MGB AGM M/C battery
MGBGM1977
I got tired of the battery and the mess in the trunk of my 1974 MGB. Kind of a pain behind the seat too. I decided to give this AGM battery out of my 1984 Goldwing motorcycle a try. 350cca 21ah battery, it starts very well. So far I am very pleased with the results. I glued a rubber pad behind and underneath the battery and secure it with a heavy duty rubber tarp strap.It doesn't move. Plenty of room and easy to get to. Only time will tell if it will last. YTX24HL-BS-BatteryMart_side_1000x1000.jpgAGM motorcycle battery.jpg
Mickey Richaud
I'll be interested to hear how it fares over the long haul. Don't imagine that it weighs much, either.
MGBGM1977
MGBGM1977
18 pounds. I understand a lot of people use Miata batteries. This one is close to the same specs. The old Goldwing is a four cylinder 1200cc boxer engine. This battery spins my MG engine over as fast as a larger battery and my car starts quick. I don't feel like it's loading the battery very hard. As I said though, only time will tell. I have had a lot better luck with the AGM battery as opposed to a flooded acid battery lasting much longer in the bike.
Mickey Richaud
Thanks - oh, and welcome to the BCF!
:cheers:
Mickey
Platinum
I'll be interested to learn how well that works out, too. I have scant space in the same location as yours is placed (air horns and compressor, extra relays installed) but it should fit in the original position.
And as Mickey stated: Welcome to th' fray.
Be you Air Force? The F-15 avatar has me curious.
PAUL161
I use the Optima battery, no acid there either. PJ
drooartz
Welcome! I have the Miata battery in my B, it's worked great for years. Definitely interested in how this one works for you.
LarryK
I used the Optima battery in my 03 Cooper S, seemed like a good choice for track time. Only lasted 5 yrs. Went back to get new, and found the stock battery weighed less and I could get 7 yrs out of it. Car is 16, run hard and battery still as new. Might try the AGM next.
MGBGM1977
MGBGM1977
Used to be Air Force many years ago. F-15 Weapons Puke. 33rd TFW at Eglin AFB.
Here are the specs on this battery. The old Goldwing is down for now and I needed a battery for the MG. I thought "Why not try it".specs.jpg
Platinum
:thumbsup: A few years before you: 1365th, 1361st & 601st Photo... "Aerial Combat Documentation Photographer." a.k.a. "Still Photo Weenie." :smirk:
Platinum
Nice shot! Never got an F-15 hop, they were still in blue & orange wingtips. A few F-4 rides with 8th TFW though. One was memorable... :scared:
MGBGM1977
MGBGM1977
The 33rd TFW had F-4s up to 1978, then transitioned to F-15s. I got there in Dec. 1979. They now are training wing for F-35s. My Air Force time was short, but some of the best days of my life. Spent the next 30 years in Public Works for a small city just outside the gate of Eglin AFB. Love them jets!
Back to MGs, the Lucas alternator in my '74 was putting out 16 volts and made quite a mess of the wet lead acid battery that was in the trunk when I got the car. I am cleaning up that mess now after my battery change and a new Delco alternator. Lots of things to do to it yet, but just trying to put it on the road for this summer. It is in good condition other than a lot of interior work and a good paint job down the road. Helping to keep this old retired guy off the streets and out of trouble-haha
Platinum
Looks good. "SnugTop" hardtop... nice.
I recently converted our B to an alternator, did the negative ground change-over back in '05~'06 during the rebuild. Added a period correct voltmeter and clock from Nisonger on a bespoke center console.
Incidentally, I'm right under the turn for final approach down here at MacDill AFB. Lots of KC-135's, some C-17's occasionally. Also infrequent visits by some "odd" single-seaters: F-5 two-flight last month, assuming some foreign AF doing refueling practice.
MGBGM1977
MGBGM1977
I got to fly in a KC-135 once during a fueling mission. Lay down next to the boom operator and watched F-15s and A-10s refuel. Loved that opportunity. F-5s are pretty cool jets. I knew Col. Frank Emory that commanded the Scoshi Tigers F-5 squadron in Vietnam testing the F-5s capabilities. After he retired, he lived in the city where I worked outside the Eglin gate. He sure had a lot of stories to tell.18-2.jpgFrank Emory f5.jpg
mgedit TR2/3/3A AGM Battery for TR3 Triumph 12
Scott_Hower AGM [Optima-type] battery in chrome bumper B MG 27
K TR2/3/3A Old school battery shut off switch....... Triumph 3
tahoe healey Battery Chargers vs. Maintainers Austin Healey 25
Bayless What size battery for my '67 Sprite? Spridgets 5
Sopwith_Camel battery drain Jaguar 35
Popeye General TR Battery Tray - yes or no? Triumph 11
Gatheringtree TR2/3/3A Changing out the battery liner Triumph 11
B MGB 1977 MGB Battery Box and Shifter knob MG 4
B T-Series Battery replacement mgtd MG 2
M TR2/3/3A Generator Warning Light on with the Alternator Charging the Battery Triumph 4
tahoe healey Battery Lifespan Austin Healey 8
EWD TR6 Battery charge loss Triumph 25
NutmegCT Upgrade your battery? Electric Upgrades of All Sizes 8
D Battery Minders Austin Healey 3
R MGB BATTERY DRAIN MG 7
D TR2/3/3A Battery Box drain Triumph 9
T TR2/3/3A Should there be a body ground strap to battery on TR3 Triumph 7
steveg Battery Cable Specs Austin Healey 33
Jim_Stevens TR2/3/3A Arcing & Sparking at the battery terminal to ground Triumph 7
GeorgeC Painting the Battery Austin Healey 0
GeorgeC OK to paint battery? Spridgets 9
D Battery connections Spridgets 0
A Wedge Won't fire without jumper from coil to battery Triumph 6
69MGC MGC Putting a 12v battery in the trunk MG 10
T How do you cover your battery in the boot? Austin Healey 5
S TR2/3/3A Need New Battery for TR3A Triumph 9
Busted knuckles TR2/3/3A Lead sled, spiral shank nails and dead battery box’s. Triumph 13
Y MGB Battery relocation ponderings and considerations [and ideas?].... MG 6
D New Battery Needed for BJ8 Austin Healey 9
HealeyRick Vented Battery Austin Healey 6
sparkydave 1500 battery cable colors Spridgets 1
G BN6 Battery location Austin Healey 7
L TR2/3/3A helmet style battery terminals Triumph 7
TRMark TR4/4A Miata Battery Triumph 6
RAC68 Battery Fuse Protection Austin Healey 101
RAC68 How does a 12 Volt Alternator charge a battery to read 18+ Volts Austin Healey 8
wangdango BJ8 inner battery hold down? Austin Healey 4
JimTR4 TR4/4A Battery recommendation Triumph 11
3798j Fastronix Battery Compression Ends Restoration & Tools 4
M battery helmet stuck on post help Austin Healey 8
69MGC MGC WANTED: Passenger side Battery Box Bracket MG 0
NutmegCT Whacko battery[s] Restoration & Tools 7
NutmegCT battery post connectors Restoration & Tools 6
2billydavies TR2/3/3A dead battery, generator, belt Triumph 13
NutmegCT Solar battery maintainer? Restoration & Tools 9
S TR2/3/3A Replacement Battery Triumph 5
HighAltitudeTR3 TR2/3/3A Battery/Control Box/Voltage Regulator Triumph 20
S Battery - BJ8 Austin Healey 8
D Battery Tray Size Austin Healey 1
