Results 1 to 7 of 7
Thread: 100/6 Radiator cross member
  1. #1
    Join Date
    Apr 2018
    Location
    Ferrussac, Tarn et Garonne
    Posts
    15
    Thanks Thanks Given
    Thanks Thanks Received
    Thanked in
    Hi all,
    I replaced my water pump and noticed a very shabby repair on the front yoke that supports the bottom of the rad.
    The left side of the yoke has been reattached a good inch behind where it should be. It does not seem to do much other than support the radiator, but has anyone had any experience with this sort of repair?
    Also the brackets that attach the radiator to the yoke are so short that the brace is tight up against the back of the radiator which must inhibit air flow. Has anyone extended/bushed the brackets to allow more air gap?
    Thanks for any thoughts...
  2. #2
    Yoda John Turney's Avatar
    Join Date
    May 2002
    Location
    Concord, CA
    Posts
    3,985
    Thanks Thanks Given
    78
    50
    Thanked in
    Re: 100/6 Radiator cross member
    I think that front yoke is supposed to add stiffness to the front suspension. The bracket looks normal.
    John, BN4
  3. #3
    Join Date
    Feb 2007
    Location
    California USA
    Posts
    4,233
    Thanks Thanks Given
    5
    66
    Thanked in
    Hate to say it, but it looks to me that the 'yoke' needs to be replaced. A good welder can probably do it.
    Is that electrical tape on the steering column, by the box?
  4. #4
    Yoda Randy Forbes's Avatar
    Join Date
    Feb 2003
    Location
    SW Florida (Sarasota/Bradenton area)
    Posts
    4,534
    Thanks Thanks Given
    12
    41
    Thanked in
    Has the "X" brace also been cut loose at the bottom__I mean, it sure looks like it is...
    I see too that it has a later model steering box, so I'm guessing most of this stems from a previous encounter with a solid, stationary object?
    The bottom of the radiator on my 100/6 is also right up against the xmbr, though there are some holes in it for the air to pass through. This picture shows a 3000 MKIII.
    http://www.britishcarforum.com/bcf/image.php
    57 Healey BN6L-942 Wine Red/Honey Tan
    99 BMW M Coupe EB w/ ES/TS & 99 M Rdstr BK/BK
    01 BMW M Rdstr Steel Gray Performance Center (factory) Delivery
    16 X5M/DINAN Stg II Mineral White Metallic Wife's 716 hp/702 Lb-ft Turbo Hauler
  5. #5
    Join Date
    Apr 2018
    Location
    Posts
    15
    Thanks Thanks Given
    Thanked in
    Thanks all,
    Yes, I suspect all the damage stems from a previous accident - before my time. I suspect driving an Austin Healey may not be the best place to have an accident involving the steering column. Thanks for the advice re the radiator Randy. Mine has the holes too though they were full of stones. Great to find that rattle! It would seem a simple mod to move the bottom of the rad forward a bit to allow more airflow. Has anyone seen that done?
    The cross brace has been "modified" (I suspect to fit the old BMW thermo fan a PO had added) so that will need replacing/repairing at the same time.
    There is a turn of electrical tape on the bottom of the steering column - well spotted, Bob. No idea why its there. I hope its not keeping the column together!
  6. #6
    Join Date
    Feb 2007
    Location
    California USA
    Posts
    4,233
    Thanks Thanks Given
    5
    66
    Thanked in
    Quote Originally Posted by Guy Marshall View Post
    Probably to stop/suppress/hide a leak. The column is sweated (soldered) into the box, and they've been known to leak over time (not usually as bad as the front plate, olive or seal on the rocker).
  7. #7
    Jedi Knight Healey Nut's Avatar
    Join Date
    Sep 2013
    Location
    Ottawa Ontario
    Posts
    1,268
    Thanks Thanks Given
    3
    16
    Thanked in
    The 64 I just finished had the ultimate bodge job on the front X member . It had been cut out completely I assume to do timing chain etc without removing engine .
    Then they patched some crappy brackets in place over the cuts and put bolts right through it all .
    Needless to say it got done right during the restoration
    "If it aint broke ....dont fix it "
    " Thats not an oil leak ..........its a special automatic British rustproofing system "
    Best Healey in show ABCD Ottawa 2013
    Best Healey in Show Boot n Bonnett Kingston 2013
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
