Ozone generator - cigarette smoke smell in car?
NutmegCT
I wondered if anyone has used an ozone generator successfully to eliminate odors inside a car.
I've read several online articles on using them for air purifying and "freshening" - but so far nothing on how effective they are for odors in car carpeting, upholstery, headliner, "behind the dash", a/c ducts, etc.
Thanks.
Tom M.
LarryK
I gave my Step-Mom one to put in her Mercury as Dad smoked heavy. She said it worked. If you aren't driving the vehicle for a few days, pour vinegar in a wide mouth jar and set in a pie pan on the floorboard, clears smells in a few days. Friend of mine who owned a body shop did this on impound towed cars. Knew bot to clean blood out too.
NutmegCT
NutmegCT
LarryK
It plugged one into the cigarette lighter, wasn't real big. Been a while, don't remember where we got it. And wasn't expensive back then. Might be at Dollar General or Walgreens now, might be at WallyWorld.
AngliaGT
I've used ground coffee.Spread it in a thin layer all around
the vehicle,then vacuum it up later.Do this on a hot day,with the windows rolled up.
NutmegCT
NutmegCT
Thanks gentlemen. I'd heard about the coffee grounds method, but didn't know about spreading it all around the car.
Stupid question: are the grounds *used* grounds? or ground coffee out of a can?
(Also, still can't quite believe that *anything* would eliminate odors in the a/c duct system, or in the upholstery.)
LarryK
Coffee would smell better than mold. Anything sitting long enough in a car that has a smell will be absorbed by the upholstery, vinyl, mats, carpet and headliner. That being, coffee would work and vinegar, another natural smell remover.
AngliaGT
Out of the can.I bought a 2003 Dodge Dakota from a
heavy smoker,& used ground coffee.After a short while,the smell was completely
gone.
I also used it on the Dakota I just bought,but made the mistake of using
most of a large can of cheap coffee.The smell was a little overwhelming for a while,
but very slight now.
martx-5
I've used the ground coffee method. I just put it in a large cup and drove around with it in the cup holder for a couple of weeks. The smell of the coffee was actually nice. It got rid of all the cigarette smell.
PC
The machines that actually work well are expensive. Hard to justify unless you're using them professionally.
For a consumer product, there are odor "bombs" that flood the space with neutralizing chemicals. They do unfortunately tend do add scents too.
PC
Here are a couple of pretty thorough vids on ozone machines. (The technique parts are fairly decent. Ignore the "sciencey" parts. He ain't no scientist.)
MGTF1250Dave T-Series Lucas Generator MG 1
P Generator to Alternator Swap Austin Healey 2
W Generator or Alternator? Austin Healey 18
T Spitfire MK2 Generator Triumph 3
W Generator and Starter Long Bolts Spridgets 0
DrEntropy MGB Generator to alternator swap MG 1
M TR2/3/3A Generator Warning Light on with the Alternator Charging the Battery Triumph 4
B Generator Parts Austin Healey 6
P BN4 Generator Woes Austin Healey 7
K TR2/3/3A Can anyone confirm that if you replace the ammeter with a voltmeter ( generator removed and alternator added) that you...... Triumph 5
K TR2/3/3A Red ignition light stays on...car has alternator not generator. Triumph 17
TR3MT TR2/3/3A Generator Output Triumph 18
Dnickels Spitfire Generator fan rubbing/scraping Triumph 3
AUSMHLY Generator to Alternator Swap Austin Healey 20
AUSMHLY Lucas Generator C42 End Caps Austin Healey 3
vette Need BugEye Generator Austin Healey 7
vette Need BugEye Generator Spridgets 4
S For Sale Early Sprite & Midget Speedometer/Tachometer/Generator etc. Spridgets Classified 2
Merlin63Tr4 TR4/4A Alternator or alternator in a generator case? Triumph 4
J Wanted WTB TR 3-4 Generator pedestal Triumph Classifieds 3
S TR2/3/3A Generator Pulley Bolt Removal Triumph 12
O Generator Question Austin Healey 2
TAS525 TR2/3/3A Brand New Generator Low Voltage Triumph 25
K What to do for coil bracket on upgraded generator? Austin Healey 8
R TR2/3/3A generator to alternator Triumph 5
M Difficult Electrical Problem in 59 BE with Generator Spridgets 6
T New Generator Mystery Austin Healey 5
I Bugeye generator/alternator conversion question Spridgets 7
S TR2/3/3A no leaks, but the generator is not charging Triumph 45
R TR2/3/3A TR-2,3 Generator Pic showing all attachments Triumph 5
doc50 Mash Metropolitan Generator testing Other British Cars 1
S TR2/3/3A generator red light deal Triumph 6
J advice on a 3 brush generator please C45N-3 Other British Cars 0
5 Tach Drive Generator for a Bugeye Spridgets 2
M Jaguar XK Special Equipment Generator Jaguar 1
T C42 BJ8 generator long screw needed Austin Healey 2
Magyar Generator going on the fritz Spridgets 3
Rhodyspit75 Generator pulley diameter Spridgets 2
A Wanted WTB Generator pulley & fan Austin Healey Classifieds 2
Rut Bugeye generator color Spridgets 22
CJD TR2/3/3A Generator and other Odds Triumph 6
G TR4/4A New Generator vs Alternator vs BPNW Alternator/Generator Triumph 13
R TR6 Generator to alternator conversion Triumph 6
2billydavies TR2/3/3A generator doesn't appear to be working Triumph 7
2billydavies TR2/3/3A dead battery, generator, belt Triumph 13
K TR4/4A Generator bench testing..... Triumph 6
G Generator - Key Replacement Austin Healey 6
T For Sale Free tr3 transmission radiator and generator Triumph Classifieds 2
D TR4/4A two questions- converting generator to alternator and breather cap query Triumph 17
NutmegCT Generator symptoms Other Cars 15
