I'm having a tough time getting the original Purolator oil canister to seal. I was changing the oil this past week, and had difficulty getting the new gasket up in the filter head, then attaching the canister. I thought I had it, wrenched down the canister, then when I started the car to circulate the oil (after cranking it some with the key off), it spewed a quart or so on the garage floor!
After researching fitting the gasket on this and the Triumph Experience forums, I found that there can be different "sizes" of the o-ring. I ordered the correct ones from TRF but I still can't seem to get them to fit in the groove properly. The cross section in the shop manual shows the o-ring to fit in the groove almost flush, mine stands proud and I don't think the groove is deep enough (the TRF o-rings are not as tall, but the same thickness as the ones I already had). How deep should they be? I've changed the oil before (in my old pre-Macy's rebuild engine) and don't remember this trouble.
I think I'm going to order the spin-on adapter from TRF and be done with this. Help, if you can. I miss driving my car!
