up or down?
Sopwith_Camel
Can I drop just the Transmission out the bottom of a 67 340 (mk2)
LarryK
If you can reach the upper bolts and the bell housing will move back far enough to clear firewall. If not careful will crush rear oil lines on back of head, speedometer connection, vacuum line mount. I have never removed just trans. Easiest if a 4-speed was installed in an automatic car, as the auto housing is wider than the stick.
Deleted member 8987
no. I mean, like Larry said...you will damage all sorts of stuff trying to drop the engine low enough in the back.
Then the tunnel isn't wide enough to get the bell back far enough to clear the input shaft from the clutch plate.
Now, if the floor section could be removed with the narrow bits at the sides, and the top of the firewall above the removable tunnel, maybe.
On mine (2.4L so shorter height block, even) I looked...closely....decided to pull engine and trans (and they do come out the top, but it is still a royal PITA. Glad I did, as the engine needed serious going through (knew head gasket, but needed it all).
Sopwith_Camel
Sopwith_Camel
I have the Borgwarner 35 Tranny.
steve
Deleted member 8987
ah. No idea. Still, does it have the 3" studs out the back of the block? Can you get the tork converter unbolted from the flexplate?
Than, maybe, back two inches and drop straight down.
What does the owner's manual say?
Sopwith_Camel
Sopwith_Camel
the bogwarner is in a supplemental appendix not the stander shop manual
Deleted member 8987
I know it is in the parts indexes. I'll czech my Shop Manual later today, see what it says.
Sopwith_Camel
Sopwith_Camel
thanks
Deleted member 8987
I went through my official MKII Jag shop manual. While it mentions automatics, there is no provision for a supplement for same.
I have all sorts of included supplements, overdrives, power steering, various carbs....the only thing it says is to remove a gearbox the engine and trans must be removed from the vehicle.
Sopwith_Camel
Sopwith_Camel
ok good to know.
thanks
steve
Deleted member 8987
and then....da google....several spots where folks have dropped (numerous times) a MK2 auto box out the bottom.
One of the tricks seems to be to fully remove front motor mounts to drop engine enough to access upper bell bolts, but not sure.
Me? Hard enough to pull mounts then get up above and yank it all out the top.
Can't imagine at this stage in life doing all that under the car.
Sopwith_Camel
Sopwith_Camel
Ahh great i will tell my guy.
I just got a job offer, so that will complicate getting the car done.
steve
Sopwith_Camel
Sopwith_Camel
ok trying to get this all back together, the inner bearing shims on the diff are not a valible and mine are worn. looks like if we go from a 7.5 shim on the exteranl U joint up to a 8.5 to take up the Laderal movment will that be a problem?
steve
K TR2/3/3A Pushing down the clutch pedal when starting the car? Triumph 13
Patrick67BJ8 Traced down that elusive exhaust leak! Austin Healey 5
sim oil pressure gage bad or engine needs rebuild It starts our cold at 60 psi but when warm it down to 10 psi Spridgets 21
Got_All_4 TR6 TR6 Down Pipe How They Last Triumph 6
K TR2/3/3A RE: Pulling the choke knob all the way out....the carb jets should be down how far? Triumph 5
AngliaGT RB Midget - Finally tracked it Down! Spotted 3
M MGC New book: MGCs Down Under MG 0
shadowfever Shake down run Spridgets 2
TheRealDestrux MGB 1977 MG MGB need help putting top down MG 1
K TR2/3/3A Steering Wheel hold down Nut Triumph 6
Busted knuckles TR2/3/3A Engine tear down, Triumph 13
Rut Cut down windshield Spridgets 22
S TR2/3/3A trim to hold down the furflex Triumph 3
D TR2/3/3A stator tube will not go down Triumph 0
K Austin-Healey Fold-Down Windscreens Austin Healey 27
D Lotus Elan S4, From water pump...to a strip down.. Lotus 2
DrEntropy Diesela won't go down... Other Cars 5
C TR2/3/3A Triumph Tr2 Down Under Triumph 2
A Spitfire Spitfire Ride Down The Mountain - Vermont Rt 100 Triumph 12
wangdango BJ8 inner battery hold down? Austin Healey 4
Got_All_4 TR6 Starting The Tear Down Of MY 1969 TR6 Triumph 6
G Supplier rant from down under Austin Healey 12
RAC68 Cost of Cutting Down an American Rear Austin Healey 12
edkap2002 TR6 Issue of the day......restart and idle after shut down Triumph 21
M Hauling a Spridget - Proper tie down technique? Spridgets 15
A Spitfire Here's Our latest Newsletter.. Scroll Down -Many Tech Sessions Images Triumph 0
PatGalvin TR2/3/3A Scraping Down Under Triumph 18
Patrick67BJ8 Brake Pedal Vary Hard to Push Down and Brakes feel like there's no Booster on my BJ8 Austin Healey 27
GTP1960 Drive down memory road. Other Cars 14
AngliaGT MGB When the MGB is Down..... MG 1
KVH General Tech Leak Down Test Triumph 17
aero3113 100 hard top with windshield folded down. Austin Healey 4
N Wire wheel hub removal & suspension tear down Spridgets 3
simon1966 BN1 Strip down well under way Austin Healey 5
mcmillal TR4/4A TR4 suddenly shuts down Triumph 25
SherpaPilot TR6 Engine Will Not Shut-Down Triumph 4
PC the fire down below Spotted 7
S Best Top Down Tune Spridgets 36
KVH TR4/4A Long Speedo Cable for Overdrive--where does it get tied down? Triumph 7
R Tracking down my dads old Austin Eight Other British Cars 3
healeydan Windshield Seal Won't Lie Down Austin Healey 3
Jeepster BJ8 exhaust down pipe gaskets Austin Healey 6
S rear fold down seat Austin Healey 4
HealeyRick Down East Dickering Midget Spridgets 4
jlaird Miss Agatha jumping up and down Spridgets 0
JPSmit Brisk Top Down Motoring Spotted 1
tomshobby Shake down tour Spridgets 6
K TR2/3/3A A cut down side curtain for Fall driving? Triumph 7
P TR6 Can't leave top down Triumph 10
jlaird Tie down Spridgets 0
