TR2/3/3A Now the bad news. BRAKES
STeve 1958
My peddle is soft every morning and sometimes during the day. When I bleed the right front I get air every time. I've gotten to where I can bleed the one brake in about two minutes by myself. So I've done this every day for a week.
How do you think air is getting into the right front brake and how to stop it ???
glemon
Maybe air is getting past the threads of the bleeder valve, but I am not sure how you are doing the bleeding. Is the pedal firm right after you get done? How about if you wait a couple minutes? I am just trying to figure out if this is a trouble with bleeding problem or air somehow getting into the system after. I assume when youmention air in the right front that you are not getting bubble when you bleed at the other three corners. If it is occuring only in that corner and only post bleed look for a leaky caliper (sometimes hard to see, might need to take it off) or a leak in the line to the caliper, could be either the rubber line, steel line or any of the end fittings of the line.
Chuck Murphy
I had this same problem once. Turns out it was a bad seal in the MC. Seal was good enough to not let brake fluid out under pressure, but apparently sucked air in upon brake release and hence had air in the line the next time I used the brakes. Air always in right front caliper. Rebuild MC and air in caliper problem went away.
Chuck
CJD
Are the bubbles all in the right front...always? Are you certain they are not by the MC, so you have to bleed for a while to get bubbles, or are they immediate out of the right front?
If it is always right front, then you have excessive runout in the right front rotor. Either the hub is bent, the wheel bearing is bad, or the rotor likely needs to be shimmed. If the runout checks within limits, then the wheel cylinder needs to come apart to check for pitting in the bore/piston.
S
STeve 1958
I have the secondary problem of the brakes always being soft, first thing in the morning. One pump and they firm right up.
This would implicate the master cylinder. I see no fluid at any connections or on the right brake. Always bubbles at the right front, occasionally a bubble at the left front.
DavidApp
DOT 5?
I sometimes have a similar problem. Soft on the first application then OK. I am using DOT5 and considering trying pressure bleeding to see if that fixes the problem. I have replaced the MC as the one I replaced would not always return in a timely manner. It was a brand new MC put on the car at the same time as the clutch MC.
David
sp53
Sometimes a soft pedal occurs or will occur if the back brakes are not adjusted up tight. I am not sure what size brakes you have 10 or 9 inch. I find the 10 inch adjuster a little beefier. Anyways, the adjusters have to work smoothly and many times they are pitted on the cam lob and pointed cam adjuster. I also find a good quality wrench is important when adjusting because a smaller wrench will often come off at that last click that is needed to get the shoe tight enough in the drum to stop the excessive travel.
K TR2/3/3A Bad news...blown head gasket??? Triumph 15
Alfred E. Neuman TR4/4A Bad news on my TR4 Triumph 8
roscoe Good news/bad news Austin Healey 11
C TR6 Frame Pics, some bad news Triumph 9
gbtr6 TR6 Good news, Bad news Triumph 10
J Bad News 1098 Spridgets 14
regularman New midget good news and bad news Spridgets 16
M bad compression news Triumph 10
DNK Wedge Bad News Wedge Info Triumph 0
VelodromeRacer VSCDA Grattan bad news Racing 4
JPSmit I've got some good news and some bad news Spridgets 7
zimmy good news, bad news Spridgets 19
T TR4/4A Some good news and some bad news on the TR4 Triumph 5
healeyboz bad news Spridgets 70
eejay56 Bad news from the machine shop Triumph 12
Z Front suspension - good and bad news..mostly good. Spridgets 12
Taz d news bad news Spridgets 29
T Wedge Bad news on the TR8 Triumph 16
G Good News and Bad News Triumph 10
zimmy hey guys, im back w bad news Spridgets 11
tahoe healey Bad news Austin Healey 16
Steve Bad news for TVR Other British Cars 15
C bad news for MG 2006 MG 8
L good news, bad news? MG 25
Guinn Bad news. Not the donut. MG 5
TypeRboy Bad news on the BDA.. Lotus 8
bighly Very bad news [2 die in Healey rollover] Austin Healey 11
sim oil pressure gage bad or engine needs rebuild It starts our cold at 60 psi but when warm it down to 10 psi Spridgets 21
AUSMHLY Bad 1st Motion Shaft or Mainshaft Symptoms Austin Healey 13
P TR6 Bad Luck? Triumph 51
jlaird MGB Follow up to my bad post on prewar MGs MG 4
KiwiStagguy Re building my power steering 71 Stag . Rust and pitting bad . Need a business name to fix it Triumph Classifieds 0
T TR2/3/3A bad napa points Triumph 9
S TR2/3/3A How bad is this? Vertical link Triumph 12
D TR2/3/3A Bad parts. Triumph 16
charleyf TR4/4A Symptoms with bad condenser Triumph 14
AUSMHLY How to tell if a starter is going bad? Austin Healey 10
W TR2/3/3A Overheating Bad Triumph 12
Rut Help a bad memory out... Spridgets 6
Jim_Gruber Strange noises - Bad U Joint perhaps? Spridgets 10
M TR6 Fresh rebuild gone bad!!!!!!! Triumph 13
T TR5/TR250 Is it good or bad idea to grease an overdrive angle drive? Triumph 2
TR3TR6 TR2/3/3A Anybody else having a bad day! Triumph 31
S Is it a bad idea to buy a higher pressure radiator cap? Austin Healey 47
drooartz MGB Good people go to heaven, bad people replace MGB clutch hydraulics MG 2
JFS TR2/3/3A Bad Water Pump Triumph 11
P TR2/3/3A "MaXpeedingRods" con rods good or bad? Triumph 3
T TR4/4A Seems like a bad cylinder head or head gasket but what do you think? Triumph 19
D Removing servo . Good or Bad Austin Healey 12
PeterK TR4/4A Never seen a dual exhaust cobbed this bad before. Triumph 2
