TR2/3/3A Oil drain plug stuck
joshsibille
I've been breaking down my engine ('61 TR3A)to pull it, but for the life of me, I can't get the oil drain plug out. I've soaked it with PB blaster, tried a breaker bar, even to some extent an impact wrench with a universal joint(only way I could get it to reach). Anybody have any thoughts as to how to to get the d*** thing out? Would like to drain the engine before pulling it, but its looking like it may have to come out full of oil then get taken out when its in the open. Any thoughts would be greatly appreciated.
STeve 1958
My first impulse was to say " Righty righty, lefty loose " but that would be cruel.
You might try heat. use a 1200 degree heat gun, not a torch. Then a breaker bar.
Someone must have thought they could stop an oil leak if they got it tight enough.
NutmegCT
I had a similar experience on an old Jaguar saloon. My dad taught me something a zillion years ago: put a wrench on the bolt head, but lightly tap the wrench with a hammer *the direction you'd normally tighten it."
That light "backwards" tapping usually breaks the bolt out of the rust or whatever is holding it, so you can then turn it normally to loosen it.
Not always - but worked for me many many times on various cars.
Tom M.
TomMull
Put a breaker bar with a 3 foot pipe "cheater" on it. If that doesn't do it, increase the length of the cheater. Oh, and you can tap it too.
Tom
TR3driver
Great Pumpkin - R.I.P
This puzzles me; I've never had any trouble at all twisting off those dang pipe plugs without using a cheater bar at all. Seems like they're made of stale cheese that has gone soft again (no doubt from exposure to hot oil).
IMO, if an 8 point socket and breaker bar doesn't get it, it's time to start drilling for oil.
Some teflon pipe dope on the replacement will help ensure it doesn't happen again.
Tom
sp53
The bolt is probably shot by now and I am wondering if it a square plug or a bolt someone put in its place. I actually think the treads in the pan are angle pipe treads. Sometimes a good bite with vise grips and a 4 to 6 pound hammer to bump it with lets the mass of the big hammer do the work, but again vise grips can backfire and take all the sides off. I have had to weld a nut on what was left of plug before and the heat from the welder and a new clean nut it made it so popped right off.
Welding the nut was a lot easier than I thought it would be and I had wished I had done it sooner.
CJD
In the short term: "Give me a lever long enough and a fulcrum on which to place it, and I shall move the world." (Archemedes 250BC).
In the Long term: Don't let anyone else touch your ride!
TR3driver
The later pans were pipe threads, the factory used common square head pipe plugs. (Which I like to replace with hex socket plugs.)
Tr2 and early TR3 took a different, hex head plug with straight threads. I don't recall the thread offhand, but I believe it was SAE. There should be a fiber sealing washer, too.
The pans are interchangeable, of course, so its never quite certain what you will find on any given car. But the pipe threads are much more common, just because they made so many (same pan for TR4 and 4A as well).
titanic
Amended version: "Give me a lever long enough and a fulcrum on which to place it, and I shall break anything and/or maim myself." (Berry 2019 AD)
Berry
S TR2/3/3A Removing a stuck oil drain plug Triumph 13
B TR4/4A Oil Drain plug size Triumph 14
af3683 TR2/3/3A TR3B Oil Drain Plug Triumph 10
Marla TR4/4A Oil Drain Plug Triumph 4
KVH Leak at Oil Drain Plug Triumph 12
CinneaghTR Thread Pitch for TRactor Oil Drain Plug Triumph 8
L What size and thread pitch oil drain plug? Spridgets 5
H TR2/3/3A TR3A Oil sump drain plug [Thread zize] Triumph 2
Stewart Leaky transmission oil drain plug MG 3
RandallRK Differential oil drain plug Austin Healey 13
H Where is the Overdrive Oil Drain Plug and Filter? Austin Healey 2
RSMTR8 Wedge TR8 Oil Drain Plug Triumph 1
78MGB Oil Drain Plug Washer *DELETED* *DELETED* MG 3
Erica General MG Oil Drain Valve -- mine is an MGB, but they have others MG 3
T Spin-On Oil Filters Anti-Drain Back Valves Austin Healey 0
T TR4/4A Oil drain hole from rear crank seal/rear main cap Triumph 3
J Toyota tranny conversion question, oil drain hole Austin Healey 1
tahoe healey trans oil drain Austin Healey 11
kindofblue Which Tool for the Oil Drain Bolt? Triumph 9
tahoe healey oil drain plugs Austin Healey 11
R For Sale 1960 Healey BN7 Oil Pan For Sale Austin Healey Classifieds 0
Carlbanan56 MGB MGB oil consumption MG 5
1955TR2 TR2/3/3A TR2/3 Oil Leak Where Oil Sending Pipe Connects to the Block Triumph 8
Jim_Gruber Correct Transmission Oil for Datsun 210 5-speed Spridgets 1
af3683 TR2/3/3A Recommended Oil Filter Cartridge for Purolator Triumph 8
R oil pressure Spridgets 2
RickPA Overdrive Oil Pressure Austin Healey 8
6 Valve Oil Seals Spridgets 10
RJS TR4/4A Smiths Oil Temp Gauge Triumph 11
J MGB Oil Pressure Gauge Gives Constant Reading -- Doesn't Seem Right MG 15
Lotuswins Dry Spin-On Oil Filter Austin Healey 14
Todd78d Oil Spridgets 6
G Right-Side Shock Weeping Oil Austin Healey 1
scottkilpatrick TR4/4A Gear oil and choke question Triumph 4
D TR2/3/3A cylinder head oil plug bolt size Triumph 6
G High Oil Pressure Austin Healey 2
T Spin-On Oil Filters for Cars with a Brake Servo Austin Healey 3
Bayless What oil for Datsun 5 speed? Spridgets 7
T Spin-On Oil Filters Austin Healey 1
K TR2/3/3A Old school penetrating oil? Triumph 24
R TR6 question re: Engine Oil Triumph 3
nevets Spin-On Oil Filter Adaptor Austin Healey 12
D Overdrive Stops Working After Oil Change Austin Healey 26
Celtic 77 General MG Lever shock oil refiller MG 0
I MGB Sprung an (oil) Leak! MG 2
sim oil pressure gage bad or engine needs rebuild It starts our cold at 60 psi but when warm it down to 10 psi Spridgets 21
S TR2/3/3A Aluminum oil gallery plugs Triumph 9
WHT Oil Sump Question For Dougie Austin Healey 0
Joel Lester TR2/3/3A Priming new engine with oil Triumph 9
