TR2/3/3A Inner sill or floor pan- which to replace first?
71TR6
Hello Forum,
After many unplanned delays, I'm ready to dive in again on my restoration of my '59 TR3A. Next week I plan to tearing into the final major body repair which is to replace the left inner sill, rear dog leg, and floor pan on my TR3A. There's not much left of the existing left floor pan and the inner sill is swiss cheese so I need to replace both. My instinct is to start with replacing the inner sill with the TRF replacement I have and then install the floor pan. My concern with putting the floor pan in first is that it really limits access to properly welding in the sill.
My question to the forum is: Is installing the sill first the best path or should I put the new floor pan in first and then do the inner sill?
Ron
CJD
Do all body work with the body on your frame, after measuring the frame to ensure it is straight.
The sill is the base for all the parts you mention, so it will have to be installed first.
The sill bolts to the outriggers on the frame using pads.
The a post and dog leg then weld to the sill.
The front kick panel and rear inner fender is next.
The floor can be saved until very last. All floor welds are easily accessible, if you look closely at them.
sp53
John showed me many ideas; he has a lot of experience. I would suggest posting some pictures, so the specifics of your car are clearer. I would also suggest removing the spots welds and leaving as much of the old sheet-metal as you can for a guide; you can always remove it later. For example, if your inner kick panel is kinda ok, either remove the spot welds with a dull faced rotary file, drill bits, or a spot weld removing tool. I suggest this because the inner kick panel sits on top of the inner sill providing a straight line for the sill, and if there are remnants of the old inner kick panel then visualizing the re-assembly is easier with less chance of being overwhelmed with parts and pieces floating in the air. The same goes for the last few inches of the floor because depending on the year the floor finishes off in 2 different ways at the very end. Good luck take you time and things will be fine.
steve
71TR6
71TR6
Thanks Guys! I appreciate the guidance. I tore into it yesterday and it was worse than I thought (isn't it always) so I need to do some B post repair as well. Here's some pictures--- the side of the inner sills look fine but the bottoms are completely gone.
charleyf
71TR6,
Actually your B post looks like it is mostly there in the picture. It is the sill that is "missing". You just need to work to protect the B post and remove the sill without removing any of the B post at the welds.
sp53
The inner sill is structural and the out sill is just a cosmetic tin cover. What does the whole outer look like behind the tin cover? And are both sides missing the last few inches of the inner sill.
K Link to pic of 4 inner sill install without floor? Triumph 0
Jim_Stevens For Sale New TR2-3A inner sill assemblies Triumph Classifieds 3
F TR2/3/3A Inner sill opinion Triumph 38
J TR2/3/3A Body Restoration - Inner Sill Replacement Triumph 38
J TR2/3/3A inner sill rust prevention Triumph 1
J TR2/3/3A Inner sill replacement procedure ? Triumph 5
Scot1966 For Sale New TR6 / TR4 passenger side rocker panel & inner sill -FREE- Triumph Classifieds 2
C Inner Sill Assembly Should i spend extra money on kilmartin brand??? Austin Healey 4
W Inner sill panels Spridgets 3
B TR2/3/3A Need advice TR3b inner sill replacement Triumph 16
M_Pied_Lourd TR2/3/3A TR3A Inner Sill Replacement Advice Triumph 7
M_Pied_Lourd TR2/3/3A TR3A Help with Resto Pics Please Front Inner Sill Triumph 19
O TR2/3/3A Help with TR3 inner sill removal - blind welds? Triumph 5
ekamm welding tr3a inner sill Restoration & Tools 2
M_Pied_Lourd TR2/3/3A TR3A Inner Sill Repair Question/Advice Triumph 95
K TR4/4A TR4A :Anyone have a pic of inner sill in place.... Triumph 2
F Inner rocker [sill] panels Spridgets 11
T TR4/4A TR4/6 inner sill replacement - body on/off frame Triumph 1
A TR6 TR6 B-post to inner sill connection Triumph 3
tr6web Outer and inner sill [rocker] installation Triumph 5
R Inner Sill, Which way ? Spridgets 2
J TR4/4A Strange Problem Fitting Inner Fender Triumph 18
D TR4/4A TR4 inner ball joints Triumph 8
R 2500M Inner Fenders - are they the same as a Vixen 2500? (Also Tire Size) TVR 3
SNClocks Gap between inner and outer fenders Spridgets 0
S TR2/3/3A Distributor vacuum advance hook up to the inner plate Triumph 9
M TR2/3/3A TR3 Small Mouth Inner Fender Holes Triumph 3
J Wanted WTB Triumph TR3 inner sills Triumph Classifieds 8
R GT6 GT6 Bearing Part Number Request (Front Axle, Inner Bearing)... Triumph 3
M BJ8 Inner Body Panel Repair Austin Healey 2
chicken Inner Door Seal Trim Position Austin Healey 6
S Inner Body Alignment Austin Healey 0
G 1962 TR3A inner plate # Triumph 8
rr64 Wanted Early MGB Inner Steering Track Rods Wanted MG Classifieds 1
K TR2/3/3A Inner tie rod ball joint. Triumph 6
M TR2/3/3A Front Inner Fender Doublers Triumph 2
F TR2/3/3A Front inner wing baffle measurement Triumph 7
wangdango BJ8 inner battery hold down? Austin Healey 4
K TR2/3/3A Front suspension inner Lower wishbone bush area? Triumph 3
Got_All_4 TR2/3/3A Inner tie rod ends Triumph 4
F TR2/3/3A Question: front inner wings Triumph 11
TAS525 TR2/3/3A Missing zerk from inner tie rod end Triumph 7
T TR2/3/3A Drive end of speedo inner cable to large for pinion Triumph 2
M For Sale 2006 Aston Martin DB9 - Get in Touch with your Inner James Bond Other British Classifieds 2
G TR4/4A Inner Door Reassembly Questions Triumph 4
aero3113 Front Hub Inner Bearing Seal Austin Healey 7
Feathers 289I inner tie rod end. TVR 0
D TR4/4A inner tie rod ball joint tension Triumph 0
F TR4/4A TR4 inner and outer sills Triumph 2
W TR2/3/3A Fabricating inner sills? Triumph 39
