Dash refinishing help
64 healey
Hi I’m in the process of refinishing my dash
panels in my original 64 3000 with just 52,000 miles. I’m a car,boat,motorcycle crazed nut from way back when. This sight seems to have some very useful help that I am in need of.
Gliderman8
Hello 64healey and welcome to the BCF.
You will get more answers by posting your question in the “Austin Healey” section of the forum.
I can tell you that when I refinished the Walnut dash on my TR6 I sanded off the old veneer the used PRE-CATALYZED Veneer Adhesive. It holds up better than contact cement. After I applied the adhesive, I sandwiched the dash between two pieces of plywood with bolts and wing nuts strategically placed. Tightening the wing nuts gave me the clamping pressure I needed while the glue dried. I finished it with UV Marine Grade Polyurethane.
Administrator
Boss
Hey there 64, I'm going to move this thread to our Austin Healey forum where you will be more likely to get answers. If you're reading this, then you are now in the Austin Healey forum. I will leaver a "pointer" in the New Member Introuctions forum (where you originally posted your question).
When you have a chance, go back to the "New Member Introductions" forum and post an inroduction for yourself. Tell us a bit about yourslef.
Cheers, Basil
glemon
When I did my dash on my TR250 I peeled/picked the thick varnish off the surface leaned and very lightly sanded and then simply finished with some Minwax clear poly and it ended up looking great. But how it ends up will be dependent on where it starts, a lot of people re veneer their dashes too.
Stinger TR4/4A TR4A Wood Dash Refinishing Triumph 18
jjbunn Refinishing the dash Triumph 9
B TR2/3/3A TR-3A Dash Cap Refinishing Triumph 16
J Spitfire Spitfire Dash Top refinishing Triumph 4
I TR6 TR6 dash refinishing Triumph 7
J For Sale TR 3 dash warning light lens, used Triumph Classifieds 0
J Spitfire No start after fiddling with dash Triumph 2
Patrick67BJ8 Custom BJ8 Dash Switch Panel Austin Healey 7
K TR2/3/3A Switching to green LED dash panel bulbs? Triumph 3
V For Sale Hard Top and Solid Walnut Dash for Sale Triumph Classifieds 2
KVH General TR Green Turn Signal Dash Indicator Triumph 8
timsgolf Center Dash Switch Plate Painting Austin Healey 5
C MGA Dash removal MG 0
C For Sale BJ8 original dash Austin Healey Classifieds 3
rjc157 For Sale Dash Austin Healey Classifieds 1
Bocaray TR2/3/3A Headlight Dimmer conversion to dash switch Triumph 6
M MGA RHD MGA dash finisher MG 0
A MGB MGB dash painted MG 13
Rob Glasgow LED Dash Light Upgrade Austin Healey 28
jfarris TR2/3/3A Removing choke cable from dash insert Triumph 3
BoyRacer Blue Vinyl Dash Material Austin Healey 3
jfarris TR2/3/3A Dash Lights Triumph 3
E Wanted wanted Austin healey 3000 adjustable steering wheel & dash pad Austin Healey Classifieds 2
R Ground wires under dash Spridgets 5
EWD TR6 74 TR6 Renegade Dash Wire Triumph 7
B TR4/4A Dash Color? Triumph 3
EWD TR6 TR6 top dash trim paint Triumph 2
TomMull Dash wiring Plus 2 S Lotus 16
I TR6 Dash light issues Triumph 19
J Attaching BT7 Dash Facia Panel Austin Healey 2
EWD TR6 Dash Pad Replacement Triumph 3
longbridgehealey Bugeye dash Spridgets 6
J TR2/3/3A Wooden piece under scuttle with dash Triumph 6
Basil New Dash Cover in the Telly Other Cars 3
oldbagpipe Wanted Early TR4 Silver [Aluminum] Dash Cluster Triumph Classifieds 1
steveg TR6 Metal Dash - does anyone make one? Triumph 13
charleyf TR2/3/3A Under dash fuse Triumph 7
F TR2/3/3A Dash repair Triumph 7
M Getting behind the dash on BJ8 Austin Healey 4
Rut TR4/4A Dash color Triumph 9
Rut TR4/4A TR4 wood dash Triumph 26
J Walnut veneer for the dash, Look what I found! Austin Healey 12
I TR6 Thickness of original TR6 dash Triumph 2
S TR2/3/3A Dash Pot Oil Triumph 14
TRMark T-Series Dash for Sports/Racer MG 5
S BJ8 Choke Cable- How to tighten the nut behind the dash? Austin Healey 6
TomMull replacing walnut veneeron the dash Lotus 17
K TR2/3/3A Dash Lights Triumph 3
EWD TR6 ‘74 TR6 Interior - Padded dash and heat/sound material Triumph 4
