Results 1 to 5 of 5
Thread: Alumifix Flux-cored Rods
Discuss general restoration and car care topics (paint & body, upholstery, woodworking, etc) as well as tools.
  1. #1
    Yoda John Turney's Avatar
    Join Date
    May 2002
    Location
    Concord, CA
    Posts
    3,919
    Thanks Thanks Given
    71
    Thanks Thanks Received
    46
    Thanked in
    I saw this on Facebook, and although it sounds wonderful for joining aluminium, I'm wondering if it's too good to be true. Anyone tried it?
    https://dealygiftshop.com/products/a...X-LaXXjK-mupUE
    John, BN4
  2. #2
    Join Date
    Aug 2003
    Location
    Sunny So California
    Posts
    19,552
    Thanks Thanks Given
    8
    138
    Thanked in
    Re: Alumifix Flux-cored Rods
    I tried a similar product years ago, to repair a TR3A thermostat housing. Watched a fellow at the state fair solder blobs to beer cans, then use the blob to tear the can apart, "proving" the weld was stronger than the base metal.
    But my propane torch just wasn't enough to get the housing hot enough to flow the solder. I guess there was a reason he was using beer cans (which are extremely thin)!
    And by the time I got an OA torch, I'd lost the rods and used the special SS wire brush for other things (which supposedly ruined it for this purpose).
    At that time, a used housing turned out cheaper than the kit anyway
  3. #3
    Darth Vader Bayless's Avatar
    Join Date
    Mar 2007
    Location
    Oklahoma City
    Posts
    2,664
    Thanks Thanks Given
    15
    Thanked in
    I remember the guy at the state fair.
    Was Man nicht im Kopf hat muss Man in den Beinen haben
    '48 Ford Prefect
    '67 Sprite (project)
    '74 Super Beetle
    http://enfoprefect.org
  4. #4
    Yoda martx-5's Avatar
    Join Date
    Jul 2002
    Location
    Kings Park, NY
    Posts
    6,600
    Thanks Thanks Given
    8
    Thanked in
    I used a similar product to repair the aluminum capping on my TR3, which is thin like the beer can Randall mentions. There were a few other heavier items that I used it on that were maybe 1/4" thick. On the heavier stuff I used a MAP gas cylinder. The stuff works well if you clean it properly with the stainless brush. I pretty sure it's a zinc alloy.
    Edit: Below is the stuff I used...AlumiWeld...In the FAQ, they give the physical characteristics and mention that it is a zinc alloy. I still have 3 or 4 rods.
    https://www.alumiweld.com/
    Art
    '58 TR3A TS236xxL
    '92 Mazda Miata -- Supercharged
    '07 Mazda RX-8
    '11 Mazda CX-7
  5. #5
    Yoda dklawson's Avatar
    Join Date
    Mar 2005
    Location
    Durham, North Carolina, USA
    Posts
    6,252
    Thanks Thanks Given
    52
    Thanked in
    I have used a similar product with success on diecast aluminum. It was from National Welders and has/uses no flux. You get the broken part up to temperature with a propane or mapp torch, move the flame out of the way, and rub the aluminum rod on the broken area to be fixed. If the temperature is high enough (about 700 oF) the rub-on rod scratches through the oxide coating on the broken parts and tins the surface. Over the years I have used it (the same package of material I bought over 35 years ago) to repair several broken aluminum parts. Harbor Freight sells their version of the stuff now.
    https://www.harborfreight.com/8-piec...ods-44810.html
    Another apparent version of the same....
    https://selectrode.com/2111-a-rub-on...-without-flux/
    The rub-on aluminum solder I used is harder than regular aluminum but not stronger. The tensile strength value for the second of the two solders linked above is 35,000 PSI. Tempered 7075 aluminum is about 70,000 PSI while 6061 is in the low 40,000 range. For the applications I worked on the strength was never an issue as the parts were typically ornamental. Remember that this rub-on solder doesn't really melt the base metal, it's more like it tins the surface so if you need strength, TIG welding will generally be better.
    Doug L.
    '64 Morris Mini Cooper-S 1275
    '67 Triumph GT6 Mk1
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
