Page 2 of 2 FirstFirst 12
Results 21 to 38 of 38
Thread: Non-Healey Cruising Rear Possible?
  1. #21
    Yoda HealeyRick's Avatar
    Join Date
    Apr 2004
    Location
    Massachusetts
    Posts
    5,838
    Thanks Thanks Given
    16
    Thanks Thanks Received
    41
    Thanked in
    Re: Non-Healey Cruising Rear Possible?
    Quote Originally Posted by RAC68 View Post
    Hi Rick,
    I must agree with all you have said and the a 3.54 ring and pinion is most likely what would be best. However, how did you come to know that that rear was in all the cars mentioned? Was it from experience or an informal acquisition of knowledge or from a cross indexed parts list? I expect I know the answer but I can hope.
    Thanks Rick and all the best,
    Ray(64BJ8P1)
    Ray,
    In my wellspent youth, I spent an inordinate amount of time hanging around in what were called "junkyards" and learned more about cars and life than many courses of higher education. Every junkyard had a full complement of Hollander's Interchange Manuals that would magically tell you that a starter from a '54 Studebaker would fit a '67 Plymouth Roadrunner. Somehow the local yard knew a rear axle from a Nash Metropolitan would fit my Bugeye. Hollander is still in business and I was surprised to see they have a foreign version: https://hollanderinterchange.net/cat...2e952462881885 . I have no idea whether it covers Healeys. I did know from collected knowledge that some of the larger BMC "saloons" used the same driveline as the Healey and I believe the ones I listed have the same rear end, however I'm not exactly positive and if you were trying to hunt one down you might want to confirm they fit first.
    Rick
  2. #22
    Luke Skywalker vette's Avatar
    Join Date
    May 2002
    Location
    Pa.
    Posts
    1,727
    Thanks Thanks Given
    1
    13
    Thanked in
    I am sure that I have read that the Healey rear end came from a truck. What I believe has been called a lorry. I know the rear end is what is called a semi-floating axle design which is commonly used in heavy applications such as trucks.
    About TV Shows-
    "...you really can't restore a car in 10 days. I don't want to watch a race where people have to restore it in a week. It's not going to drive, and those cars never work. In real life, it takes years to get it right. " Jay Leno.
  3. #23
    Yoda steveg's Avatar
    Join Date
    Sep 2007
    Location
    Altadena, CA
    Posts
    3,809
    Thanks Thanks Given
    93
    143
    Thanked in
    After all this, it seems to me the $64 question is: would a Jaguar ring-and-pinion interchange into a Healey axle. My reasoning is the Jag is the only reasonably common British car that's faster than a Healey. All the other uses of this axle, such as lorries, saloons, taxis, etc are going to be slower, hence will have a higher numerical ratio. The Jags, being faster, would have a lower numerical ratio, such as a 3.3. So the question is whether this would interchange into a Healey. All other faster cars, such as Aston Martins, Bentleys, Jensen Interceptors - are going to be much rarer, therefore one would expect usable ring-and-pinions to be rarer/more expensive.
    Steve Gerow
    Altadena, CA, USA
    Maker of most complete Big Healey rear disc kit
    Check out my galleries:
    http://www.pbase.com/stevegerow
  4. #24
    Join Date
    Apr 2004
    Location
    Massachusetts
    Posts
    5,838
    Thanks Thanks Given
    16
    41
    Thanked in
    The Dana 44 postal jeep rear might be worth checking out to see if it fits: http://www.britishv8.org/articles/dana44axle.htm
    Rick
  5. #25
    Yoda Michael Oritt's Avatar
    Join Date
    Jun 2001
    Location
    Lusby, MD, USA
    Posts
    3,276
    Thanks Thanks Given
    6
    23
    Thanked in
    I believe--but am not certain--that the conversion from the standard 3.9 diff to the 3.5 Lempert diff lowered my 70 mph rpm's from around 4K to 3K. I'll leave it to the mathematicians to figure out but if the commensurate reduction using a 3.09 diff (as discussed) would bring the 70 mph cruise rpm's down to 2000 or thereabouts this would place the revs below the engine's green/go line and would necessitate a downshift of at least one gear in order to have enough torque for a reasonably snappy pass.
    Best--Michael Oritt
    1954 Austin-Healey 100 Le Mans
    1958 Elva Courier (FOR SALE)
    1959 Elva MK IV Sports Racer
    1961 Ginetta G4
  6. #26
    Join Date
    Mar 2006
    Location
    scotland
    Posts
    122
    Thanks Thanks Given
    Thanked in
    As said above, Westminsters and their namesakes used the same diff in a couple of different ratios. From memory, the autos used the 3.54 that is desireable nowadays, the manual ones not so much. The Westminster etc engines were about 90% the same as Healey. The later ones used broadly the same gearbox, but with more differences. Im not aware of any other big saloons of the era that used the same components. Jaguar, Rover etc were not part of the group at that time
  7. #27
    Join Date
    Aug 2016
    Location
    Greensburg, PA
    Posts
    123
    Thanks Thanks Given
    1
    Thanked in
    1 Post
    Quote Originally Posted by Michael Oritt View Post
    Michael,
    Not a mathematician, but the 3.9 diff has a 43 tooth ring, the 3.55 a 39. Both have an 11 tooth pinion. Arithmetic says that's just about 10%, so your revs would drop by about the same %. That is what I experienced in my Healey and also in my Jag when I went from 3.54 to 3.31.
  8. #28
    Jedi Warrior maxwedge5281's Avatar
    Join Date
    Aug 2013
    Location
    easley, south carolina
    Posts
    575
    Thanks Thanks Given
    Thanked in
    too bad that there are not adaptors for the tremec 5 speed transmission. i have one in my bn6 and cruise at 70 mph at 1800 rpm in fifth gear. i do have an in line six chevrolet motor but the tremec ratios seem perfectly suited to my driving style....
    1959 bn6 sbc zz4 with aod transmission....... 1959 bn6 inline 6 250 chev engine and tremec 5 speed.......Porsche 911 all aluminum 434 cubic inch dart sbc engine 930 4 spd
  9. #29
    Join Date
    Sep 2007
    Location
    Altadena, CA
    Posts
    3,809
    Thanks Thanks Given
    93
    143
    Thanked in
    Quote Originally Posted by maxwedge5281 View Post
    Oh, but there is:
    Steve Gerow
    Altadena, CA, USA
  10. The Following User Says Thank You to steveg For This Useful Post:
    Patrick67BJ8  (07-07-2019)
  11. #30
    Obi Wan RAC68's Avatar
    Join Date
    May 2010
    Location
    NJ Shore
    Posts
    2,069
    Thanks Thanks Given
    16
    Thanked in
    Hi All,
    Per MaxWedge, a 10% RPM reduction from the roughly 4K-RPM @ 70-MPH would produce a cruising RPM or 3600 with a 3.5 rear. Now, doubling that and assuming the same number of pinion teeth, it would seem to yield a ring gear reduced from the 3.9 @ 43-teeth to approx. 35-teeth for a 3.1 rear to cruise at 3100-RPM @ 70-MPH. I appreciate that my numbers are not very accurate but if the logic is correct, going to a 3.09 rear is not that far from ideal.
    Now, I appreciate that these numbers are misleading and having had no experience in this area, my knowledge non-existent. So, what would be a good ration to provide a good cruising speed with sufficient pep to run in OD? Although many believe the 3.5 rear is a good choice, is it because of its availability or performance satisfaction?
    Bottom line, what would be the ideal rear ration for if any ration was available to choose from?
    Just my thoughts,
    Ray(64BJ8P1)
  12. #31
    Join Date
    Sep 2007
    Location
    Altadena, CA
    Posts
    3,809
    Thanks Thanks Given
    93
    143
    Thanked in
    I have the 3.54 rear and .78 Toyota OD 5th, with 180-15 Michelins - 3000 rpms is about 79 mph. 70 mph freeway is around 2500.
    Steve Gerow
    Altadena, CA, USA
  13. #32
    Join Date
    May 2002
    Location
    Pa.
    Posts
    1,727
    Thanks Thanks Given
    1
    13
    Thanked in
    Well to add a little fodder to the feed or whatever, My BJ7 runs at about 2800 rpms at about 63 to 64 mph with a 3:54 rear and OD. But I don't know what ratio my OD is. As a comparison for a lower numbered rear gear my '70 Vette has a 3:08.1 rear gear and is right on 65 mph at 2500 rpms. the final wheel diameters of both cars is very near the same. I believe the Healey could handle something near the 3:08 number because it has a lot of low torque and the 1st gear is low enough to give it thrust at start off.
    About TV Shows-
  14. #33
    Join Date
    Sep 2007
    Location
    Altadena, CA
    Posts
    3,809
    Thanks Thanks Given
    93
    143
    Thanked in
    Quote Originally Posted by vette View Post
    Isn't the Vette doing this on a 1.00 4th gear rather than an OD 5th?
    22% OD on 3000s; 28% on 100s and 100-6s
    Steve Gerow
    Altadena, CA, USA
  15. #34
    Join Date
    May 2002
    Location
    Pa.
    Posts
    1,727
    Thanks Thanks Given
    1
    13
    Thanked in
    Yes Steve you have a point. I didn't consider that.
    About TV Shows-
  16. #35
    Join Date
    Sep 2007
    Location
    Altadena, CA
    Posts
    3,809
    Thanks Thanks Given
    93
    143
    Thanked in
    Speeds at 3000 rpm. From an online ratio calculator. .82 is 22%OD; .78 is 28%OD.
    Formulas: 1-1/.78 = .28 (28%) ; 1-1/.82 = 22%
    screenshot.1745.jpg Stock BJ8screenshot.1744.jpg 3.54 axle with 28%OD or Supra 5thscreenshot.1743.jpg 3.54 with 22% ODscreenshot.1742.jpg 3.3 axle, 22% ODscreenshot.1741.jpg3.08 axle, 22% OD
    Steve Gerow
    Altadena, CA, USA
  17. The Following 2 Users Say Thank You to steveg For This Useful Post:
    Editor_Reid  (06-10-2019), Patrick67BJ8  (06-10-2019)
  18. #36
    Join Date
    Apr 2004
    Location
    Massachusetts
    Posts
    5,838
    Thanks Thanks Given
    16
    41
    Thanked in
    Quote Originally Posted by steveg View Post
    Oh, but there is:
    Haven't seen that one before. Don't see what they are using for a bellhousing. A brand new T5 is about $2,500 so they are getting a fair chunk of change for the conversion
    Rick
  19. #37
    Join Date
    Apr 2004
    Location
    Massachusetts
    Posts
    5,838
    Thanks Thanks Given
    16
    41
    Thanked in
    Was speaking to a fellow Nasty Boy owner with a Vortec 4200 motor last week. Said he's using a Chevy S10 rear end that he had cut down and axles shortened. Cost him about $650 altogether. Here's a page showing all the axle ratios and what they came in. Probably a good way to pick up a posi rear end in the process: http://www.lsxharness.com/336816530
    Rick
  20. #38
    Obi Wan Patrick67BJ8's Avatar
    Join Date
    May 2007
    Location
    Holly Lake Ranch, (East) Texas
    Posts
    2,300
    Thanks Thanks Given
    76
    5
    Thanked in
    I have a Toyota 5-speed with a 28% 5th gear ratio and a 3:54 rear end ratio. I specified the 28% 5th gear when I purchased the trans.
    Patrick
    '67 Metallic Golden Beige/Red
    Owned since '72
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
