Whenever I check the carbs on my BJ8 I notice that the piston and the air filter on the rear carb has a film of oil on it and the plugs for the rear bank of cylinders are usually blacker than the front. I guess this is caused by oil mist coming in from the breather pipe connecting the air filter to the valve cover.
So I've been thinking of fitting a catch tank. My question is, how big do they need to be. I don't have a lot of room in the corner behind the rear carb and I've found quiet a compact looking catch tank on Ebay which would easily fit in the chassis void under the air filter. It holds 2 fluid ounces (Imp). My car doesn't seem to use much oil. I do about 2000mls a year and very rarely have to top the sump up, I think I only did it once last year with 1/2 litre in all.
Has anyone else tried this out? Does anyone have any advice as to whether this is likely to cause any problems.
Thanks
Thanks
AJ
