TR2/3/3A Brake lines
karls59tr
Bronze
Doh! I was installing a stainless steel rear brake hose when I cross threaded the line connector at the rear brake hose. It connects the hose to the long brake line that goes to the 4 way junction box at the front of the car. Anyone know if I would be able to find a similar brake line from a shop that would match up to car this old? Cant tell if the line is single or double flared. Looks like SAE maybe 3/16" or 1/4".
Alternately I guess I could remove the entire line,cut the line and remove the offending connector. I have a spare Master cylinder "pipe assembly" that has a connector on it that is the same as the cross threaded one that I could cut off and use. I could borrow a pipe flare kit, and install the good connector to the line. I was just wondering if it would be possible to buy a generic brake with the correct fittings already on it that would match up. Anyone know if if a modern brake line would match up???
TR3driver
Great Pumpkin - R.I.P
Girling used a special nut pattern, you have to get the extended tip on the nut as well as the correct threads and pipe size. Using American pattern nuts may appear to work, but the joint will be prone to leak and may break the fitting when you over-tighten it in an attempt to stop the leak.
K
karls59tr
Bronze
So An American brake line wont work because of the Girling special nut pattern. Where do I get a single Girling brake line? or do I have to cut the existing brake line, install the spare connector I described and flare the old brake line?
Sarastro
Fedhill http://www.fedhillusa.com/ has this stuff. My only problem with them has been the occasional English-sized part with metric flats, but if you can live with that kind of thing, they have all you need.
LAW75 BJ8 Brake Lines Austin Healey 2
T Wedge TR7 brake hard and flex lines - fittings Triumph 12
P Classic Tube Pre-Bent Brake Lines Austin Healey 5
nichola TR6 Grrr, again, this time brake lines Triumph 18
J TR2/3/3A replace brake and fuel lines? Triumph 4
B TR2/3/3A Bubbling in brake reservoir. No pressure in lines Triumph 5
T Assistance with Front Brake Lines Spridgets 3
glemon General Tech Nickel Copper Brake Lines Triumph 10
D new brake lines Austin Healey 23
Jim_Gruber What is the correct tool for removing brake lines from a BE Master Cylinder Spridgets 10
Jim_Gruber Brake Lines for Bugsy - What do I need for a Flaring Tool / Rear Discs for Bugsy Spridgets 39
W BN1 vs. BN2 rear brake lines / pipes Austin Healey 4
GTP1960 TR2/3/3A Question on replacing brake lines & converting to Dot 5 Triumph 9
M Front steel brake lines Spridgets 9
maxwedge5281 redoing brake lines Austin Healey 3
D Brake/clutch lines Spridgets 14
A TR2/3/3A TR3 Brake / Clutch Resevior & Lines needed Triumph 2
Rob Glasgow Brake/Clutch Reservoir Lines Austin Healey 9
S Healey brake lines Austin Healey 7
C question on the front brake lines for BJ8 Austin Healey 2
nevets pre-bent brake lines Austin Healey 7
J BN6 / Smash my fuel and brake lines.. Austin Healey 5
TulsaFred Brake Lines Spridgets 34
S TR2/3/3A rear brake lines tr3 Triumph 3
D brake lines Austin Healey 2
D flexible brake lines Austin Healey 4
middie Flush out brake lines/pipes Spridgets 13
PatGalvin Tie Down Those Brake Lines to the Diff Triumph 4
T Anyone use Poly-armour or Cunifer brake lines? Triumph 2
Sarastro Tool for making bubble flares on brake lines Restoration & Tools 14
S MG brake lines MG 1
PatGalvin Test New Brake Lines Triumph 4
PatGalvin New Brake Lines Question Triumph 5
PatGalvin Routing brake lines for Toyota 4 pot conversion Triumph 5
T Flushing brake and fuel lines Triumph 3
rjc157 healey 3000 brake lines Austin Healey 2
T Recommendations on stainless brake lines Spridgets 13
M Help needed to ID brake lines Triumph 5
T TR4/4A Stainless steel brake lines for a TR4a Triumph 12
drooartz Actual progress -- brake lines done! Spridgets 13
D Replace brake lines BT7 Austin Healey 7
Basil New Brake Lines are here Jaguar 16
D BN2 brake lines Austin Healey 6
S TR2/3/3A brake lines and rubber bumpers tr3 Triumph 12
T Let's talk about stainless steel brake lines... Triumph 4
drooartz Brake and fuel lines in Spridgets 2
Tinkerman Testing Brake Lines? Triumph 1
drooartz Progress: brake lines Spridgets 4
drooartz Brake lines -- wrong parts! Spridgets 16
I Help ordering brake lines for Bugeye Spridgets 7
