Results 1 to 9 of 9
Thread: Turn signal flasher??
Discuss the Austin Healey Sprite and the MG Midget. Two different but similar cars sometimes referred to collectively as the Spridget.
  1. #1
    Join Date
    Dec 2008
    Location
    South Dakota
    Posts
    3,885
    Thanks Thanks Given
    Thanks Thanks Received
    Thanked in
    Just changed flasher unit's in my Mk3 Sprite. The one a PO fitted flashed really fast so I changed to an old one I had lying around. Flash speed is now right but my dash indicators now only give a single flash and that is it. Any idea's???
    Kurt
    65,66 Midget
    57 Berkeley, MGA
    Working on quality rather than quantity
  2. #2
    Jedi Trainee Joe Schlosser's Avatar
    Join Date
    Jul 2015
    Location
    Chester NY
    Posts
    297
    Thanks Thanks Given
    6
    Thanked in
    Re: Turn signal flasher??
    Would love to have tha answer to that. By signals flash on BE but dash lamp only flashes once for the right one. I have been trouble shooting for several years byt no luck. Only thing left is to change the lamp holder.
    Joe Schlosser
    SCCA National License, Retired
    60 Bugeye, since 1966
    SCCA FP, sold but not forgotten
  3. #3
    Yoda Jim_Gruber's Avatar
    Join Date
    Dec 2006
    Location
    Riverview, FL
    Posts
    5,371
    Blog Entries
    2
    Thanks Thanks Given
    2
    Thanked in
    Clean off the green. Polish up those connections.
    Jim Gruber - Tampa/Riverview FL
    Bugsy I - '68 Sprite w BE Bonnet - Gone but not forgotten
    Bugsy IV - '60 Bugeye - 1,275+.040 and a 5-Speed - CA Car - 2nd Owner from new -
  4. #4
    Join Date
    Dec 2008
    Location
    South Dakota
    Posts
    3,885
    Thanks Thanks Given
    Thanked in
    Suppose that is it? They flashed with the flasher that was on the car. Just way too fast.
    Kurt
    65,66 Midget
    57 Berkeley, MGA
  5. #5
    Yoda dklawson's Avatar
    Join Date
    Mar 2005
    Location
    Durham, North Carolina, USA
    Posts
    6,063
    Thanks Thanks Given
    39
    Thanked in
    Traditional flashers are thermal/current actuated switches. Because of that, if you have the wrong light bulbs installed (too many or too few Watts) then the flasher will operate at the "wrong" speed or not at all.
    Does your car use the 3-terminal or 2-Terminal flasher? On 3-terminal installations, one terminal is specifically to drive a single dash mounted indicator light. I have see a couple of different wiring schematics for the 2-terminal flashers.
    Doug L.
    '64 Morris Mini Cooper-S 1275
    '67 Triumph GT6 Mk1
  6. #6
    Join Date
    Dec 2008
    Location
    South Dakota
    Posts
    3,885
    Thanks Thanks Given
    Thanked in
    Three terminal, Doug. They flashed way too fast with the flasher the PO fitted. Car is a Canadian spec with bulb's that draw more current than US so no surprise with the speed.
    Kurt
    65,66 Midget
    57 Berkeley, MGA
  7. #7
    Join Date
    Mar 2005
    Location
    Posts
    6,063
    Thanks Thanks Given
    39
    Thanked in
    With the 3-terminal flashers make sure you have:
    Green/Brown on the "L" terminal,
    Green/Purple on the "P" terminal, and
    Green on the "B" terminal (or "X" for an aftermarket U.S. flasher).
    "B" is power in from the battery typically after passing through the hazard switch when fitted.
    "L" is for the 'load'... the signal bulbs.
    "P" is for an output dedicated for the indicator bulb in the dash.
    Doug L.
    '67 Triumph GT6 Mk1
  8. #8
    Join Date
    Dec 2008
    Location
    South Dakota
    Posts
    3,885
    Thanks Thanks Given
    Thanked in
    That could be wrong. I do remember it was wrong on my MGA years ago and gave me fits. I'll check it out.
    65,66 Midget
    57 Berkeley, MGA
  9. #9
    Join Date
    Mar 2005
    Location
    Posts
    6,063
    Thanks Thanks Given
    39
    Thanked in
    The MGA should have the same flasher wiring. For a refresher on what's supposed to be happening, see the link below to Barney Gaylord's MGA Guru website and his pages about the flasher.
    https://mgaguru.com/mgtech/electric/et104.htm
    To clarify my earlier post, the load wire on "L" is supposed to be "light-green/brown" while the supply wire in on the "B" terminal should be a darker green. The indicator lamp wire may also be considered "light-green/purple".
    Doug L.
    '67 Triumph GT6 Mk1
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
