Metal prep of chassis after repairs and shot blasting
red57
Hi, I will try to keep this as short as I can. I am finally ready to blast, prime, seal, and paint the chassis. It has taken me about 5 years of part time, whenever I can get to it, work. But all cancer and bent metal has been dealt with - new sills, parts of the outriggers, new shut pillars, new floors, etc. The outer body has new patch panels in doors, boot lid, wings, new nose pieces in the front shroud, and all has been rough fitted to the car and removed again.
Now I have started blasting to get ready to prime & paint the chassis (most of the chassis was blasted about 10 years ago but has some light surface rust). I have done lots of reading over the years but am still unsure about the next steps.
My original plan was to blast, blow all dust off and spray an etching primer followed by a good 2 part urethane primer. Then seal and paint - simple enough, right? My subsequent reading says I still need to 'wash' the metal to make sure dust and oils are fully removed - I had mistakenly thought blasting would leave the metal clean enough for painting. Also, some don't recommend urethane primers over etching primers....
I can't 'blast in the morning and prime in the afternoon' simply because I don't think I will all that quick blasting and the rust bloom can be nearly instantaneous. So I was thinking of using Dupont 5717s and 5718S metal prep system for the bare metal after blasting. This is a phosphoric acid etch cleaning system that requires washing the first application (5717S) off with water. Couple of difficulties - this would require rolling the rotisserie outside (I have a gravel parking lot that won't be friendly to the 4" casters on the rotisserie) since my shop does not have a sloped floor or drains. Then there is the questions of water on all that freshly blasted metal - how well can I dry it and what kind of new rust bloom problems do I have? On top of that, how many hours will it take to scrub and brush all that metal in all those nooks and crannies? If I do this it might take days to get ready to prime after blasting.
I also considered Eastwood's bare metal etch but it requires wiping down all the metal until your rag stays clean, according to a youtube I watched - again, a lot of time consuming and difficult work.
I have read so many conflicting opinions/methods that I am really not sure how best to proceed - bodywork and paint is not something I have any real training or background in, but I am in the "do it yourself, you will be glad you did" school.
I'm hoping some of you have done this as a DIY project and have any suggestions? I'm not looking for shops because I can't afford to pay someone else to work on my toys.
I must admit, I am close to full circle and back to considering just blowing all the dust off after blasting and prime it.... After all, it only needs to last me another 15-20 years or so.
Looking forward to a learning about how some of you have solved this problem.
Thanks in advance,
Dave
RestoreThemAll
I used metal wash and then two part epoxy primer. The two part urethane paint. Both arms were ready to fall off after painting all those nooks and crannies.
RestoreThemAll
Eastwood
Metal Wash cleans and protects in one quick step without using harsh or flammable solvents, and promotes topcoat adhesion on bare metal. Mix with hot water; 7 ozs. of concentrate makes 8-10 quarts of solution (or mix 5 level teaspoons with 1 quart of warm water). Apply by dipping or using a pump spray bottle. Metal wash not only removes residual grease and oil but also leaves a protective film behind that prevents rust for up to 3 weeks in dry storage. Metal wash is an excellent prep for any coating. For faster cleaning (without corrosion resistance) use PRE Painting Prep (10041Z).
No rinsing or wiping down. Blow dry with compressed air.
red57
red57
Thanks Dale, The Eastwood 'Metal Wash' is different than the Eastwood 'After Blast Metal Prep' that I had looked at earlier (
and looks like it would be a lot easier to use, not requiring washing off)
I was interested in the After Blast but the washing down with water was not appealing to me.
I am continuing to read all I can but it is a very confusing thing - responses on forums and utube are all over the place and it's hard to find any consistency in methods.
Thanks again,
Dave
Ditto, but with one exception...
Knowing__AND ADMITTING__that it was impossible to do the whole thing at once, I didn't even try. I essentially divided the chassis into six (6) parts: front, middle and rear, top and bottom.
I'd blast a section, clean with DP 330 (wax & grease remover, or "Prepsol") and then use DP 40/401 epoxy chromate primer. Depending on how much time left in the day, I'd pick off another, slightly overlapping (blasting off some fresh primer, and painting over some previously primed areas) as I'd go.
I think the area I dreaded the most was the inside cowl and footwells__the rest, even the engine compartment__was comparatively easy.
To avoid "dry overspray" start with the top panels (say the scuttle) then progress to the lower panels, like the floors/footwells, etc. Particularly important with the topcoats. You can however lightly mist some thinner (lightly tinted with color, like when you're rinsing out the gun) to blend in some areas, but don't get it "wet."
I used an acrylic enamel with a polyurethane hardener for the topcoats, and for more solvent resistance, put a clearcoat on top of that. Unfortunately, I was getting pressed for time to complete, and the clear was applied on a VERY HUMID Louisiana evening__moisture was literally suspended in the night air__so I lost a lot of gloss in the chassis. But >30 yrs later, it has held up and doesn't look any different; actually looks appropriate for the underhood finish.
Have fun, and enjoy it, because once the chassis is painted you've turned the corner, now it's time to put stuff together for keeps!
dancrim
Been doing body work and paint for 45 years. Use a product called OSPHO. Apply really light and let it cure (2-3 days).
It will now be protected from rust till you wan't to paint. Rub off the "dust" before using a 2 part primer, then paint.
Jobs I did like this 30 years ago still look good.
60Bugeye Bare Metal Protection/Prep While Doing Bodywork Restoration & Tools 6
G Don't use "Metal Ready" prep for regular paint !! Spridgets 13
mcguijo Metal Prep Work Restoration & Tools 12
K TR2/3/3A Manifold gaskets....To use sealer or not? New ones look like fiber,old ones look like metal??? Triumph 3
HighAltitudeTR3 T-Series MGTD Sheet Metal Gauge?? MG 0
AUSMHLY BJ8 Transmission just rebuilt now has metal filings Austin Healey 10
D Made a sheet metal break. Restoration & Tools 5
J Door Draught Metal Clips Austin Healey 4
B Bugeye Original Engine Compartment Sheet Metal. Act Fast! Spridgets Classified 0
F Off Topic metal forming for a friend Triumph 25
N Spridget sheet metal Spridgets Classified 0
steveg TR6 Metal Dash - does anyone make one? Triumph 13
J For Sale Triumph TR 2/3MISC sheet metal parts Triumph Classifieds 1
Busted knuckles TR2/3/3A Sheet metal question, Triumph 5
jfarris TR2/3/3A Metal washers for SU H6 float bowls Triumph 1
RAC68 Loose Metal Knocking/Banging Sound during Rough Idle Austin Healey 32
RAC68 Source - Metal Clips for securing Convertible Top and/or Seat Covers Austin Healey 11
71TR6 TR2/3/3A Moving a radius on sheet metal patch Triumph 12
S TR2/3/3A busted through to bare metal Triumph 18
F Wanted TR6 Shock Turret Sheet Metal Triumph Classifieds 1
SpeedyG TR4/4A TR4 vs. TR4A metal dash panel Triumph 5
S TR2/3/3A were the 2 metal gas lines connect Triumph 18
HighAltitudeTR3 TR2/3/3A What is non magnetic metal and gets stuck in Pressure Relief Valve? Triumph 48
S TR4/4A Metal facia trashed Triumph 3
R metal adhesives Austin Healey 12
Editor_Reid Metal [or maybe fiberglass] tonneau for Healeys Austin Healey 24
Tinkerman TR2/3/3A 1960 tr3a sheet metal fitment Triumph 6
C Recommendations on where to send my 1954 BN1 for metal work? Austin Healey 13
T TR2/3/3A TR3A Sheet Metal Piece Needed Triumph 2
I General TR Pot metal rechroming Triumph 7
T TR2/3/3A Requesting some Pictures for metal work Triumph 9
MTribe TR6 Can you identify these metal shavings in the oil? Triumph 32
T TR2/3/3A Repairing thin aluminum sheet metal like the grill. Triumph 6
Brinkerhoff MGA metal work details MG 18
certifiedcarnut Spridget master cylinder cap, metal Spridgets 8
S TR2/3/3A Odometer gears for the early pot metal speedometer Triumph 27
Scot1966 TR6 TR6 sheet metal Triumph 3
D Another question 1967 BJ8 top installation,metal retaining strip Austin Healey 1
T TR4/4A Fabricating a metal panel in between the fuel tank and cockpit Triumph 6
G Filler metal used for tig welding ah aluminum shrouds Austin Healey 2
JPSmit New fun tool review - metal tumbler Restoration & Tools 6
R Simple question about metal Spridgets 18
Hap Waldrop King Tri metal Bearing MG 10
doc50 Best Method to weld sheet metal repair panels in... Triumph 10
S TR2/3/3A tr3 metal fuel lines Triumph 1
L Bugeye door pocket metal trim Spridgets 0
G TR2/3/3A Tropical metal fan for TR3 Triumph 4
S TR2/3/3A those metal button trim pieces tr3 Triumph 5
J Metal work restoration of a TR3A Restoration & Tools 1
J TR2/3/3A 1959 TR3A metal work restoration. Triumph 9
