Results 1 to 11 of 11
Thread: Brake Pads - question
Discuss general restoration and car care topics (paint & body, upholstery, woodworking, etc) as well as tools.
  1. #1
    Great Pumpkin JPSmit's Avatar
    Join Date
    Nov 2004
    Location
    Toronto, ON
    Posts
    18,460
    Thanks Thanks Given
    Thanks Thanks Received
    51
    Thanked in
    So, was watching Wheeler Dealers the other day and they were repairing a Volvo 544. braking power was an issue and Mike Brewer wanted Edd to do a disc brake conversion. Instead he put uprated pads on the drum brakes. IIRC standard pads have a braking coefficient of <2 (whatever 2 is - unicorns or something) the pads he put on had a braking coefficient of 4 - so, about 2 1/2 times the braking power. Interestingly he demonstrated this by dragging the pads across the work bench and the one was harder to slide.
    Of course I have no idea of the brand, but, does this ring a bell for anyone? Are these pads readily available? Are they customizable?
    According to the show Mike didn't realize they weren't discs when he hit the brakes on the final drive.
    Yes, I know it is TV, but, it seems like this could be a good and cheaper alternative to a disc brake swap for early car owners and, in my case, the Austin 7 is apparently notoriously under braked.
    John-Peter Smit
    1976 MG Midget
    1969 Vauxhall Viva GT
    1958 Fiat Multipla (Barn art)
  2. #2
    Great Pumpkin NutmegCT's Avatar
    Join Date
    Jul 2004
    Location
    Connecticut USA
    Posts
    11,037
    Blog Entries
    1
    Thanks Thanks Given
    43
    98
    Thanked in
    Re: Brake Pads - question
    I think you've got at least two different questions. Friction, and brake type (drum or disc).
    Increased pad friction will give you a faster stop with the same brake pedal force. But increased friction also leads to increased heat build up. If you're talking pads on a disc system, the disc system dissipates heat better than drum brakes.
    More to the point (!), if you're talking about your Austin 7, I assume it's got drum brakes, not disc brakes. So if you use higher coefficient (higher friction) shoes, you build up more heat due to increased friction. You stop faster with the same pedal force, but you're more likely to experience brake fade.
    http://knowhow.napaonline.com/disc-v...pros-and-cons/
    The bells are ringing ... Ding Ding!
    Mac & Phyllis Take a Trip: http://nutmegflyer.com/trip-details-daily-updates/
    History: 1976 MGB, 1959 Triumph TR3A, 1960 Mercedes-Benz 190b, 1958 Rambler American.
    Current: 1953 MG TD27318.
  3. #3
    Luke Skywalker LarryK's Avatar
    Join Date
    Mar 2007
    Location
    Millstadt, IL
    Posts
    1,805
    Thanks Thanks Given
    12
    Thanked in
    My drum brakes have ceramic shoes which stop as good as discs. Continual stopping can bring heat but pads can take it drums would be turned or replaced more often. Plus side of drums, no drag as discs, gas saver. Stopping power same, just heat issue. Use a drum that throws heat and ceramic pads. Drum brakes if setup properly last a lot longer than disc pads. I have 4 cars with shoes, 2 MK1 Jags, 64 Valiant, 98 Ford E350 V10 RV with shoes in rear.
    Larry K
    58 Jag 3.4 MK 1 auto under restoration, 57 Jag 3.4 MK1 manual ,
    03 Cooper S, 2011 Cooper S Countryman, 2011 Land Rover LR4 HSE LUX, 1964 Valiant V200
    Also had , 68 Cortina 1600E, 64 Spit 4 & 80 1500, 73 GT6 3, 71 XJ6, 79 XJ6, 86 XJS V-12, 53 XK120 OTS.
  4. #4
    Join Date
    Aug 2003
    Location
    Sunny So California
    Posts
    19,251
    Thanks Thanks Given
    7
    104
    Thanked in
    Ted Schumacher can reline your shoes with a "Kevlar" material that works very well on the street IMO.
    http://www.tsimportedautomotive.com/tr3_tr4a.html
    Unlike many "racing" compounds, the stuff Ted uses works very well cold as well as hot. It has a good coefficient of friction and excellent fade resistance. It also seems to be gentle on discs and drums (some friction materials cause rapid wear). It seems to wear well, IMO, not as good as some perhaps but much better than others; and I would rate dust generation as moderate.
    Another trick with drum brakes that seems to be something of a lost art these days : After relining (or even when new), it helps to have the shoes 'arced' to match the drum surface. There is a fairly simple machine that grinds the friction surface to exactly match the measured diameter of the drums. It also roughens the surface, for best friction.
    As noted, the big benefit of disc brakes is cooling/lack of fade. Until they overheat, drum brakes should give you all the stopping power you can use. That's not to say the brakes on an Austin 7 aren't poorly designed though; I have no experience with a 7.
    Randall
  5. #5
    Join Date
    Nov 2004
    Location
    Toronto, ON
    Posts
    18,460
    Thanks Thanks Given
    51
    Thanked in
    Quote Originally Posted by TR3driver View Post
    thanks for the info - and actually they are poorly designed - partly because prewar but they also have pressed steel drums.
    John-Peter Smit
    1976 MG Midget
  6. #6
    Obi Wan Bayless's Avatar
    Join Date
    Mar 2007
    Location
    Oklahoma City
    Posts
    2,457
    Thanks Thanks Given
    10
    Thanked in
    I understand that the Austin 7 doesn't have very good brakes. But go ahead with "gripper" shoes. I don't think it will go fast enough for brake fade to be a major problem. Much like my Prefect in that regard.
    Never express yourself more clearly than you can think.
    '48 Ford Prefect
    '67 Sprite (project)
    '74 Super Beetle
    '73 MB 450SE
    '04 Saab Arc
    http://enfoprefect.org
  7. #7
    Luke Skywalker Roger's Avatar
    Join Date
    May 2002
    Location
    Richmond,Texas
    Posts
    1,670
    Thanks Thanks Given
    3
    Thanked in
    J-P, you can get soft linings for your A7 brakes, most savvy owners recommend them. Your pressed drums are o.k., the main issue with A7s is the means of operation. For example, the front brake cables pull at the bottom of the backplates. The brakes come on, the axle twists forward, the cables slacken and the brakes come off.
    You'll get tons of good advice on Austisevenfriends.
    Roger
    Ancient Briton
    '67 Lotus Elan S3
    '72 Lotus Europa TC
    '05 Lotus Elise
  8. #8
    Join Date
    Jan 2011
    Location
    stamford, CT
    Posts
    2,166
    Thanks Thanks Given
    17
    Thanked in
    A soft pad will probably wear faster. Not a problem on your Austin 7.
  9. #9
    Join Date
    Nov 2004
    Location
    Toronto, ON
    Posts
    18,460
    Thanks Thanks Given
    51
    Thanked in
    Quote Originally Posted by pdplot View Post
    No doubt I could probably stick my foot out! and yes Roger have discovered austinsevenfriends. Almost got to meet one in Guernsey a couple weeks ago but we connected too late
    John-Peter Smit
    1976 MG Midget
  10. #10
    Join Date
    Jun 2019
    Location
    Sioux Falls, SD
    Posts
    2
    Thanks Thanks Given
    Thanked in
    The numbers the show referenced are coefficient of friction - called mu.
    The coefficient of friction (COF) is a number that determines the amount of friction between materials in contact. It is often designated by the Greek letter mu (μ)
  11. #11
    Join Date
    Nov 2004
    Location
    Toronto, ON
    Posts
    18,460
    Thanks Thanks Given
    51
    Thanked in
    Quote Originally Posted by Koop View Post
    helpful - thanks
    John-Peter Smit
    1976 MG Midget
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
