TR2/3/3A LED Flasher Problem
ckeithjordan
This morning I installed an electronic flasher for LED lighting: two front LEDs for turn signal/side head lights and two LEDs for the rear flashers. Once installed, all worked fine. The front LEDs flash amber and are white for side head. The rears flash red. I tested them by turning the ignition switch on and working the knobs/trafficator.
But when I started the motor, they didn't work fine: the dash light glowed steady, the front LEDs flashed erratically and the rear LEDs stayed on steady.
Any ideas?
TR3driver
Great Pumpkin - R.I.P
Are you saying the front & rear turn signals came on even with the control in the 'off' position? Or just that they didn't flash as expected with the lever in either turn position?
If it's the latter, I'd guess your electronic flasher doesn't like all the electrical noise. Are you still positive ground? Do all new components match your ground polarity?
ckeithjordan
ckeithjordan
It's the latter symptom, Randall. I'm negative earth, having converted earlier when I put in LED stop lamps. All the components should be NE.
TR3driver
I would try either a different flasher, or adding some bypass capacitors at the flasher. Green wire connection to ground, a 10 mfd electrolytic plus a .01 mfd mica or ceramic should do it. Exact values aren't important.
As an experiment, you could try disabling the generator and then starting the engine. If the problem remains, it's most likely noise from the ignition. If not, then it's probably noise from the generator. Might be a sign of incipient generator failure, wouldn't hurt to have a look at the bushes and commutator; but most likely it's fine. They just make a lot of electrical noise. I've even been known to add a big ceramic cap at the generator output terminal, which cut way down on the noise getting into the CB radio.
ckeithjordan
ckeithjordan
Thanks again, Randall. I'll try a different flasher to verify operation, then see about adding the capacity. Why the two different types of capacitors?
I would hope the generator is OK, I just had a rebuilt one installed by Macy's, as part of my drivetrain overhaul.
TR3driver
Electrolytic capacitors (the larger value) are good at filtering low frequency noise; but not so good at filtering high frequency noise. The smaller capacitor will be much better for the high frequency stuff.
Every time the generator brushes cross a commutator segment, they cause a tiny spark. Also sparks inside the distributor cap, since the rotor doesn't quite touch the terminals. Sparks generate noise across a wide range of frequencies. It's hard to say (at least for me) just what range your flasher is sensitive to (if that's the problem at all). Hence the "shotgun" approach.
ckeithjordan
ckeithjordan
I appreciate the explanation. I tried another electronic flasher today with no change. So on to constructing the bypass capacitors. It might be awhile before I get to that, so in the meantime, I reverted back to Edison's, er Lucas' creations. I'll let you know the results when I do add the capacitors.
TR3driver
Another solution is to add load resistors, so the stock flasher will work with LEDs. That's the direction I went.
ckeithjordan
ckeithjordan
What resistors did you use and how are they wired in?
TR3driver
My setup is actually somewhat more complicated; since I also have 3 relays involved. Early cars like mine only had one brake light in the center, the rear corner lamps were originally only for tail and turn. Adding the relays allowed me to keep the center brake light, but also make the corner lamps do triple duty as brake/turn/tail, while still only having dual filament bulbs (or the LED equivalent of same).
Anyway, something like these should do fine for what you need
https://www.amazon.com/Resistors-Signal-License-Warning-Cancellor-x/dp/B004EDF8HY
One side of each resistor goes to the turn signal wire for left or right (GR and GW), the other side goes to ground.
You can pick out a mounting location; mine (and the relays) are mounted to a simple steel bracket which in turn is bolted to the back of the pedal box, under the dash. (Out of sight, plus no new holes.) The resistors do get warm in normal operation (while the turn signals are running), but not really hot. If you don't mind them being visible, on the inner fender near the LH horn (and near where the wires from the control head join the main harness) might be a good spot. On a LHD car, both GR and GW go through a 4-way bullet sleeve with only 3 of the openings used originally, so you can add a bullet to the resistor wires and connect them into the 4th opening.
ckeithjordan
ckeithjordan
Thanks again. I may give that a try.
ckeithjordan
ckeithjordan
I was able to "fix" my problem. I went the route of adding resistors, the ones suggested by Randall. I used one resistor for each location, a total of four. I painted them with a red (to match the body work) high-heat enamel and epoxied small neodymium magnets to hold them. I replaced the wiring off each with the correct color-coded wire (GW, GR and black) and plugged them in. Using my stock flasher, they worked like a charm. While the electronic flasher was fun to do (disguising it in the original body), I would have had to capacitors to overcome the electrical noise. Adding resistors seemed like a better solution, plus they're more easily hidden.
Jim_Stevens
Brilliant solutions: the color-coded wiring, the magnets, and using the extra bullet hole to connect in! Thanks —
S TR2/3/3A LED turn signal -- panel flasher not working Triumph 5
Lukens TR2/3/3A Led flasher relay? Triumph 3
Gliderman8 TR6 Correct LED flasher relay Triumph 6
D TR4/4A Elec Flasher/LED bulbs revisited Triumph 14
bighealeysource LED bulbs and electronic flasher module issues Austin Healey 26
PAUL161 T-Series MGT 7 inch LED Headlights MG 4
B Positive-Ground LED Light Strip Austin Healey 8
K TR2/3/3A Switching to green LED dash panel bulbs? Triumph 3
Gatheringtree TR2/3/3A LED headlamp and tail light conversion. Triumph 4
RJS General TR Warm White H4 LED Headlight Bulbs Triumph 1
Rob Glasgow LED Dash Light Upgrade Austin Healey 28
J LED lights for PL 700 Restoration & Tools 12
Guido36 LED Headlight Upgrade Austin Healey 1
bighealeysource LED Instrument Lights Austin Healey 12
linuxcoupe General MG Lamp to LED Conversion - How many ballasts to use MG 5
johnrip Wedge TR7 LED Tail lights from Wedge Shop Triumph 1
BoyRacer LED Turn Signals Austin Healey 5
P LED Brake Lights Austin Healey 2
EWD TR6 LED instrument conversion / Dimmer. Triumph 25
B TR6 LED Headlights Thouights? Triumph 14
T Decreasing Intensity of LED Lighting Austin Healey 3
V LED light bulbs : One thing leads to another Spridgets 7
V LED light bulbs : One thing leads to another Austin Healey 2
Michael Oritt LED bulb/resistor wiring question Austin Healey 24
johnrip Wedge TR7 led light conversion question Triumph 1
AUSMHLY E10 Light bulb, 2.2w vs 5w vs warm white LED Austin Healey 4
AUSMHLY Led headlight conversion kit with Lucas headlight bucket Austin Healey 37
R TR2/3/3A Positive-ground LED lights Triumph 13
Martinld123 Just installed LED headlights in BN2 Austin Healey 15
Bob_Spidell LED Headlamps Austin Healey 14
N Charging warning light LED conversion Austin Healey 29
S LED or Quartz-Iodine headlights for my '67 AH 3000 Austin Healey 22
J LED Brake / Turn Signal Austin Healey 4
Martinld123 Problem Using LED lights with Existing Brake Lamps Austin Healey 20
Joe Schlosser LED Turn signals Austin Healey 9
Joe Schlosser LED flashers Spridgets 2
Gliderman8 General TR Let there be [LED] light! Triumph 18
D LED shop lights Restoration & Tools 10
GTP1960 TR2/3/3A LED headlight question Triumph 11
gbtr6 TR6 LED light bulbs questions Triumph 20
Rob Glasgow E10 Base LED Dash Bulbs Austin Healey 17
Marla TR4/4A Led dash lights Triumph 0
jfarris TR2/3/3A Moss LED Tailight Kit Triumph 4
P LED Dash Lights Spridgets 1
K TR2/3/3A LED dash bulbs again? Triumph 2
gbtr6 TR6 LED Dash Lights Triumph 8
PAUL161 General MG LED Dash and Instrument Bulbs POS or NEG ground. MG 8
D TR2/3/3A TR3 LED Lights? Triumph 5
G BJ8 Phase II conversion to LED turn signals Austin Healey 11
S LED Exterior Light Upgrade Spridgets 15
