BJ7 Window channel position
grimes6
I am just in the process of fitting the frame to my windows on my BJ7 . The window channel is not attached and I need to know its position on the bottom frame. Attached is the channel in question.
Many thanks
Greg
vette
If my memory is near correct, this piece has some adjustability to it. It is tapped unto the bottom metal frame of the window glass. put the window either all the way up or all the way down and see where the arm and this pieces meets it. this piece can be moved horizontally somewhat to get perfect actuation of the glass. the object is to get the window to travel its complete travel without the sliding arm coming free of this piece. May be some trial and error to get it right.
Hope this helps a little.
HealeyRick BJ7 Side Window Alignment Austin Healey 31
T Early BJ7 Vent Window Seal Austin Healey 2
AUSMHLY BJ7-BJ8 outer weather strip for door window Austin Healey 4
G Early BJ7 rear window fittings Austin Healey 2
B New Window Seal for BJ7/BJ8 Roll Up Windows Austin Healey 1
healeydan BJ7/BJ8 Vent Window Corner Block Austin Healey 13
AUSMHLY Window Regulator BJ7 vs BJ8 Austin Healey 26
B BJ7/8 side window glass Austin Healey 6
chicken Window winder mechanism BJ7 Austin Healey 15
M BJ7 rear window ["backllight"] Austin Healey 0
J BJ7 - Removing Door and Window Cranks Austin Healey 21
5 WTB: BJ7 Squab Austin Healey 13
5 BJ7 Boot Rust-Through Austin Healey 13
B For Sale Too many Healeys - BN2, BN4, BT6, BJ7 For Sale Austin Healey Classifieds 0
Walter74 BJ7 Throttle Linkage "Support Panel" Austin Healey 5
T BJ7 Trim Recession (Convertible Top) Austin Healey 2
ModifiedBJ7 BJ7 Windshield Surround Rubber Seal Austin Healey 2
R New Hood for BJ7 Austin Healey 3
chicken BJ7 Chrome Trim Austin Healey 15
JMACENGINESHOP BJ7 Engine Rebuilding Austin Healey 23
R BJ7 Rear Axle Maintenance Austin Healey 5
B Wanted Grill Top Cowl and Surround - BJ7 Austin Healey Classifieds 1
R Changing BJ7 Differential Ratio Austin Healey 10
X Trouble shooting trafficator - 1963 BJ7 Jaguar 9
T BJ7 Hard to find First Gear when G/Box is hot Austin Healey 3
B BJ7 Rear View Mirror Mounting Hardware Austin Healey 7
chicken BJ7 Door Fit Austin Healey 27
T Wanted BJ7 parts needed Austin Healey Classifieds 0
T Weight of BJ7 Transmission/Overdrive Austin Healey 10
D BJ7 Clutch Austin Healey 6
R BJ7 Back Seat-Rest Austin Healey 1
HealeyRick BJ7/8 Convertible Top Issues Austin Healey 5
B BJ7 Interior Finishing Details Austin Healey 2
chicken Healey BJ7 door (i think) Austin Healey Classifieds 0
chicken BJ7 Rear Number Plate Mounting Austin Healey 3
chicken BJ7 Door Seal Austin Healey 5
chicken BJ7 Rear Quarter Panels Austin Healey 6
B BJ7 Boot Trim Austin Healey 7
D BJ7 Underdash Trim Austin Healey 9
G Steering Arm Installation Recommendations - BJ7 Austin Healey 2
D BJ7 Rear rail trim Austin Healey 0
D BJ7 Hood frame mounting plate Austin Healey 7
D Wanted BJ7/8 front grill top cowl Austin Healey Classifieds 4
BLong63AH BJ7 Hard Fuel Lines Austin Healey 20
T Spin-On Oil Filter Removal [BJ7] Austin Healey 12
T Installing Garmin GPS in a BJ7 Austin Healey 19
pbraun How much does a BJ7 or 8 transmission weigh? Austin Healey 3
P BJ7 Upholstery Austin Healey 1
B BJ7 back end rebuild Austin Healey 1
