatar
    Join Date
    Oct 2003
    Location
    Santa Barbara Ca
    Posts
    2,453
    Thanks Thanks Given
    Thanked in
    New front and rear seal, side cover seals, clean out toms knob, replace the rubber clutch hose (super easy with engine out no so fun with it in) and I'd change the water pump as they are cheap and easy to do with the engine out. Great time to do an engine bay degrease and detail.
    1975 Titanium Grey Metallic Supercharged MGB.
    Restoration of the 75MGB
    You Can't Prove It Won't Happen
  7. #7
    Join Date
    Oct 2003
    Location
    Santa Barbara Ca
    Posts
    2,453
    Thanks Thanks Given
    Thanked in
    Also change out the rear seal on the transmission. Piece of cake outside the car royal pita in.
  8. #8
    Great Pumpkin JPSmit's Avatar
    Join Date
    Nov 2004
    Location
    Toronto, ON
    Posts
    18,585
    Thanks Thanks Given
    55
    Thanked in
    I might investigate a header and maybe a slightly hotter cam
    John-Peter Smit
    1976 MG Midget
    1969 Vauxhall Viva GT
    1958 Fiat Multipla (Barn art)
  9. #9
    Yoda PAUL161's Avatar
    Join Date
    Jan 2005
    Location
    Locust Grove, Oklahoma
    Posts
    9,379
    Thanks Thanks Given
    1
    41
    Thanked in
    JP, There has been a misconception about the MGB exhaust manifold needing upgrading. Because it was designed so well there is very little to no advantage of replacing it with something else, actually a waste of money. Cleaning it up, ceramic coating it can help with heat transfer if needed, but it's already the best exhaust system one can get for the 1800 MGB series engines. The original designers hit the nail on the head for exhaust extraction. JMHO, PJ
    Remember, Never Forget
    We Live In The Land of The Free
    Because of The Brave
    How good it feels, the hand of an old friend! Longfellow
  10. #10
    Join Date
    Jul 2018
    Location
    Austin TEXAS
    Posts
    123
    Thanks Thanks Given
    5
    Thanked in
    Quote Originally Posted by PAUL161 View Post
    I tend to agree (unless you are talking about the very late ones that had to be redesigned to accomodate the cat can). I had to replace one years ago because it cracked, and I went with a header because finding a replacement original was hard. I did not discern any improvement with the header. The non-catalytic exhaust is designed more like a header than a straight manifold anyway. If I ever get my current car reassembled I'll be running the factory 1970 exhaust into one of those stainless Falcon pipe/muffler setups.
  11. #11
    Join Date
    Mar 2005
    Location
    Utah, USA
    Posts
    10,763
    Thanks Thanks Given
    3
    Thanked in
    Thanks for the thoughts. I won't be getting into the internals of this engine, it's a temporary swap and is running, so not going to mess. External seals make sense, maybe the water pump as well. TOC makes a good point about sticking to known parts -- I'll be keeping many of the external bits from my old engine, as they all have miles on them and are known functional.
    Hoping to get some parts ordered this week so I can get at it.
    Drew Frink
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
