I am upgrading my front suspension to a tr4a front suspension. I ordered new lower trunnion bolts from TRF. My order arrived today and to my surprise I got to the trunnion bolts and checked the head of the bolt only to find that it is a metric bolt. I will give them credit they sourced a high quality bolt but first off, My car does not have metric bolts on it. Second the bolt is almost 1/8 ' short and is .003 undersize. Yes the bolt will work but for approximately $ 10.00 each I would expect the bolt to be right. My question, am I being too picky (Anal, yes I am when it comes to tolerances especially when it involves suspension) should I move on and pick another battle . If I do or don't send it back I will probably get with my bolt supplier and source the correct bolt. I can drill a hole for the cotter pin for a lot less than what these bolts cost. I thought the bolts were a special size or grade, not the case. This is not to bash TRF, I will be getting most of the new parts from them but this time a little disappointed . Frank
