Getting Ready for Winter
Rob Glasgow
Not really. There's too much top-down weather ahead. But I finally took some time to work on the hardtop so it fits better. When I restored in 13 years ago, I used to weather stripping that came with the kit and it always sat too high, creating issues with the side curtains and left a large gap behind the door. The hardtop did not come with the car, so like many body parts, did took some work to get it to fit. But by removing the thick weather stripping and adding just enough in certain areas to close the gaps, it now fits much better and the side curtains seal as well as can be expected.
So I guess I'm ready for winter when it comes.
But for now, it all comes off and returned to storage. Just too beautiful of ride inside.
gonzo
Healey looks great both ways! Wonderful color combination. Install air con and enjoy year around top-up comfort - central coast can get toasty hot (Solvang, SLO Paso Robles etc.) :wink-new:
Healey Nut
Looks good . My 62 Tri-Carb rally recreation will be similar but OEW top with correct rally flip up air vent .
The white on your car is very white
Rob Glasgow
Rob Glasgow
Healey Nut, I tossed and turned quite a bit over the decision to go white or blue for the top. In The end, I decided for the road less traveled and am happy with the decision. Although, white would certainly have been my choice if I had painted the car solid blue.
Gonzo, yep an AC unit would be a great addition. Before moving to the central coast, I lived in The Central Valley of California, and I used to drive home from work in 100 plus temperatures and always wished for an AC, but I just sweated it out. With all the insulation I put in during my restoration, even in the with the warm weather we have here it's not to bad.
dougie
Ready for winter or a wet day at the track......
RAC68
Hi Rob,
Boy, your Healey really looks great...good taste. I always liked the hardtop on the pre-BJ8 Healeys and was sorry that the BJ8 hardtop was not as available.
John,
A Healey with air conditioning was never a need for me but my wife would have loved it. I had my Healey shorts and sandals and was good to go anywhere.
I have a TR7 that had a piston-type air conditioning compressor that I eliminated. Not long after, I also eliminated the engine fan and now depend upon the 2 air conditioning fans mounted low in front of the radiator and on an upward angle (allowing direct unimpeded air flow when driving). I had considered mounting a set of these fans in the same manor in front of my Healey radiator and going back to my original anemic yellow fan for looks alone. Maybe one day.
Healey-Nut/Dougie,
How did you implement your front pop-up air vents on the front shroud. I appreciate that there is a cut-out under the shroud for that purpose but how did you seal and allow rain water to drain off? Are there plans for this vent?
All the enjoyment potential using your Healeys,
Ray(64BJ8P1)
Healey Nut
Im unsure about doing the air vent on the shroud . The car wont be driven in the rain but it will be nice to get some more ventilation air in the car as the hardtop will always be on .
I have one of the original pop up rally vents for the hard top that will get installed in the top and I may see about incorporating extra forced draft air vents into the scuttle area and footwells that would then exit through the roof vent .
I will never consider or add A/C to a Healey thats just not for me .
Keoke
I am just womdering how much these type air vents help wehen ambient temperature is 115 degrees ?
Rob Glasgow
Rob Glasgow
Keoke, just turn up your house heater to 90 degrees and turn the fan on high and stand in front of the vent. That's just about as much cooling as you'd get. Hot air doesn't become much cooler when you increase the velocity. That being said, as a youth, we would roll the windows down in the car and ride in the back of the car and think the how much cooler it seemed. So maybe it appears to work.
Healey Nut
115 degree ambient the Healey will stay in the garage and I will take the Aston instead .
steveg
Keoke - How relevant is talking about driving a Healey on a 115 degree day?
More relevant is how the vent works on a normal warm or hot day. I'll bet the air is closer to ambient than the recycled engine air entering through the "cold air" vent. Lots of cars in the '40s used pop-up vents in front of the windshield.
Rob Glasgow
Rob Glasgow
I always thought the opening vents on the side of the fenders were pretty cool looking. I had an old Chev truck that had them and IIRC Studebakers and maybe XK120's did too.
Keoke
That's what I wuz talking bout a normal "warm or Hot day."
Here in the valley that is easy to come by Steve.
Healey nut U got it right.
Rob Glasgow
Rob Glasgow
After I posted the comment about XK120's having side vents, I looked at several photos of those Jags and it seems they only put the vents on the driver's side. I guess the passenger was not worthy.
Bob McElwee
If it was like the Healey with the exhaust on that side it would help keep either the driver/passenger cooler depending on which side the steering wheel was on.
healeyblue
Jags have the vents on both sides. I have never seen one with just a vent on one side. I am restoring a 120 right now and have researched them a lot so I am sure they never put them just on one side. As for the hard top I agree that if going solid blue then a white top looks the best.
V Getting ready for Spring Austin Healey 6
X getting ready for bodywork and paint Spridgets 11
cbrvfr Getting ready for a 1200 mile trip in the BN4 Austin Healey 26
G Wash...Wax and getting ready ! ! Triumph 2
T Still getting ready for Triumphest... Triumph 5
tahoe healey getting ready for post paint restoration Austin Healey 5
Brosky Getting head ready to install Triumph 19
JPSmit Getting ready for the Ozarks trip? Spridgets 10
Stinky Getting ready for Good weather Triumph 5
Patton Paint and Body -Getting it ready to send it off Austin Healey 10
S TR2/3/3A getting the circlip off 3rd gear Triumph 9
Celtic 77 MGB Getting closer! MG 5
J Finally getting (re) started on the Bugeye Spridgets 27
JohnGone MGB Help getting my 1980 MGB to pass CA smog test MG 19
J TR4/4A Getting electrical shock from horn button when using the horn. Triumph 9
D TR2/3/3A Getting difficult to start. Triumph 6
S TR2/3/3A problems getting the engine to run correct Triumph 21
J MGB 73 getting loud squeal with acceleration MG 11
steveg Toyota W58 Trans Hard Getting Into Gear Austin Healey 8
M Getting behind the dash on BJ8 Austin Healey 4
John Turney Getting Speedometer out of the Case Austin Healey 6
tr6nitjulius General TR Part 4 What We Missin' we getting closer Triumph 0
HealeyPassion Getting a bit more space for triple Webers... or EFI Austin Healey 3
BoyRacer Need Tips on getting wiring harness through firewall Austin Healey 4
J TR2/3/3A Finally getting started Triumph 20
glemon GT6 GT6 Getting Some Recognition Triumph 8
K TR2/3/3A Dismantling Speedometer...getting the odometer pin past the case??? Triumph 2
D Getting closer... Spridgets 2
RAC68 3D Printing Getting Closer Austin Healey 16
bighealeysource Getting rid of pesky rubbing/polishing compound overspray Austin Healey 5
Jagguy MGB Ignition timing issues....I'm getting confused! MG 16
steveg Really Getting Into one's Healey Austin Healey 17
M TR5/TR250 problem getting engine running Triumph 15
simon1966 Seats upholstered and the shrouds getting cracks fixed Austin Healey 9
Jim_Gruber Brake Light - Getting them working Spridgets 8
Darrell_Walker General TR TR3A on Comedians in Cars Getting Coffee Triumph 7
S TR2/3/3A getting a new multi meter Triumph 9
gbtr6 TR6 Getting frustrated getting my TR to run properly Triumph 17
RickB MGB Rain water getting inside behind dash MG 17
drambuie Getting more horse power from a Healey 100 Austin Healey 63
J TR2/3/3A Joe the TR3 Guy getting started with suspension Triumph 4
Jim_Gruber 1/4 Elliptics- Getting the Bast__rd Apart Spridgets 22
steveg HD8s - getting below 1000 rpm idle Austin Healey 4
steveg Unable to edit posts, getting a wierd message FORUM Navigation Questions 2
RickPA Getting back in the game Austin Healey 5
D Getting hot in the car [AH3000mk3] Austin Healey 6
Got_All_4 General Tech Getting the nut off for J Type drive shaft flange Triumph 3
T Spitfire Randall - anyone you would recommend for getting a driveshaft shorted in SoCal Triumph 4
Jim_Gruber Help Needed, getting those 1/4 Eliptics out of the spring mounting box Spridgets 24
B TR2/3/3A Is a 63 TCF probably needing total restoration worth getting into? Triumph 16
