In line fuses
If I was considering putting in line fuses into my 100-6 wiring, what all should I fuse?
thanks!
John Turney
I have the following fused:
  • overdrive circuit
  • fuel pump
  • the five circuits that come from the 35-amp fuse are individually fused (the 35-amp fuse is now used for the fuel pump fuse).
You might also consider the tail lights and license plate light.
Keoke
Licence plate , Headlight's, driving lights if u have them installed.
longbridgehealey
Yep, got driving lights. Thanks, Keoke
RAC68
Hi All,
While you are installing in-line fuses, I suggest you make a list containing the circuit/component covered, the fuse amperage and, most important, the location of the fuse. Also, I strongly recommend that you also carry an updated copy of your fuse directory in the glove box along with 1 or 2 spare fuses of each amperage installed.
The beauty of in-line fuses is that they are installed into the covered circuit and, therefore, can be located anywhere. I have used in-line fuses extensively in my BJ8 to cover every critical circuit and key component...including my sound system. Although I have not had an issue causing a fuse to blow, I have pulled a fuse to deactivate/separate a circuit when addressing a circuit or component modification. This can also be helpful when experiencing a component anomaly/issue when on the road and needing to continue home.
One last thought. If I remember correctly, power for your headlights comes from your ignition switch and passes through your light switch and dip (high/low beam) switch before arriving at your headlights and (depending on how you have wired them) driving lights. Depending on the type of headlights installed, a substantial amount of amperage will be passed over very light wiring. If you haven't already done so, consider installing (3) relays to bring fused power to your headlights/driving-lights directly from your alternator/generator/voltage-regulator. This would allow a significant reduction in power passing through your original thin-wired circuits and components to that needed for switching the relays with an improved probability of extending circuit and component longevity and reliability.
Enjoy your Healey,
Ray(64BJ8P1)
John Turney
Hi All,
While you are installing in-line fuses, I suggest you make a list of containing the circuit/component covered, the fuse amperage and, most important, the location of the fuse. Also, I strongly recommend that you also carry an updated copy of your fuse directory in the glove box along with 1 or 2 spare fuses of each amperage installed.
Enjoy your Healey,
Ray(64BJ8P1)
Good points Ray.
When I installed the relays for my head and driving lights, I installed an auto reset circuit breaker to protect against shorts, but allow it to reset when the fault is gone. Wouldn't want to blow fuses in the dark.
longbridgehealey
Wow, this is a lot of great information, guys. Thanks a lot! More questions coming, I’m sure. Where best to place fuses, what size to use, etc. we’ve had this Healey on the road for over forty years, weathered two wiring fires, it’s time to give it some helpful upgrades!
RAC68
Hi John, Rick,
John,
Very good point. I was thinking of changing to a circuit braker but was wondering if it would be functional. If a short occured in the headlight power feed circuit (apposed to the switching circuit), I can see an automatic reset would be beneficial. Have you also install a circuit breaker on the relay's switching feed circuit as well?
Rick,
I fully agree. I was a recipient of a short in the rear license plate light that resulted from water penetration into the light housing when washing the car. The short caused the insulation of a few of the adjacent wires in the rear harness to melt and needed to be replaced with wire outside of the harness. After my experience, I discovered that BJ8 Phase 2s had a fuse originally installed but never heard anything about its presence or reason for its installation.
Ray(64BJ8P1)
Michael Oritt
thanks!
I'd recommend that you fuse as many circuits as you can and do so separately so the value of the fuse is not much more than about twice the anticipated maximum current draw, calculated by dividing the number of watts by the voltage. So the fuse for a lighting circuit for a 50 watt bulb in a 12 volt car should be around 10 amps. Bunching appliances together and powering them though one big fuse offers little more protection than a 16d nail and puts all the wiring at risk.
Though fuses are used to protect an appliance in case it develops some internal over-current situation they also protect the wiring leading to it which can be destroyed whether the fault is within the appliance or the wiring itself, such as when insulation is compromised allowing a current-carrying wire to contact a ground.
Locating a fuse as close as possible to the power source offers more protection to the circuit, or--put differently--that portion of wiring between the hot source and the fuse is unprotected from damage due to overloading and the wire itself becomes a fuse.
Lots to consider....
steveg
The Charlie Hart fuse block is a good thing to get started with - if he still makes them. It separates out the ganged green wires at the bottom of the regular fuse block. Uses the same mounting screws as the stock block.
hartcg:atmsn.com
Michael Oritt
There is a great article buy Steve Maas containing more than you may choose to know about fuses on John Sims' site at: http://www.healey6.com/Technical/Electrical Mods.pdf
It is Sprite-specific but as with so much LBC stuff the knowledge is directly transferable to Big Healeys as well.
Patrick67BJ8
hartcg:atmsn.com
I purchased one of his fuse blocks for my BJ8. It has six fuses. The difference between early and late big Healeys is the green wires are on the opposite side.
Patrick67BJ8
Interesting BJ8 version has 6 fuses while the older model has 7.
Addendum: Charlie Hart via email above, informs me he does still sell them. Needs to know for which model.
He also includes a wiring diagram with what size fuse goes with what circuit.
Keoke
Just remember resistive circuits lights use FAST BLOW fuses, while inductive circuits Motors & Solenoids use Slow Blow Fuses
NOTE:
We are dependant on the original designers to see that wire gauge and bundleling of wires in the harness are correct.
John Turney
Hi John, Rick,
John,
Ray(64BJ8P1)
Ray,
The control circuit is from a different source, and it has a fuse. The headlights, driving lights (and AC) are fed from a bus bar that comes directly off the alternator and starter solenoid.
Keoke
considering-Michael-Oritt Last post:
Where he mentions that the wire protects the FUSE You can Perform what is called a marriage , identical fuses are placed one at the power source and the other at the load. This adds a bit of complication but will generally solve the problem.
Michael-Oritt
the fuse is unprotected from damage due to overloading and the wire itself becomes a fuse.????
RAC68
Hi All,
Michael,
Thank you for the reference to Steve Maas's document. From my short scan of the article, it seems like a worthwhile read.
Keoke,
NOTE:
A very good point.
When viewing the gauge of wire used within the original harnesses, it is not hard to understand that they will not support today's common electrical component expansions. Additionally, the fact that original wiring (and insulation) hardens with age and furthers the risk of their ability to maintaining the complement of components originally designed to support. These factors justify why many of use have taken the approach of creating separate new wiring harnesses for all new electrical additions (fans, lights, sound system, etc.) and are trying to reduce to control functions any operational amperage draw through my original harnesses.
Thanks again,
Ray(64BJ8P1)
S In-Line Fuses Austin Healey 19
A TR2/3/3A Those round fuel line clips Triumph 2
E TR4/4A What Flare to put on a TR4 Brake Line Triumph 2
J TR2/3/3A Brake Line Flares Triumph 8
J TR2/3/3A Rear Fuel Line Clips Triumph 3
M TR6 Fuel return line Triumph 8
KVH TR4/4A Routing of TR4A Fuel Line Triumph 7
S TR2/3/3A brass fitting from a steel brake line Triumph 2
Walter74 Fuel Line Routing Austin Healey 7
B TR4/4A In-Line fuse 25 or 35 Amp? Triumph 21
K TR2/3/3A Fuel line routing from pump to carbs Triumph 7
D Fuel Line Clip vs Brake Line Clip Austin Healey 2
G TR6 Clogged fuel line Triumph 6
B Brake Line Pictures Austin Healey 1
KVH General Tech Brake Failure--The Line Split Triumph 19
petnatcar Fuel Line Upgrade Austin Healey 8
B TR4/4A Rear Fuel Line Routing IRS Triumph 5
D TR2/3/3A oil pressure line venting? Triumph 4
TomMull TR2/3/3A rear mount does not line up Triumph 10
R Bugeye oil pressure line Spridgets 9
TR6Canuck TR6 Wire spoke rims to fit Michelin Red Line Tires on TR6 Triumph 12
R TR6 Clutch Master Cylinder Hydraulic Line (Thread / Flare Type) Triumph 4
Geo Hahn TR6 TR6 Oil Line Thread Size Triumph 1
D TR2/3/3A rearmost fuel line question Triumph 5
MGTF1250Dave T-Series MG TF fuel line from tank to pump MG 3
JPSmit Fuel line - gas tank question Restoration & Tools 5
M TR2/3/3A Fuel Line Fitting at the Tank. Triumph 5
steveg TR6 Source for fuel line P-clip Triumph 17
Lin Brake hard line question Austin Healey 4
M TR2/3/3A Brake Line Removal From the Left Frame Rail Triumph 14
C TR2/3/3A Gas Line Triumph 11
R TR2/3/3A Brake Line Triumph 4
B TR2/3/3A Caliper brake line Triumph 10
Lin Healey assembly line - engine installation Austin Healey 19
Jim_Stevens TR2/3/3A Clutch slave hydraulic line Triumph 1
Lin Brake line fittings Austin Healey 2
M Vacuum Line on a 948 Spridgets 4
A TR2/3/3A how do i fix this hood line? Triumph 5
mctriumph Morgan drive line Other British Cars 2
T TR2/3/3A Can someone confirm size and thread count on fuel line tube nuts [brass fittings]? Triumph 16
Bayless What size fuel line for '67 Sprite? Spridgets 2
John Turney TR6 Brake Line to Front Calipers Triumph 4
dklawson General TR Fuel Line Routing Triumph 4
M TR4/4A Fuel Line Fittings - Stock or Upgrade? Triumph 6
Gliderman8 TR6 Removing Left Rear brake line... help! Triumph 9
D 62 tri-carb fuel line connection Austin Healey 10
FlyingCat Spitfire Brake line Triumph 8
M TR2/3/3A Oil Pressure Gauge Line Fitting Triumph 8
D TR2/3/3A Fuel line run from pump to carbs Triumph 5
