TR2/3/3A tune up
STeve 1958
I was adjusting a few things on my car and, on someones advice, I advanced the timing to about 7 degrees before TDC. When I test drove the car I spun the wheels without trying. For the first time I had all the horse power I remembered from my youth. Lesson is that the advance under idle is unimportant compared to the advance under power.
Happy motoring !
Sarastro
Back in the dark ages, before everyone had a timing light, it was common to adjust the timing by advancing it a bit at a time, using that convenient little thumbwheel, until the car started knocking. Then back it off until the pinging stopped. Today we have different fuel and maybe different compression (since heads get shaved a lot during rebuilds) and the shop-manual timing spec isn't really gospel anymore. So, you can go back to the idea of experimenting a bit with it.
TR3driver
Great Pumpkin - R.I.P
The other problem is that the TR3 distributor had an advance curve that can start below idle rpm. So using a timing light may not be accurate.
I always use the "road test" method, but with the engine fully warmed up and slightly lugging (eg full throttle at 30 mph in 4th gear). Advance until you can just make it knock, then retard a degree or two (I like to go two just to be on the safe side).
CJD
Yep, the book gives an "initial" advance as a starting point...then it is very explicit in explaining how to perform the final adjustment with a road test.
pdplot
Sometimes the old ways are the best ways. I did the same on a TR6 years ago and picked up a lot of power with no knocking.
TR3driver
For those of you who use the driving test, is it easy to hear the engine knock?
I've never had any trouble at 30 mph; though it's best to do it in a relatively quiet area. (And I do have a moderate amount of hearing loss.)
Lou Metelko
Randall:
All part of listening to too many loud mouth race cars for too many years - ask me how I know!
Lou Metelko
Auburn, Indiana
CJD
You have to "tune in" to it. When you've heard it once, it is like nails on a blackboard after that. Not the sound...but your reaction to it.
karls59tr
Wasn't it lugging the engine in 4th gear what used to cause the crankshaft to break at the 4th journal? I guess "slightly" is the key word here.
TR3driver
As a rule (normal operation) it's best to avoid "lugging" (shift to a lower gear instead). But a brief test isn't going to hurt anything.
Breaking the crankshaft is normally associated with sustained high rpm operation, where the stresses on the crankshaft are much higher. Not just more power being produced (1500 rpm will only get you about 1/3 max power on a stock engine), but the greatly increased stress from having to stop and start each piston & rod assembly at the end of every stroke.
The TR2-4 crankshaft also suffers (according to Kas Kastner and others) from resonance effects. If you hang a bare crankshaft up and tap it lightly with a metal object, it will actually ring like a bell (this is an old-timer's trick for checking for cracks, a cracked crank won't ring). At various certain speeds, the impact from each cylinder firing can excite the resonance and, in effect, make it ring louder (more deflection). Added to the other stresses, it can flex the steel too far and eventually break it.
IIRC, Kas said that the first such danger point happens around 5200 rpm.
S
STeve 1958
5200 RPM is about 100 MPH in fourth gear. Not a good time to have a crank shaft break!
I keep mine under 3000 RPM at all times. Forty five years ago ( when I was invincible ) I had my 1960 TR3A up to 104 MPH. Never again.
CJD
Makes you think real hard before removing the stock extension and radiator fan. Those are the stock crank “dampers”.
RJS TR4/4A Tune Up Order - Fuel and Ignition Triumph 5
D Tune Up Trouble Austin Healey 24
4tecdog Stage 2 tune 1293 Spridgets 7
M Tune up / Maintenance question Spridgets 8
D My First Tune up Austin Healey 14
D TR6 '74 TR6 Tune up, oil, filters questions Triumph 3
DrEntropy MGB To th' tune of Sade's "Smooth Operator" MG 10
K TR2/3/3A Tune up refesh questions..... Triumph 1
S Best Top Down Tune Spridgets 36
J TR4/4A Making a '65 TR4 Run Awesome. Misfire, Ignition Tune Up, Carb Rebuilds. Help? Triumph 70
KVH TR4/4A I'm Trying to Tune, Again Triumph 4
C 65' 3000 Tune Up info/help for Prom? Austin Healey 3
bighealeysource Anyone have a good SU tune up article for BN2 Austin Healey 11
M 123 ignition tune mapping Austin Healey 0
toysrrus TR6 "NEW" TR6 Tune Up Parts For Sale in the Classified Triumph 2
JPSmit Italian Tune Ups and Ms Triss Spridgets 4
robdmau New to a Sprite, tune ups.... Spridgets 31
E TR6 TR-6 Tune Up Shop Recommendation Triumph 7
tr6nitjulius TR gets Dyno Tune Triumph 5
M TR2/3/3A TR3 Tune Up Triumph 16
Moseso A Tale of a Sunday Tune-up Triumph 13
dougie Test and Tune Racing 4
wkilleffer MGB What's the best way to tune an MGB? MG 19
Got_All_4 Used my Color Tune for the 1st time. Sweet! Triumph 10
B TR6 Another novice question re:TR6 tune-ups and chokes Triumph 9
B TR6 TR6 Tune-up guidance Triumph 14
D Tune-up Foul-up Triumph 37
G TR6 If anyone has had their TR6 on the dyno to tune Triumph 16
RickB Quick ? -Tune up tools -Craigslist - Timing light Spridgets 9
B Bugeye won't start after tune-up Spridgets 17
B Tune up sequence??? Spridgets 9
RickB MGB-GT Starting tune up of my 70 BGT MG 24
Editor_Reid AH 100 Tune-Up Cost Austin Healey 5
BritCarFan A/C could use a tune-up, I think Jaguar 6
M Tune up Triumph 1
AUSMHLY The next project...the tune up Austin Healey 15
R Electrical tune up Q's Triumph 8
Paul Slice Changed my tune....... Triumph 2
I TR6 69 TR6 tune up tips Triumph 15
Mark_Gibson TR6 Tune Up Tips for TR-6 Triumph 14
B new member 5.7 tune port in a 7 series bmw? Other British Cars 13
Nunyas oooooooo... aaaaaaaahhh... How to Power Tune... MG 11
J Zenith Stromburg 175 carburator tune? Other British Cars 3
Patton Tune up to isolate a Low Power problem Austin Healey 2
C tune up time Triumph 3
X Dyno/tune social Jaguar 4
T Color Tune Restoration & Tools 9
Basil Color Tune Restoration & Tools 7
