TR2/3/3A 'A' type Front calipers, TR3 vendor???
bwest
I noticed a leak from the bleedscrew on my front caliper, I'd used a heli-coil to repair
some bad threads years ago,, but unfortunately a recent conversion to
silicone fluid ( and subsequent brake bleeding) resulted in a small but persistant leak.
None of the major vendors seem to stock these, and it's prime drive season so an
elaborate swap to Toyota (or others) calipers would chew up valuable driving time.
It's unlikely that I'd be able to get a core credit ( because of the helicoil repair) so
does picking up a 'cheapie' on Flea-Bay and having someone ( WhitePost perhaps?)
rebuild it seem like the best path?
thanks
BW
TR3driver
Great Pumpkin - R.I.P
TRF seems to have rebuilds in stock; core charge is only $50 if they refuse your core. That's the way I'd go, if I couldn't fix the bleed screw myself.
Or, if you just want to get back on the road ASAP, I might try dropping a suitable bearing ball into the hole, and running a bolt down on top of it. Messy to bleed, but a very good chance of sealing. If it doesn't seal the first time, use a punch and BFH to tap on the ball, to form a new seat in the caliper.
B
bwest
Just contacted TRF, they didn't show any calipers on the website, and 'Chuck' at TRF confirmed they don't sell
them. Used to,,, but they closed the rebuild shop so,.... ugh...
Any other suggestions? I'm amazed that a part like that would be un-supported, while they appear to have every other piece..
Strange world...
BW
Merlin63Tr4
Try Rimmer Brothers, not cheap....
M.
Geo Hahn
... might try dropping a suitable bearing ball into the hole, and running a bolt down on top of it...
I had to do this with a (non-TR) remote bleeder set-up that would not seal perfectly with any bleeder I could find. Instead of a bolt I used a modified bleeder: pointy end ground off and a notch added:
Works just like a 'normal' bleeder.
Some British cars used ball bearings in the original bleeders.
BTW - That is a small magnet on the open end of the bleeder to hold the ball bearing in place during installation.
Sarastro
Ummm...at the risk of suggesting the obvious, did you try a new bleed nipple? It might be just that the sealing end of the nipple is a little bunged up.
Clever trick with the ball bearing, though.
J For Sale Bilstein Front Shocks for Jaguar E-Type 727-498-6493 Jaguar Classifieds 0
A SOLD!! TR3A Girling Type A brake caliper for right front Triumph Classifieds 0
M Front caliper rebuild 1970 Series 2 E-Type Jaguar 0
JFeher TR2/3/3A TR3 Type "A" front brake caliper rebuilding Triumph 17
HEALEYJAG 73 e-type front overriders Jaguar 3
zedvictor1 what type of front end is this? Spridgets 12
J Will the New F type Jaguar be mid engined or front engined..the last report was..... Jaguar 2
H MK2 lover, but... what about an E type? Jaguar 5
D TR2/3/3A layout for lap type seat belt Triumph 5
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
71TR6 TR6 Type-J Overdrive identification Triumph 4
B Thread Type and Size of BN2 Intake/Exhaust Studs Austin Healey 0
Editor_Reid V-12 E-Type Body Number Location Jaguar 3
M For Sale 2017 Jaguar F-TYPE Premium 2-Door Convertible for Sale mlbirk@aol.com Jaguar Classifieds 0
K TR2/3/3A The Amco chrome tube type grille ....... Triumph 9
T TR2/3/3A A type overdrive hard engagement Triumph 36
S TR2/3/3A Wedge type and Dzus type side- curtains Triumph 1
R TR6 J-Type overdrive will not disengage when warm Triumph 8
6 E-Type brake light pressure switch location Jaguar 5
M General Tech J Type OD Stuck in OD - Fixed Triumph 2
ROARRR Is there any problem swopping in a 3.0 in place of the 2.5 L engine in my Jag X Type? Jaguar 0
M General TR Source for J Type O/D Solenoid Circlip Triumph 0
M Wanted Wanted: Inoperative J Type OD Solenoid! Triumph Classifieds 2
V vintage glue type for veneer? Sunbeam (Rootes) 13
Joel Lester TR2/3/3A What type of valve to use when rebuilding the head? Triumph 10
M TR6 Gear Oil Type and how to add 1973 TR6 Triumph 9
Basil Remember the Royal Electric E-Type Electric Upgrades of All Sizes 0
S TR2/3/3A lifter type Triumph 3
1 TR2/3/3A TR3 Fuel Pump Thread Type? Triumph 4
RonC TR2/3/3A J Type Overdrive in TR3A Triumph 4
M TR6 1973 TR6 Coolant Type? Triumph 5
R TR6 Clutch Master Cylinder Hydraulic Line (Thread / Flare Type) Triumph 4
S TR2/3/3A 187 NOS sleeved type thermostat Triumph 16
Basil The new Kia E-Type? Jaguar 6
H TR4/4A A-type overdrive pump Triumph 4
Got_All_4 TR6 Refurbishing gearbox with A type overdrive Triumph 7
P Wanted E type spare tire bracket Jaguar Classifieds 2
P Wanted 62 E Type spare tire bracket Other British Classifieds 1
Got_All_4 TR6 Routing Speedo cable for a J type tranny in my TR250 Triumph 4
Got_All_4 TR5/TR250 Trying to figure out rear transmission mount with a J type tranny Triumph 9
I GT6 A type OD vs D type - engagement speed? Triumph 3
J For Sale Jaguar E Type and MK2 spares Jaguar Classifieds 0
VooDooDaddy63 Basic E-Type Question: Fasteners - Metric or SAE or ...? Jaguar 15
D TR2/3/3A Type A overdrive not engaging Triumph 0
D TR2/3/3A Type A overdrive not engaging Triumph 16
S For Sale Lotus Elan Factory Workshop Manual on CD/ROM - Type 26 - 1963 - 1965 Other British Classifieds 1
B Resistor type vs non-resistor type spark plugs for 100-6 Austin Healey 17
K TR4/4A TR4 Fuel Gauge'"light bulb socket" type? Triumph 11
Martinld123 H Type Carburetors BN2 M version Leaking Fuel At Jet Bearing Area Austin Healey 18
