TR6 Brake Line to Front Calipers
John Turney
I've got some Girling type 16 PB metric TR6 front brake calipers. They are mounted on my Austin-Healey 100-6, and were supplied with custom flex lines that have a tendency to kink. I want to use the TR6 flex lines, which would have a smoother route.
There is a short rigid pipe, hose to caliper, metric thread, Moss 588-555. One end of this rigid pipe obviously screws into the caliper. Is this pipe supported anywhere else along its length to keep it from flexing? If so, how?
Thanks!
Tybalt
There is a small "L" shaped bracket that attaches at the upper caliper mounting bolt for the solid line from the caliper to the flex line attachment. Note that only the fitting for the caliper is metric, the end that attaches to the flex line is Unified/SAE threads. Moss part number 582-165 or Triumph/Roadster Factory part number 141124 for the bracket.
ed_h
Is this the pipe?
R Help with BJ7 front brake line routing Austin Healey 6
T TR2/3/3A TR3 front brake line routing Triumph 3
Trevor Jessie Front brake line locating brackets [disc]. Spridgets 6
jhorton3 Front Brake Line Clips Spridgets 8
jhorton3 Front Left Brake Line Spridgets 9
E TR4/4A What Flare to put on a TR4 Brake Line Triumph 2
J TR2/3/3A Brake Line Flares Triumph 8
S TR2/3/3A brass fitting from a steel brake line Triumph 2
D Fuel Line Clip vs Brake Line Clip Austin Healey 2
B Brake Line Pictures Austin Healey 1
KVH General Tech Brake Failure--The Line Split Triumph 19
Lin Brake hard line question Austin Healey 4
M TR2/3/3A Brake Line Removal From the Left Frame Rail Triumph 14
R TR2/3/3A Brake Line Triumph 4
B TR2/3/3A Caliper brake line Triumph 10
Lin Brake line fittings Austin Healey 2
Gliderman8 TR6 Removing Left Rear brake line... help! Triumph 9
FlyingCat Spitfire Brake line Triumph 8
RAC68 Hard Brake Line Compound Opinion/Recomendation Austin Healey 8
Vineyarder Austin Healey 100-4 brake line fittings Austin Healey 10
Rut Brake line routing Spridgets 21
AngliaGT '74 Midget - Best way to Replace Brake Line? Spridgets 1
M TR4/4A 67 TR4A, need brake line fitting specs Triumph 6
M Brake Line Lengths Austin Healey 1
J TR2/3/3A Spring loaded valve in the top of the 4 way brake line fitting? Triumph 3
Rut MGB Need some brake line clips? MG 9
J Brake line material Austin Healey 24
J Brake line pipe Other British Cars 5
DornTRoriginal TR2/3/3A Installation of Brake Line Clamps on Real Axel Triumph 1
PatGalvin TR2/3/3A Hard Brake Line Flaring Question Triumph 11
AHS TR2/3/3A Disc brake line routing Triumph 0
T TR2/3/3A brake line replacement Triumph 11
DornTRoriginal TR2/3/3A Hydraulic Brake Line Clips Installation Triumph 2
C Vacuum line routing for brake booster Austin Healey 5
M Brake line kits Spridgets 28
D TR6 76 TR6 Rear Right Brake Line Triumph 8
mgedit TR2/3/3A Brake Line Master to Banjo Connection LHD 56 TR3 Triumph 4
R Brake line nipple size Triumph 4
Tugboat TR2/3/3A TR3A Brake Line Triumph 2
J TR2/3/3A Brake line advice for my TR3 Triumph 5
luke44 Clip - Brake Line to Firewall Triumph 3
M TR6 Where does this TR6 brake line go?[pic] Triumph 3
W Off to the local shop... brake line bleeding Spridgets 2
W Problems!! Brake line bleeding and leaks Spridgets 5
D Brake line flush Austin Healey 13
T Wiring Harnress and Brake Line Routes Austin Healey 11
E BE Dual Brake Line Switch Assembly Spridgets 0
E BE w/dual line brake master....90 degree fitting? Spridgets 12
K brake line flares Spridgets 9
letemglow Brake line layout with dual master cylinder MG 6
