windshield wiper motor rubber mounting grommets
BoyRacer
Have new mounting grommets. I'm finding it impossible to get them into the holes in the bracket. The rubber won't compress enough. Any ideas?
Lin
They are a royal pain in the __s! I used generous amounts of Dawn liquid soap and a dull screwdriver.
Good luck, Richard!
Lin
RestoreThemAll
Maybe I should be embarrassed to say...that I cut mine in half. One half on top, one on bottom. It worked but I haven't used the wipers.
Rob Glasgow
I resorted to the technique Dale used. I'm kind of surprised the suppliers haven't addressed this problem already. There have been posts about the installation problem for years.
steveg
I cut them like this. Mounted the motor a couple of years ago and working fine.
Suggest blue loctite on nuts so they don't have to be too tight.
BoyRacer
BoyRacer
A diagonal cut from top to bottom, on the side, as suggested by British_Recovery, is the way to go. With the help from some soapy water and a pair of pliers, I was able to "screw" it into the hole just as he said.
bob hughes
I did mine by using some stout string and plenty of lube, wind the string around the middle section pass it through the hole from the top and and pull down on it whilst trying to press the rubber in from the top and twist the rubber as you do it, seemed to work for me. I did have the seat out and was lying on my back with my feet dangling over the back of the cockpit.
:cheers:
D TR5/TR250 Windshield wiper motor Triumph 9
R grease for windshield wiper motor- BJ7 Austin Healey 4
P Bugeye Windshield Wiper Motor Spridgets 3
T TR2/3/3A Windshield Wiper Motor Grease Triumph 4
P windshield wiper motor Triumph 14
TraceZ how to remove windshield wiper motor. Spridgets 7
G Windshield wiper motor MG 16
KVH TR4/4A TR4 Windshield Wiper Motor Issue Triumph 8
Tinkerman Lucas windshield wiper motor DR-2 rebuild? Triumph 9
R BJ-7 windshield wiper motor wiring problems Austin Healey 3
G TR2/3/3A TR3A Windshield wiper motor...any help? Triumph 2
V Windshield Wiper Motor Jaguar 3
V Windshield wiper motor Jaguar 8
kcbugeye1275 Windshield wiper motor Spridgets 7
J windshield wiper motor Triumph 1
W Windshield / Windscreen Wiper Motor Austin Healey 1
A windshield wiper motor MG 5
R TR2/3/3A Windshield Wiper System Triumph 2
Sopwith_Camel mk2 windshield wiper nozzles Jaguar 4
BoyRacer Windshield Wiper Wheelbox Austin Healey 4
B TR2/3/3A Windshield Wiper mount rubber Triumph 3
C windshield wiper stupid question Spridgets 7
B Windshield wiper arm MG 3
Roger Elan Windshield Wiper Lotus 2
I TR6 help with TR6 windshield wiper arm removal Triumph 6
B TR2/3/3A TR3 Windshield Wiper Tubing Triumph 5
NutmegCT Windshield wiper scratch removal? Restoration & Tools 14
I Windshield wiper help please. Spridgets 1
T Windshield Wiper Mods and Upgrades Austin Healey 10
G Windshield wiper blades MG 2
A TR2/3/3A TR-3A windshield wiper assembly Triumph 2
Michael Oritt Variable Speed Windshield Wiper Austin Healey 4
Ohiobugeye Bugeye Windshield Wiper Installation OUCH !!!! Spridgets 3
C Are there spacers for the windshield wiper posts? Spridgets 3
58Custom Windshield wiper questions Spridgets 1
M Windshield Wiper Alternatives Spridgets 5
M 90 XJS Windshield Wiper Won't Shut Off Jaguar 5
T Windshield Wiper Gearbox Grease Austin Healey 2
RSMTR8 Windshield Wiper Scratch Removal? Triumph 5
X Windshield wiper problems Spridgets 3
C Windshield Wiper Upgrade - AH 3000 Austin Healey 4
K T-Series Windshield wiper path scratch removal question MG 17
P Windshield wiper drive post rubber grommets Austin Healey 1
W windshield wiper tech on 74 XJ6L Jaguar 1
D TR2/3/3A Windshield glass doesn't fit Triumph 6
P Post-War Other Herald Windshield: Is it the same as.... Triumph 2
D TR2/3/3A Windshield assembly question Triumph 6
K TR2/3/3A Removing scratches and scrapes fro the wind wings that screw to the windshield? Triumph 9
ModifiedBJ7 BJ7 Windshield Surround Rubber Seal Austin Healey 2
