New cylinder heads
Michael Oritt
Roughly 15,000 100's were made. I assume the head would also fit Atlantics and perhaps other models as well. In any case, given the relatively small number of engines produced and cars remaining in operation it is an interesting commentary upon the durability of the iron head--or lack thereof--that three or four suppliers have each gone to the trouble and expense of designing, tooling up for and producing a proprietary replacement head. Certainly it is an expensive adventure and the heads are high-$$ items, yet each producer obvioously plans to make money on the venture....
DTDuck
It is not a comment on the durability of the original iron head 4-cylinder 100, it is a plain fact. The old joke it that there are only two kinds of 4-cylinder 100 Heads, those that are cracked and those that have not been checked. Not sure if it was the quality of the materials, casting process, design or some combination of all of the above, but an original cast iron head that is uncracked is a true unicorn. Hence the demand for a replacement. As to the original question of why would you want a CI head when Aluminum is available, I can't give a rational answer other than originality, although even that seems odd for a replacement part.
Dan M.
John Turney
I recall reading that some vintage racing organizations require the heads be of the original material. Other than that, ....
Bob_Spidell
Wow ... the dyno results are impressive--6-cyl numbers on 4-cyl engines. I see some 'tabs' sticking out of the gasket around the number plate, where they often leak. Anybody know the story?
Michael Oritt
Perhaps I should not have pulled my punch, and clearly these suppliers are looking into the future and seeing a viable market in the heads that have either not yet cracked or been crack-tested. It is simply surprising the number of sellers given the relatively limited number of potential purchasers, but as the value of 100's goes up the likelihood that someone will spring for an alloy head no doubt increases.
I replaced my iron head with a DW AL "fast-road" head in 2001 when I blew a head gasket as a result of the erosion of the bridge between cylinders 1 and 2, probably the result of pre-ignition or bad casting or both.
As to why AH Spares offers to sell an iron head I believe John is correct and the organizations with which I race prohibit alloy heads in place of stock iron ones.
I don't know what the rules are for UK/EU clubs where Healeys are way more actively raced than in the USA.
Bob_Spidell
Every once in a while I remind myself how lucky we are to have suppliers like DWM, AHSpares, etc. along with great mechanics and advisors like Tom M, David N, etc. We are truly blessed.
On the latest episode of 'Wheeler Dealers' they fixed and flipped a J-H. Mike went back to England to get some parts, and visited a large shop where they were making body panels for several LBCs (probably dropped in on his wife too, methinks). I thought maybe it was DWM, but they had the logos blurred out--why???--and I don't think DWM does body panels for J-Hs.
DerekJ
Interesting development. Cast iron heads had become so rare that UK competition rules were amended to allow alloy heads, as racers complained they could not find any iron replacements. I think this also applied in FIA sanctioned events.
The graph shows a pretty aggressive peak power number of about 150bhp which is about what the top 100 race engines are producing over here. You will not get that simply by bolting this new head on to your standard car.
vette
About the only advantage that aluminum heads have over iron is heat dissipation. Admitably that is a BIG advantage when considering compression ratio, timing flexibility and overall performance. But iron heads have their own set of advantages as well: 1. material stability there-by reducing head gasket problems. 2. no adverse reactions to anti-freeze engine coolants. 3. Generally longer life especially in normal non-competitive, street driving. If you have aluminum heads you should check the bolt torque reqularly and at least change your anti-freeze more often. I believe the three biggest reasons that manufacturers will produce the aluminum heads is because 1. they are cheaper to produce, 2. the market wants them (oh god ya gotta have an aluminum head), 3. The sanctioning bodies allow them. One last commentary, I had a new engine built a few years ago ,by a professional race engine builder, for my '70 Vette. It is a roller cam, roller rocker, 383 cu in stroker small block. It dyno'd at 467 hp. I specified Iron Eagle 180 Iron Heads. I specified the 180 runners verses the larger sets because of the theory of velocity over volume. I specified the Iron heads because I told the builder that even though I want high power that since this was strictly a street driven car I want to never touch this engine again after I install it in the car. Long term durability that's why I use Iron.
DerekJ
Vette, aluminium heads are considerably lighter and removing all that weight from high up in the front improves handling.
Racers won’t want to switch back to iron unless forced to.
I don’t understand those torque and power curves as they don’t cross at 5252rpm.
Bob_Spidell
So, you're disputing AHS's claims?
"Significant BHP and Torque power gains when tested on our development engine using H4 carburettors and all standard engine components including the O.E. cast iron exhaust manifold and a slightly higher compression ratio. "
vette
Derek, I agree with you. Those are all good reasons for using them in racing applications.
CraigC
Bob, those tabs are the telltale sign of a MLS-type head gasket
being used. There will usually be two tabs on each side where the multiple layers are riveted together.
CraigC
Derek, 150 is the torque not the HP. HP numbers are on the left side of the graph and in this case it is 111 HP.
The use of dual graph graduations will also explain why the curves do not cross at 5252 rpm. Even if they used a single shared graduation, the curves would not cross as they only go to 4500 RPM.
DerekJ
Thanks Craig,
Apologies all round for my inability to read a graph properly!����
That explains both my queries, so Bob I’m no longer disputing the numbers.��
edit..seems like my keyboard emojis don’t work and I get question marks instead!
BN6 Austin Healey 3000 Cylinder Heads Austin Healey 19
K GT6 Triumph Spitfire Cylinder heads.... Triumph 2
K TR2/3/3A Cylinder Heads Triumph 2
D MGB MGB Cracked Cylinder Heads Question MG 4
V Are 1275cc cylinder heads date coded? Spridgets 5
RedTR3 TR2/3/3A TR3 Cylinder Heads Triumph 10
R Lead-Free Cylinder Heads Austin Healey 10
M Performance Cylinder Heads MG 3
K TR2/3/3A Retorquing the Cylinder Head after the initial torquing.? Triumph 12
S TR2/3/3A Rebuilding a cylinder head Triumph 10
petnatcar Cylinder Head Nuts - Tightening Sequence Austin Healey 2
L Removing Master Cylinder Without Paint Damage Austin Healey 27
K TR2/3/3A Checking a cylinder head with a straight edge to see if it's warped? Triumph 22
K TR2/3/3A Cylinder Head Bolt question.... Triumph 3
W Cylinder compression Hillman super minx Other British Cars 15
Celtic 77 MGB Mystery cylinder head attachment. MG 4
K TR2/3/3A Cylinder head removal and valve adjustment Triumph 2
Donald1107 TR2/3/3A low cylinder compression Triumph 12
6 Master Cylinder Rebuild Spridgets 6
K New Clutch Master/Slave Cylinder Austin Healey 1
D TR2/3/3A cylinder head oil plug bolt size Triumph 6
nichola TR6 Hot spot on cylinder head - 1973 TR6 Triumph 2
wkilleffer MGB 1974 MGB clutch master cylinder questions MG 1
Racer-X- Frame mounted power brake pedal/booster/master cylinder kits for RHD cars? Restoration & Tools 1
S TR2/3/3A rear wheel cylinder Triumph 1
AUSMHLY Reduced-Shank Cylinder Head Studs Austin Healey 0
AUSMHLY Cylinder Head Studs Austin Healey 3
AUSMHLY Cylinder Head Input/Exhaust Circlip/Split pin Austin Healey 3
Got_All_4 TR6 Which Clutch Master Cylinder Fork is for TR6 Triumph 4
bighealeysource Master Cylinder Installation Austin Healey 9
bighealeysource BN2 Master Cylinder Austin Healey 91
prb51 100-6 Brake Master Cylinder Bore Austin Healey 5
bighealeysource Brake Master Cylinder Austin Healey 27
KVH General Tech Rusted Cylinder Head Freeze Plug--WOW Triumph 16
AUSMHLY BJ8 Cylinder Head Installation Austin Healey 6
A Brake Master Cylinder Freeplay Austin Healey 11
SNClocks Master Cylinder Bore Diameter Spridgets 0
W replace rigid master cylinder lines with flex. Spridgets 2
T TR2/3/3A cylinder head ,valves and springs Triumph 0
K TR2/3/3A Oil leaks at two front cylinder head studs? Triumph 3
AUSMHLY BJ8 Cylinder Head Re-Torque Austin Healey 26
6 Master Cylinder Actuator rods Spridgets 2
BoyRacer 6 cylinder flywheel on a 100 engine? Austin Healey 0
6 Master Cylinder Install Spridgets 5
Patrick67BJ8 Cylinder Compression Checks Austin Healey 30
S MGB Mgb with nissan cylinder head. I am a new member, introduction and help MG 1
R TR6 Rear brake wheel cylinder fitment Triumph 5
rgfrey Bench Bleeding Brake Master Cylinder Austin Healey 2
K TR2/3/3A Clutch "Long Throw" Slave Cylinder? Triumph 4
