General TR Ignition lock barrel help
ichthos
While removing my ignition lock barrel from my TR6, the button/spring that holds it in shot off to the great abyss of my shop floor. Does anyone have a used lock barrel with a key(s) I could buy? Not intrrested in new. Thank you in advance for your help. Kevin
RJCOX
You could have it fixed by a locksmith. We recently had one keyed to match up the set.
Out here is a chain called professional lock and key. Don't know if they are a national chain or not.
old sub sailor Ignition switch / steering lock replacement in a '78 midget Spridgets 5
mikecyc72usa MGB 71 MGB ignition lock core removal MG 3
angelfj1 TR2/3/3A TR3A Ignition Switch - new lock/key Triumph 5
W Ignition lock piece needed please MG 1
G ignition key/lock switch question Spridgets 0
G Removing ignition key/lock switch? Spridgets 5
Monark192 Ignition Switch / Steering Lock Removal Question Spridgets 1
bcliff Needed: Ignition lock cylinder MG 2
MGTF1250Dave Wedge TR8 Ignition Lock & Switch Repair & Replacement Triumph 10
Steve1970 TR6 How do you replace the ignition lock, 74 tr6? Triumph 6
N TR6 TR6 Steering lock and ignition Triumph 1
T T-Series Ignition lock and switch removal MG 2
TNMGB Steering wheel lock and ignition question... MG 11
martx-5 TR2/3/3A TR3 Ignition Lock Cylinder Triumph 3
M T-Series 1974 mgb ignition switch/lock w/harness MG 10
R Steering lock/ignition on sprite MK II Spridgets 3
T TR6 TR-6 Ignition switch/lock replacement Triumph 2
R TR6 Crazy Ignition Failure in TR6 engine… Triumph 7
R Ignition Failure Austin Healey 12
R Bugeye ignition switch Spridgets 2
G Crane XR700 Electronic Ignition / BT7 Austin Healey 6
RJS TR4/4A Tune Up Order - Fuel and Ignition Triumph 5
T 100 BN2 Possible Ignition Issue Austin Healey 7
Cokerair TR4/4A Fried Ignition Coil Triumph 18
R Wanted Bugeye ignition switch Spridgets Classified 2
J TR2/3/3A Red ignition light stays on Triumph 7
M Which wires fit which terminals on my Rover V8 ignition switch? Rover / Land Rover 6
F Hot Ignition Coil Austin Healey 6
J Ignition Key Malfunction Austin Healey 6
R Electrical Experts - Vixen 2500 - Ignition Switch Observation? TVR 10
SherpaPilot TR6 Ignition Switch Question Triumph 13
PAUL161 T-Series MGTF Ignition Key MG 7
P TR2/3/3A ignition switch smoking Triumph 12
rgfrey BN4 Ignition/Turn Indicator Light Austin Healey 7
PAUL161 T-Series Points Triggering Electronic Ignition MG 5
W Healey BN1 Ignition Light Austin Healey 8
C TR6 Ignition Switch for 1972 TR6 Triumph 1
K TR2/3/3A Red ignition light stays on...car has alternator not generator. Triumph 17
E Ignition Timing Austin Healey 14
T TR6 Continuous Starting and Ignition Issues Triumph 6
TRickster6 MGB electronic ignition on '73 MGB MG 1
K TR2/3/3A Ignition timing questions while I'm waiting for Spring Triumph 27
J TR2/3/3A Early Lucas Ignition Switch Triumph 4
jlaird MGB ignition switch MG 2
algot1901 Electronic Ignition for 1950 Prefect 1172cc Eng Other British Cars 10
Lin Ignition timing question Spridgets 2
H MGB 1980 mgb no power from ignition switch MG 23
Lin Crane or Fast XR700 Electronic Ignition Austin Healey 4
Lin Checking static timing for a 1275 with Crane XR700 ignition Spridgets 0
