Speedi-sleeve p/n needed
Michael Oritt
My left rear tire is leaving a tell-tale oily footprint on the garage floor and it is obviously time to inspect and probably resleeve the hub. Does anyone have the sleeve p/n--this for a 12/54 mid-production (222333) BN1?
Michael Oritt
Michael Oritt
Steve--
Sorry, my brain was not fully engaged, but yes a sleeve for the axle tip bearing surface is what I seek. I have never had to address leaks from the 100's rear axle since buying it 20 years ago but on the Elva Courier, which uses a Morris Minor rear axle housing, leaks always come from this bearing surface which no doubt gets a lot more wear due to the strains of racing.
steveg
Steve--
Maybe BCS or Healey Surgeons would have them in stock or would know the measurement. Otherwise they're sold by measurement. Won't know if you need one until you examine the sealing surface. Maybe the seal is just old.
Michael Oritt
Michael Oritt
I pulled the left axle shaft today and found to my amazement that there was no paper gasket between the inner face of the axle flange and the hub. I installed new brake shoes a year or so ago and cannot believe that I left out the paper gasket. I am also amazed that the leak did not appear sooner. In any case a gasket is now in place and the leak is gone. Maybe I need to check the right side....
F Schreiber
I dont' know the p/n but if you get on the S/K site that have a list for some cars, and if it doesn't have any Healey, then its easy to measure the shaft and pick it off the S/K chart, same web site. Once you do it, its pretty easy for next - different job. You just have to make sure you get it pushed on the right distance so the seal lip is on the surface of the sleeve, ( seal or sleeve pushed far enough but not too far..
Michael Oritt
Michael Oritt
Steve--
Yes, I did use Hylomar.
Joel Lester TR2/3/3A What size speedi-sleeve needed for pinion seal on a TR3? Triumph 6
Jim_Gruber Hubs a Rocking on side where Speedi Sleeve was installed Spridgets 5
Jim_Gruber Speedi Sleeve Install and New Diff Gasket Spridgets 5
Jim_Gruber Speedi Sleeve required for this application - Need advise! Spridgets 12
Michael Oritt Speedi-sleeve part number Spridgets 0
M TR2/3/3A TR3 overdrive trans rear speedi sleeve Triumph 6
T SKF Speedi-sleeve p/n for tailend of transmission? Triumph 3
K TR4/4A Paging TR4nut re Timken speedi sleeve? Triumph 4
K TR2/3/3A Tr3:installing a speedi sleeve timing chain cover? Triumph 4
M Speedi sleeve question Triumph 7
mgnewbie Speedi-sleeve for the gearbox rear oil seal MG 7
lorendad Speedi-sleeve Triumph 10
budk1953 Speedi-sleeve Spridgets 11
MGTF1250Dave Speedi-sleeve for Timing Cover Seal Triumph 15
G Cheap[er] speedi sleeves Spridgets 9
tahoe healey CR Speedi-Sleve Austin Healey 5
M TR2/3/3A Speedy Sleeve Repair Sleeves for Rear Axle Pinion and Half Shafts Triumph 1
Lin Thermostat and blanking Sleeve question again Austin Healey 7
K TR2/3/3A TR3 Tie Rod Sleeve Triumph 2
K Wanted TR3 Tie Rod Sleeve Triumph Classifieds 2
Healey Nut Thermostat blanking sleeve Austin Healey 13
RAC68 Radiator Core Replacement and Sleeve Thermostat Alternatives Austin Healey 20
R TR6 bronze sleeve for release bearing Triumph 1
M TR2/3/3A Sleeve and Piston Sizes Triumph 6
T TR4/4A Release Bearing Sleeve Triumph 0
K TR2/3/3A Clutch and Gearbox Sleeve Differences. Triumph 12
BoyRacer Top bows - plastic sleeve for socket Austin Healey 0
K TR2/3/3A When assembling a release bearing to the sleeve? Triumph 4
R TR2/3/3A Steering, stator tube compression sleeve? Triumph 4
K TR2/3/3A What's the easiest way to remove the clutch release bearing from the bronze sleeve? Triumph 7
B TR2/3/3A TR3 Cylinder Sleeve Installation Triumph 10
B inner bushing sleeve on pin? Triumph 5
B TR6 TR6 Front Oil Seal Sleeve Triumph 3
PatGalvin TR2/3/3A Wet Sleeve to Engine Block Deck Clearance, TR3A Triumph 4
W Suggestions on wiring sleeve Spridgets 3
M Cylinder sleeve protrusion Triumph 4
T Apple Hydraulics for M/C re-sleeve Triumph 11
Ohiobugeye Bugeye Fuel Line Nut & Sleeve For Gas Tank Spridgets 12
I TR6 TR6 Trunion installation/stop sleeve help Triumph 4
dklawson Spitfire Spitfire - Trunion Bushing/Sleeve Clearance? Triumph 2
KVH Revelation Re Those Figure 8 Sleeve Gaskets Triumph 8
Basil Redi-Sleeve for Spitfire? Spridgets 6
ronzet MGA MGA 1500 Thermostat Blanking Sleeve MG 22
prb51 TR2/3/3A TR3 Dif Pinion seal and speedy sleeve Triumph 12
W TR6 TR6 Crank oil seal sleeve Triumph 4
P thermostat/blanking sleeve? MG 5
G Oil Seal Sleeve......This is getting to be a pain Triumph 0
Steve P. master brake/clutch re-sleeve...suggestions Spridgets 3
Patrick67BJ8 Healey Mechanic Needed - El Paso, Texas Area Austin Healey 0
H TR2/3/3A Rock guard needed Triumph 2
