More Sprite progress finally
Bayless
Been waiting for days or maybe even weeks for two consecutive dry days to get some paint on. Meanwhile, we have been working on, trying to salvage the wiring harness. It's not too bad although most of the original woven cover is gone and replaced with friction tape. There are also a few pretty ugly "customizations" that need to be repaired. The dry days finally came. Or at least the first one did and the forecast for tomorrow is still promising. I managed to get some white epoxy on the entire bottom, including the repaired wheel well. More importantly, I also get that ugly red paint resolved in the engine bay. Now with any luck and assuming my back recovers enough, I will get some of the lovely primrose to cover the primer. Then it comes down off the rotisserie to start assembly. Yes, that is the wheel well and spring hanger box that got all the welding and new metal. Will try to post more tomorrow if successful.
JPSmit
looks great!
drooartz
Looking good. Nice to see someone making progress. My poor Penny looks reproachfully at me each time I step into the shop... :grin:
Bayless
Bayless
Ok, I actually did get it painted yesterday but something, I guess the combination of the flourescent lights and the grey background, fooled my phone camera and made the car look green. Went back today with a real camera and got better results although still a little greenish that I have tried to correct a little bit. Got a closeup of the wheel well that had to be repaired and a couple of others. I think I might be getting a little "long-in-the-tooth" for that much work on two consecutive days. Then again, it is now the third day and is starting to rain with storms to follow shortly.
nomad
Primrose has always been a favorite of mine. Looks good!
Kurt
Bayless
Bayless
Hey, glad to hear there are other who like the color. SWMBO says it is "nice but wouldn't paint her car that color."
Bayless
Bayless
So I spent the better part of last week sanding and stripping the rattle can primer from the interior. Then I primed it Saturday and painted yesterday. I think I'll do the brake line and fuel line to the rear then get it off the rotisserie and start assembly of the many bits that are ready.
glemon
My first three cars were originally that Pale Primrose color. The first was painted before I bought it, the second and third I painted red and green respectively. As a young buck my sports cars had to be bright color. Now I really like the light yellow, and you don't see it as often. Looks good.
Bayless
Bayless
Thank you. Been working on the brake lines and fitting the wiring harness, both seem to be slow. Hope to get off the rotisserie soon and start assembling suspension. Then have to buy some tires.
Bayless
Bayless
Back on the jack stands today. Will start installing suspension parts Monday. Only thing holding that up right now is a pair of back ordered brake return springs. Wheels are already painted and may go for tires the following week. OTOH, I may have access to a set of Minilights (copies) at a reasonable price. We'll see if that works out.
I have a pair of taller jack stands that I will put under the rear bumper brackets and remove those at the spring hangers. That should make room to work and avoid too much rear weight while building.
Jim_Gruber
Be sure and get the front jack stands up front under the frame rails. That place where you have the Front jack stands situated is just about the balance point for a Spridget. I was underneath my '68 one time, jack stands where you have them and rear stands under the rear axle. Engine in and rear end installed. I grabbed the body to pull myself out from under the car only to feel the back end come up and about 6" off of the jack stands before I let go and pushed back up. A scary moment. Install the front suspension before you decide to hang the rear end. You'll need access from the rear with the floor jack to get the rear end installed. I did it by myself but safer with a second pair of hands.
Bayless
Bayless
I appreciate the advice Jim. It will be a while before the engine but I agree. The front jack stands need to move forward a little. And I do have help with the rear axle.
Bayless
Bayless
More work since the last post. Front and rear suspension completely installed. Brakes installed except for the master cylinders which are next. Fuel system finished as far as can be until the engine is installed. First problem at the back was the right shock. It would interfere with the fuel pump outlet so the mounting bracket had to be modified. Next problem was getting the rebound straps installed. Had to mount two slightly over weight guys (myself included) on the very back to compress the spring enough. Next problem was the rear brake hose. It would interfere with the inlet hose at the fuel pump. Had to change to a remote filter and modify the pump mount yet again. Only real difficulty at the front was getting the lower control arms installed and it was a challenge. Then after helper had installed the brake calipers, I discovered that I have two left and no right. Apparently the car ran that way before so I will give it a try. I figure if I have to I can unmount the right one and hold it upside down to bleed it. Outcome of that is yet to be known. Here is the latest iteration of the fuel pump/filter system and one of the front suspension. That really is kinda pretty I think even though it may be hard to bleed.
Jim_Gruber
No front sway bar? Ask this list and other forums if they ha e one available from a parts car rusting away in their back yard. Update bushings and links and it will bolt right on. If you are planning on a front tilt bonnet, those towing eyes may or may not work. I have a set for Bugsy I hope to add on the outside of the frame rails.
otherwise really looking good��
Bayless
Bayless
Thanks but can't do a front tilt Jim. This is a MkIV. I have a sway bar but the control arms are not drilled for it. Waiting until on the ground to get it all lined up right to drill.
Jim_Gruber
Sure you can do a front tilt on a Mk IV. I did it with Bugsy I. Oh you do need a BE Bonnet but I did it.Bugsy 3rd Coat 2 - small.jpgBugsy Rebuild 04 05 09 - Kentucky Chromed Grille.jpg
Bayless
Bayless
I stand corrected. That would be fun and give you the best of both too. Yours looks nice Jim.
Jim_Gruber
That was Bugsy I sold to Alan Fisher up in New Hampshire. It does provide the advantages if roll up windows, a trunk, and a top that can be put up rather than erected. And most people think it is a BE. But Bugsy drives and handles so much different. I’ll leave it at that. Your Mk IV will be gorgeous when done.
Bayless
Bayless
Ok, got a set of Kumho 155 tires. Got the blanking plugs installed for the lower trunions. One side had a burr inside the control arm that had to be ground away to get it to fit. Set it on the ground. Whoo Hoo but she does look small now. Oh, the lights in the rear are just in temporarily for testing. I sure wish the flourescent lights in the shop didn't play such tricks with my camera. Most of the photos come out actually green and I try to adjust best I can.
Oh, almost forgot, I just ordered my Rivergate 5 speed kit. Will said he probably can't ship it until Monday so should have it by later next week.
jlaird More Holy Sprite Spridgets 8
Bayless More Prefect Progress Other British Cars 2
B MGB while driving engine cuts out if I let off or push more throttle it comes right back on MG 5
C MGB More Weber help needed MG 27
DrEntropy More lessons in Japanese engineering Other Cars 7
KVH General Tech More Technical Questions—TR4 Triumph 5
KVH General Tech Heater and Vent Control Cables--TR2 thru TR4, and more . . . Triumph 3
KVH General Tech More Engine Rebuild Questions Triumph 15
AngliaGT A Few More Spotted 6
AngliaGT Saw a Few More Spotted 0
Bob Claffie More Village pics Other British Cars 0
Bob Claffie More Village pics Other Cars 3
M TR6 More noob questions… Triumph 14
Bayless More Paint Other British Cars 3
AngliaGT A Few More Local Vehicles Spotted 5
Basil More BMW Z4 trials Other Cars 21
AngliaGT A Few More I saw Yesterday Spotted 10
SteveTheBrewer Spitfire More rust repair Triumph 1
AngliaGT A Few More along Highway 220 Spotted 3
Bob Claffie More pics from Falls Village Festival Other British Cars 3
Sherlock Another cruise night, more interesting British iron Spotted 2
Y MGB More things that seem odd.... MG 2
D TR2/3/3A More Fuel pump questions. Triumph 10
jlaird MGB More on Bee's status MG 6
AngliaGT A Couple More Spotted 0
tr6nitjulius TR6 TR6 meeting my Demands & Giving Back more! Triumph 2
tr6web TR6 More leg room needed Triumph 5
Got_All_4 For Sale Brake caliper pistons Ceramic Coated and more Triumph Classifieds 0
Nelson No more MG Midgets Spridgets 3
HealeyPassion Getting a bit more space for triple Webers... or EFI Austin Healey 3
K TR2/3/3A Auxillary Carb Return Spring in More BS about TR's. Triumph 0
K TR2/3/3A More pics of Kast Cam Triumph 4
K TR2/3/3A TR3A SU's More Pics Triumph 0
Ripper01 For Sale more TR-6 Used Parts Oct 2019 Triumph Classifieds 0
lbcspinners A- H Frog E: no more Bugeye oil leaks! Austin Healey 4
7 No more Bosch tools for me Restoration & Tools 4
D TR2/3/3A More small nuts [ and studs!] Triumph 2
C TR6 More fun with Lucas Triumph 5
Bayless Even more progress - the Prefect Other British Cars 5
maxwedge5281 one more time.....mirrors! Austin Healey 14
Bob Claffie T-Series More or less TD action MG 0
R More Shroud to Scuttle install Austin Healey 4
Y MGB Answer to a question creates more new questions.... MG 12
K TR2/3/3A Auxillary carb return spring in "More BS about TR,s" Triumph 9
S TR2/3/3A little more door gap Triumph 14
Michael Oritt Replacing timing chain tensioner and more Austin Healey 24
T How to add a bit more realiability/endurance to a stock 1275 engine rebuild? Spridgets 9
D BT-7 tri-carb Two more questions Austin Healey 18
R TR2/3/3A One more crank pulley question Triumph 7
K TR2/3/3A More electrical....the Starter? Triumph 8
