Results 1 to 7 of 7
Thread: Front brake rotors hot to the touch......
  1. #1
    Join Date
    Jan 2007
    Location
    Winnipeg ,Manitoba,Canada
    Posts
    2,087
    Thanks Thanks Given
    94
    Thanks Thanks Received
    2
    Thanked in
    I installed new wheel bearings and new brake pads. Would the new brake pads be just wearing in causing the rotors to heat up. If the car has not be excessively braked then parked should the rotors be that hot. Car seems to accelerate and coast OK but my concern is I may not have got the wheel bearing end play right. After my first test run I jacked up the front wheels and pulled on the the drivers side tire/wheel and found a fair bit of play there. I tightened the hub nut a bit and that took out the play in the wheel. I've read all the posts regarding the correct way to set the end play and I believe I set it up as stated. Can the end play be reset correctly with the calipers installed?? Can a dial gauge be used effectively to set end play with the calipers still on?
    I had a severe front bearing failure last year at speed that really got my adrenaline pumping and I would not like to go thru that again. Any advice most appreciated.
  2. #2
    Great Pumpkin NutmegCT's Avatar
    Join Date
    Jul 2004
    Location
    Connecticut USA
    Posts
    11,853
    Blog Entries
    1
    Thanks Thanks Given
    132
    132
    Thanked in
    Re: Front brake rotors hot to the touch......
    Just my two cents here, but - the pads are always in contact with the rotors. So heat will build up even if you don't use the brakes at all. Very different from drum and shoe brakes.
    Is it only the pad/rotor that warms up? or also the brake and hub system?
    Also, can you give us an idea of " ... should the rotors be that hot". You mean too hot to touch?
    Tom M.
    Mac & Phyllis Take a Trip: http://nutmegflyer.com/trip-details-daily-updates/
    History: 1976 MGB, 1959 Triumph TR3A, 1960 Mercedes-Benz 190b, 1958 Rambler American.
    Current: 1953 MG TD27318.
  3. #3
    Join Date
    Oct 2018
    Location
    Livermore, Ca
    Posts
    194
    Thanks Thanks Given
    8
    Thanked in
    Brakes work by dissipating kinetic energy in the form of heat, so any braking will heat the discs up. In racing they glow red but a few hundred degrees is normal, even for a quick run around the block. I don't know of any reason why you can't adjust the end play with the calipers installed.
  4. #4
    Join Date
    Aug 2003
    Location
    Sunny So California
    Posts
    19,552
    Thanks Thanks Given
    8
    138
    Thanked in
    Make sure the pads are pushed back a bit, so they don't screw up the measurement. Having the dust seal in place also makes it more difficult to measure accurately.
    Note that it may be necessary to sand down the washer just a bit, to get the specified clearance with new components. .003" to .005" (workshop manual has wrong numbers)
    https://imgur.com/a/Uh6OA
  5. #5
    Jedi Trainee Joe Schlosser's Avatar
    Join Date
    Jul 2015
    Location
    Chester NY
    Posts
    366
    Thanks Thanks Given
    7
    Thanked in
    No the pads are not incontact with rotors when the brakes are not applied. The square caliper seal pulls the pad back just enough so that they are not touching.
    If they are touching/dragging then something is wrong
    Joe Schlosser
    SCCA National License, Retired
    60 Bugeye, since 1966
    SCCA FP, sold but not forgotten
  6. #6
    Join Date
    Aug 2003
    Location
    Sunny So California
    Posts
    19,552
    Thanks Thanks Given
    8
    138
    Thanked in
    On a TR3, there is actually a residual pressure valve that holds the pads in (light) contact, for at least some time after each application of the brakes. It does slowly leak down, but they will drag enough to notice (when turning the wheel by hand) when the valve is working properly. I actually remove the RPV on my cars, because I don't like that dragging feeling (even though in reality it does no harm to speak of).
    More modern cars are indeed designed to pull the pads back; but for that to work, there must be some connection between the pads and pistons. TR3 disc brakes have no such connection. Even if the pistons somehow retracted all the way, the pads would still be out against the rotor, held there by the "damping" spring.
    Randall
  7. #7
    Yoda CJD's Avatar
    Join Date
    Feb 2011
    Location
    Arlington, TX, USA
    Posts
    5,617
    Thanks Thanks Given
    6
    47
    Thanked in
    Yes...what Randall said! Warm to hot discs after driving is normal, since the valve does keep the pads in light contact with the rotors.
    John
    1955 TR2
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
