This morning I installed an electronic flasher for LED lighting: two front LEDs for turn signal/side head lights and two LEDs for the rear flashers. Once installed, all worked fine. The front LEDs flash amber and are white for side head. The rears flash red. I tested them by turning the ignition switch on and working the knobs/trafficator.
But when I started the motor, they didn't work fine: the dash light glowed steady, the front LEDs flashed erratically and the rear LEDs stayed on steady.
Any ideas?
Any ideas?
