TR6 Fuel pump rebuild, Part not included
Got_All_4
Anyone know where to get this filter from. This is the first one I've had that was nylon. Rebuilding the pump for my TR6 and discovered that this screen is all dried up and cracked.
TR3driver
Great Pumpkin - R.I.P
TRF seems to have it listed, IF what you have is the stock AC fuel pump.
http://trf.zeni.net/TR6bluebook/24.php
If it's one of the "no-name" repops, though, I suspect you're out of luck
poolboy
The AC pumps filter screen was brass....those plastic ones are notorious for what you show..and worse.. disintegration.
If you have a fuel filter before the pump, you can delete the screen.
Got_All_4
Got_All_4
Ya I know its one of those repops Moss sells. Few years ago Moss said these were the best out there warranted for 2 years and seems to me it was around $50. Anyway installed it on my TR250 early summer then went to TRF summer party in August and it failed right after the auto cross. Less the 1k on it. Luckily one of my friends there had a electric back up pump that got me back to TRF and had to spend $100 on one of their's. Guess what I carry with me in my trunks now? Anyway that one has been in there for 5 years now and so far so good.
Poolboy I was thinking that same thing or using a piece of aluminium screen from my old porch door and make one. Not as fine but the pre-filter should get anything big.
Got_All_4
Got_All_4
Went to my local parts guy (Team Triumph) to see if Moss had one or if he had a used one. No to the first question and would not brake down a used AC pump. Said customers buy the used ones and he can't get enough of them. They prefer to rebuild them and use them instead of new repops. Can't be much different because your replacing the innards with repo stuff anyway. Don't know why I didn't think of it sooner but went home and checked my stash and found a pristine one.
D TR6 2 Fuel pump rebuild questions Triumph 6
D TR4/4A which fuel pump rebuild kit to use Triumph 7
7 AC fuel pump rebuild kit suppliers Triumph 12
PeterK Fuel pump rebuild Triumph 7
T Fuel pump rebuild kits - good results? Triumph 5
M TR2/3/3A TR3 Fuel Pump rebuild Triumph 2
T Post-War Other Brosky, can you rebuild the TRF Italian fuel pump? Triumph 17
R Rebuild of LCS SU Fuel Pump Austin Healey 13
DenverMGB SU Fuel Pump ReBuild MG 30
HAN8L1965 65 FUEL PUMP REBUILD? Spridgets 11
Walk New Fuel Pump & Rebuild Carb - No Gas in Between! MG 21
M TR4/4A TR4 Fuel Pump Rebuild Triumph 3
W Mechanical Fuel Pump Rebuild Spridgets 1
martx-5 TR2/3/3A TR3 Fuel Pump...Rebuild or New Triumph 6
S TR2/3/3A TR3 fuel pump rebuild Triumph 10
B TR4/4A AC Fuel Pump Priming Lever Stuck Triumph 14
Q TR2/3/3A 61 TR3A Fuel Pump Triumph 4
D Wanted Square body LCS fuel pump Austin Healey Classifieds 13
D Wanted Wanted square body fuel pump Jaguar Classifieds 0
D TR4/4A TR4a Fuel Pump Triumph 10
RJS TR4/4A Fuel Pump Gasket Triumph 8
D MGB Fuel Pump MG 2
Martinld123 Electric Fuel Pump Austin Healey 6
S TR2/3/3A Fuel Pump??? Triumph 14
D Fuel Pump Ticking but Not Pumping Austin Healey 8
A Spitfire Fuel Pump Triumph 5
A Spitfire Spitfire Fuel pump issues Triumph 5
K TR2/3/3A Fuel line routing from pump to carbs Triumph 7
A GT6 Fuel Pump Leaking at out port GT6 MK3 Triumph 0
wkilleffer MGB 1974 MGB SU fuel pump voltage issue MG 11
S fuel pump upgrade Spridgets 0
S Sprite Fuel Pump Upgrade Austin Healey 1
F TR4/4A New to forum - Rebuilt Fuel Pump and weeping float bowl Triumph 9
P XJ12 Fuel pump relay 85 Jaguar 4
petnatcar Fuel Pump Upgrade Austin Healey 2
R Electronic Conversion on an SU Fuel Pump? Restoration & Tools 2
T TR6 Fuel pump lines Triumph 2
1 TR2/3/3A TR3 Fuel Pump Thread Type? Triumph 4
R Electric fuel pump wiring Spridgets 4
T SU Fuel Pump Mounting Austin Healey 5
D TR2/3/3A More Fuel pump questions. Triumph 10
Donald1107 59 TR3A Fuel Pump Triumph 48
BobHaskell SU Fuel Pump Pressure Austin Healey 1
Cutrog1 Fuel Pump Ticking Austin Healey 13
MGTF1250Dave T-Series MG TF fuel line from tank to pump MG 3
S SU fuel pump servicing Austin Healey 4
71TR6 TR2/3/3A AC Fuel Pump Lever Triumph 10
E MGB 1965 mgb fuel pump removal MG 2
D For Sale Su fuel pump Other British Classifieds 5
D For Sale Su fuel pump Austin Healey Classifieds 5
