For Sale BJ8 and BT7 parts for sale
Healey Nut
******BEEN CLEANING UP MY SHOP DOING INVENTORY MANY NEW PARTS ADDED , SEE BELOW .****
Please note ***********
If you are inquiring about parts and want a shipping cost I need a FULL mailing address inc post/ZIP code to get a UPS quote and a current active email address if you want any pics of the items .
Tks .
I have added AH spares part numbers to a lot of this stuff for reference as we all have different terminology for parts .
Lots of leftover parts from BJ8 and BT7 Tri Carb restorations .Need to unload some of this stuff to some needy owners . Offers welcome on anything .
Three ground up restorations done that’s all for me , this stuff needs to find new homes and be used to keep these old cars going .
PM me for costs and shipping info .
Make me sensible offers on all items I'm not looking for huge $$$ just want help enthusiasts keep them on the road , I also have some stuff not listed . Just ask I may have what you need .I even have some brand new small parts unused as well .
Let keep these old girls on the road
BJ8 Door card clips TRP251 - 12 new
Upper Door hinge BJ8 used
zinc P clips for wiring harness new 6
seal clips new 10 DRF236
BRK236 felt washer 8 new
Front bumper spacer washer 2 new BMP140
2 wood horizontal section above window for soft top used
1 pair wood seat rail used original SET116
1 battery backer wood used original ELG205
Alternator /dynamo adjustment pillar mount.
Steering column cup washer used STG117
1- complete propshaft adjustable type .
1-pair headlamp stone guards ,chrome . LTG174
1-original non enamel front shroud AH wing badge MK3
1-MK3 cloisonné front badge , driver quality . BAD110
1 -set rear axle U bolts , brand new . SUR142
4 - hydraulic hose star lock plates CL4172 Ahead for Healey number
1- bullet mirror MRS108
1- regular wing mirror MRS105
4 short wheel spokes new WHE162
4 long wheel spokes new WHE163
2-twin cable choke firewall bracket CBS126
Various 7” sealed beam units all working LTG172
6 orange indicator lenses LUCAS LTG141
2 clear lenses Lucas LTG122
1- acorn top coil good resistance
1- regular coil good resistance ELI140
Various sizes wire type hose clamps CHT161a style
4- used but good A arm pins and nuts SUF132
2- fulcrum pins and cap nuts SUF108
8 large rubber side light etc body gaskets new LTG143
16 soft foam plastic lens gaskets new LTG146
Large heater hose support clamp flat metal type CHT163
1-thermostat sleeve
1pair bonnet safety latch plates BON141
1 chrome boot strap staple WHE178
1set front shroud grill brackets GRL129
1pair rear Hardtop latch rods and aluminum wing nuts HOD261/263
1- complete mechanical tach drive unit .
1- BT7 vertical bar grill GRL103
1- complete seat back assembly BT7 , will need recover frame etc good . UP4257 Ahead for Healeys number
1- gold face oil psi/water temp gauge . Will need overhaul as usual .
Trunk prop rod bracket BOT126
1- hood prop rod bracket BON140
1-locking fuel cap with keys
1- brand new pair plastic headlight buckets 2 adjuster with retainer ring . LTG182
1-generator with pulley and coil mount bracket
1-interior trunk latch assy . BOT107
1- perfect condition generator mounting plate . ENG776
1-BT/BJ7 rear upper soft top trim rail .
1- BT7 clutch pressure plate
1-rear engine plate
2- full sets original pistons standard size very useable condition .
1- set original Con Rods
2-BJ8 fuel filler necks and caps
2- oil filter assemblies, with 90 degree adaptor piece.
3-Oil filter elements paper type .
3-oil pumps
1- full set main bearing caps .
1-pair Girling brake servo bracketsBRK317
1-stub axle right side /hub extension , good splines coarse thread .RAX205
1-pair chrome corner pieces originals good rechrome candidates DRF190 &191
1- pair wing flashes originals
4-chrome BJ8 door waist moldings originals , good rechrome candidates
1-BT7 flywheel with starter ring
1-BT7 Harmonic balancer ,for core or rebuild .
1-distributor drive gear
1-oil pump drive gear ENG674
1-BT7 crankshaft for regrind
1-timing gear cover ENG780
1-original spare wire wheel original paint in good condition with bias ply tire ,perfect for concourse
2- sets original valve cover cap nuts ENG740 NOT STAINLESS .
1-set timing gears useable
1pair new radius arm bushings SUR166
2- brand new rear spring bushings SUR125
1- original fuel pump with BT7 mount plate (non electronic) in good rebuildable condition .Note ***Round body SU***
1- original panhard rod for BT7 , sandblasted primed and painted plus new bushings and bracket etc .
misc internal engine parts , main caps , timing chain adjusters etc .
other ods n ends not listed …..just ask me I may have what you need .
Healey Nut
Healey Nut
Healey Nut
Healey Nut
Healey Nut
Healey Nut
Healey Nut
Healey Nut
With the sale of both my BJ8s Im open to offers on all the BJ8 parts . Just looking to help keep these old girls running .
Healey Nut
Healey Nut
NO slide bolts available. Sorry .
Healey Nut
Healey Nut
Sorry that’s long gone , I used it to repair my boot lid for my TriCarb project . Made one good one out of two and scrapped the rest .
jlburdge
I didn't think it would be around. I just thought I could replace one that had lots of runs on it, though can be fixed no problem. ldb
AN6-TX
Any chance you have a tach for a BJ8?
Healey Nut
Healey Nut
Nope sorry , no Tach spare . All the instruments I have are gold face ones .
jnew >>> Austin-Healey Parts Lists for BN4-BN6, BN7-BT7, & BJ7-BJ8 Available Online Austin Healey 17
BJ8Healeys Bt7 ---> bj8? Austin Healey 15
D Differences between BT7 and BJ8 engines. Austin Healey 12
6 Dash Instrument Conversion: BJ8 > BT7 Austin Healey 3
6 BJ8-BT7 Tri-carb Conversion? Austin Healey 7
J BJ8 versus BT7 Shroud Austin Healey 11
F BJ8 Exhaust Hanger Pictures Wanted Austin Healey 9
Patrick67BJ8 Custom BJ8 Dash Switch Panel Austin Healey 7
1 BJ8 History Trace Austin Healey 7
D BJ8 Top Installation Detail Austin Healey 3
S Wanted WTB: 3.5 ratio diff/pumkin for '67 BJ8 Healey 3000 Austin Healey Classifieds 0
AUSMHLY BJ8 Trans Cover Carpet Austin Healey 7
AUSMHLY BJ8 Carpet and Snaps Austin Healey 2
Overdrive45 BJ8 Interior Trim Austin Healey 8
nitro BJ8 Production Year Austin Healey 6
B BJ8 Seat Sliders Austin Healey 4
BoyRacer For Sale BJ8 disk wheel hubs, spindles & calipers Austin Healey Classifieds 0
S SOLD!! For Sale 1964 AH 3000 MkIII BJ8 Phase 1 Austin Healey Classifieds 2
Patrick67BJ8 BJ8 Factory Hardtop Rear Window Austin Healey 6
AUSMHLY BJ8 Clutch Pressure Plate, Old vs New Austin Healey 4
AUSMHLY BJ8 Clutch Fork Bush Replacement Austin Healey 5
AUSMHLY BJ8 Cylinder Head Installation Austin Healey 6
LAW75 BJ8 Brake Lines Austin Healey 2
AUSMHLY BJ8 Clutch Pressure Plate Brand Preferences Austin Healey 3
BoyRacer For Sale BJ8 spindles & disc wheel hubs Austin Healey Classifieds 0
G Wanted BJ8 Tonneau Cover Austin Healey Classifieds 0
Cutrog1 For Sale Healey 3000 BJ8.... a restoration saga Austin Healey Classifieds 0
AUSMHLY BJ8 Overdrive Oil Passages Austin Healey 2
Scotsman Wiring Diagram for 1966 BJ8 Austin Healey 3
A For Sale 1966 3000 Healey Blue BJ8 Austin Healey Classifieds 3
B BJ8 Hood Bow and Seal Austin Healey 5
Mickey Richaud Wanted Wanted: BJ8 Seat Track Sets (Both Sides) Austin Healey Classifieds 5
Scotsman BJ8 Intake Manifold Differences Austin Healey 4
AUSMHLY Laygear End Float BN1-BJ8 Austin Healey 2
C For Sale BJ8 original dash Austin Healey Classifieds 3
LarryK BJ8 Parts or Project Car For Sale in St. Louis Austin Healey 3
Patrick67BJ8 BJ8 Intake manifold Booster & Vacuum Hookup threads sizes. Austin Healey 2
B BJ8 Centre Console Chrome Strips Austin Healey 5
B Wanted Chrome strips centre console BJ8 Austin Healey Classifieds 0
AUSMHLY BJ8 Cylinder Head Re-Torque Austin Healey 26
