TR2/3/3A Disributor Points
karls59tr
Bronze
Took a look at the TR3 points today and saw that they were offset so that the two point faces were not meeting head on. What causes that to happen? Seems to me that only one edge of the point would only be sparking across the gap and that if they met face to face I would be getting more of a complete spark there. Are some point sets better than others and who sells the better ones?
TR3driver
Great Pumpkin - R.I.P
Sometimes, if they get hot, the plastic block can deform and cause that. I've also seen brand new points where the contacts didn't meet exactly.
Doesn't really make that much difference to the spark, although it might shorten the point life.
Sorry, no help on "better". I just run whatever TRF sells me, they seem to work fine.
CJD
TR points are pretty flimsy. I can usually work with them...bending the metal or monkeying with the screw...until they are square and aligned. Once aligned they seem to stay that way.
Geo Hahn
I always put a dab of lube on the cam to help the plastic block last longer. They used to give you a little capsule of lube with the points for just this purpose. I use assembly lube but other stuff may work as well or better.
C TR6 Seatbelt anchor points Triumph 2
L T-Series Back to org. points MG 3
P TR2/3/3A NO spark at points Triumph 36
drooartz Bugeye jack points to remove rear axle Spridgets 18
PAUL161 T-Series Points Triggering Electronic Ignition MG 5
WHT Late BJ8 Seat Belt Mounting Points Austin Healey 8
W Seatbelt Anchor Points Austin Healey 2
T TR2/3/3A bad napa points Triumph 9
steveg Points assembly order of washers Austin Healey 13
K TR2/3/3A Do Lucas distributor points still have the" Lucas logo" on them.... Triumph 4
K TR2/3/3A Aftermarket Distributor Points and Terminal Bush leads? Triumph 1
Michael Oritt Lube points on BN/BT7 front end Austin Healey 4
K TR2/3/3A What is the little white fiber thing for that comes in the Lucas points box? Triumph 2
K TR2/3/3A Up-date TRF points issues resolved. Triumph 0
2wrench TR6 Help with points and condenser on '74 TR6 -- or better, choices to get rid of 'em. Triumph 25
T TR2/3/3A tr3 points& condenser#'s Triumph 6
C MGB Attachment points MG 4
Jim_Stevens TR2/3/3A Sway bar attachment points Triumph 3
JFS TR2/3/3A Engine Removal Attachment Points Triumph 8
K TR4/4A Distributor Points and condensor insulating washers..... Triumph 14
Jim_Gruber Shift Points for Bugsys 948 w Cooper S Head Spridgets 3
R TR2/3/3A Ignition points Triumph 3
R Ignition points Austin Healey 21
doc50 TR2/3/3A Question about points. Triumph 6
C TR4/4A Sudden loss of points gap Triumph 10
B TR2/3/3A Vent cowl lid mounting points Triumph 3
dklawson General MG Which Pertronix? 45D with Red Points. MG 4
S Points versus Pertronix Spridgets 22
Michael Oritt MGB MGB gearbox identification points MG 1
C TR4/4A Burning through points Triumph 4
RedTR3 TR2/3/3A Best Ignition points set? Triumph 4
Jim_Gruber Seat Belt Mounting Points for a BE Spridgets 2
TomR 1978 MG Midget with Points Distributor Spridgets 4
AUSMHLY Pertronix or points Austin Healey 49
Lukens TR2/3/3A Distributor... going back to points. Triumph 8
HealeyRick BJ7 Door Seal Attachment Points Austin Healey 0
Jeepster BJ8 exhaust mounting points Austin Healey 17
S Original Lucas Points Austin Healey 4
Marvin Gruber New points problem Austin Healey 1
nevets Points failure - broken cam follower Austin Healey 3
K TR2/3/3A TR3 Dist points plate hold down screw size? Triumph 9
tri_carb_healey brake drum work, proper jack points Austin Healey 12
drooartz Pertronix back to points MG 28
lbc_newbie Best anchor points for shipping a Midget Spridgets 8
K Those who switched back to points from petronixx.. Triumph 64
G TR2/3/3A TR3 Grease points Triumph 11
PatGalvin TR2/3/3A Engine Harness and/or Attachment Points for TR3 Triumph 10
eschneider help - points / contacts inside wiper motor ?????? Triumph 9
Ken40 MGB-GT 67 B/GT unibody datum points MG 0
O TR2/3/3A Best jack points/location stands TR3 Triumph 4
