100/6 Radiator cross member
Guy Marshall
Hi all,
I replaced my water pump and noticed a very shabby repair on the front yoke that supports the bottom of the rad.
The left side of the yoke has been reattached a good inch behind where it should be. It does not seem to do much other than support the radiator, but has anyone had any experience with this sort of repair?
Also the brackets that attach the radiator to the yoke are so short that the brace is tight up against the back of the radiator which must inhibit air flow. Has anyone extended/bushed the brackets to allow more air gap?
Thanks for any thoughts...
Hate to say it, but it looks to me that the 'yoke' needs to be replaced. A good welder can probably do it.
Is that electrical tape on the steering column, by the box?
Has the "X" brace also been cut loose at the bottom__I mean, it sure looks like it is...
attachment.php
I see too that it has a later model steering box, so I'm guessing most of this stems from a previous encounter with a solid, stationary object?
The bottom of the radiator on my 100/6 is also right up against the xmbr, though there are some holes in it for the air to pass through. This picture shows a 3000 MKIII.
G
Guy Marshall
Thanks all,
Yes, I suspect all the damage stems from a previous accident - before my time. I suspect driving an Austin Healey may not be the best place to have an accident involving the steering column. Thanks for the advice re the radiator Randy. Mine has the holes too though they were full of stones. Great to find that rattle! It would seem a simple mod to move the bottom of the rad forward a bit to allow more airflow. Has anyone seen that done?
The cross brace has been "modified" (I suspect to fit the old BMW thermo fan a PO had added) so that will need replacing/repairing at the same time.
There is a turn of electrical tape on the bottom of the steering column - well spotted, Bob. No idea why its there. I hope its not keeping the column together!
Probably to stop/suppress/hide a leak. The column is sweated (soldered) into the box, and they've been known to leak over time (not usually as bad as the front plate, olive or seal on the rocker).
Healey Nut
The 64 I just finished had the ultimate bodge job on the front X member . It had been cut out completely I assume to do timing chain etc without removing engine .
Then they patched some crappy brackets in place over the cuts and put bolts right through it all .
Needless to say it got done right during the restoration
N 1953 100-4 oil in the radiator fluid Austin Healey 15
Michael Oritt Looking for a good 100 crankshaft Austin Healey 2
56HealeyDan 100-4 Front Crankshaft Seal Austin Healey 2
A 100/6 BN4 Restoration Austin Healey 4
Editor_Reid Healey 100 Frame Diagram Austin Healey 1
A 100/6 BN4 Door Lock Austin Healey 15
R 100-4 Transmission Austin Healey 1
W For Sale Selling 1958 100-6 w/ hardtop Austin Healey Classifieds 4
R Healey 100 Dipstick Stuck Austin Healey 12
T 100 BN2 Possible Ignition Issue Austin Healey 7
T For Sale New Premium Water Pump for 100-6 Austin Healey Classifieds 0
3 100 Clutch Freeplay Austin Healey 7
E For Sale Austin Healey 100 and 3000 parts Austin Healey Classifieds 1
R Big Healey 100 Head Austin Healey 4
G For Sale 100 Year Grille Badges Other British Classifieds 3
Guido36 Webers on a Healey 100 Austin Healey 6
R For Sale 100 engine block w/head Austin Healey Classifieds 3
kodpkd For Sale Alloy valve cover for AH 100-6 3000 PRICE DROP! Austin Healey Classifieds 1
A SOLD!! 1959 100-6 Austin Healey Classifieds 0
dougie '56 100-4 Racer For Sale Austin Healey 12
longbridgehealey SOLD!! 1957 100-6 BN-4 Austin Healey Classifieds 0
longbridgehealey Letting the 100-6 Go Austin Healey 26
P Wanted Wanted: Healey 100-4 frame Austin Healey Classifieds 4
M For Sale Austin Healey 100-4 Lemans Kit OEM Austin Healey Classifieds 5
A 100-6 Brake Lights Austin Healey 2
prb51 100-6 Brake Master Cylinder Bore Austin Healey 5
C What to do with my late father's Healey 100 Austin Healey 5
P 100/6 Front Wheel Alignment Austin Healey 10
andrea 100-Six Photo Album Links Austin Healey 1
prb51 Wanted Wanted...hardtop for 100-6 BN 6 2 seater Austin Healey Classifieds 1
prb51 100-6 Drum Brakes Austin Healey 9
S 1958 100/6 Bumper Brackets Color Austin Healey 2
S Wanted Used Austin-Healy 100/100-6/3000 Restoration Guide By Gary Anderson And Roger Moment Austin Healey Classifieds 14
Michael Oritt 100 Flywheel Weight Austin Healey 16
healeynut For Sale 100/4 block and head Austin Healey Classifieds 1
boxofparts 100-4 Engine Options Austin Healey 12
BoyRacer 6 cylinder flywheel on a 100 engine? Austin Healey 0
K 100-6 Interior Austin Healey 4
56HealeyDan 100-4 Timing and Vacuum Austin Healey 5
K 100-6 Exhaust Front Mounting Bracket Austin Healey 2
C Wanted Austin Healey BN2 100-4 Austin Healey Classifieds 2
R 100 Motor and Gearbox Available Austin Healey 2
B Austin-Healey 100-6/3000 Electrical Drawing Austin Healey 2
B Austin-Healey 100 BN2 Electrical Diagram Austin Healey 0
B Austin-Healey 100 BN1 Electrical Diagram Austin Healey 0
K For Sale TR3 front passenger side fiberglass floor panel.....$100 CAD OBO plus shipping. Triumph Classifieds 3
C For Sale Parts, Factory Manual, Restoration Guide for 1959 100-6 Austin Healey Classifieds 4
T 100-Six Clutch Recommendations Austin Healey 5
J Owners of my 100-4 Austin Healey 1
andrea AH 100/6 1957 Longbridge Photo Albums Austin Healey 5
