SU carbs AUD9124 on a Jaguar ?
spinaway
I have a Healey 100-4 with two SU H6 1 3/4inch carbs fitted.
The carbs have C6 stamped on the mounting flange, and the number AUD9124 hand etched on the side of the carb bodies.
The guy that fitted them to the car back in the 1960s said he thought he got them off a wrecked Jaguar !
I am interested to know what model of Jag they might have come, if the story is true.
Does anyone know ??
Thanks
Extra Info: Originally when I got the car, these carbs had a small copper pipe going from a small hole underneath next to the butterfly, then going up to a Tee piece on top of the float bowl. I think the idea of them was as an enrichening device feeding a bit of vacuum to the top of the float bowl to change fuel level ! Did any Jags use such a device ?
Des // New Zealand
LarryK
I have H6 1 3/4s on my 3.4 MK1.
OWD724
The H6 was the standard carb on the Healey 100 when fitted with the Le Mans kit or the same M version.
The H6 was also standard on the XK 120, 140 & 150.
so, it is possible your car always had the H6’s. My Healey 100 had them from new in 54 as fitted by factory Le Mans kit.
L For Sale original Bugeye SU H1-1 1/8 Carbs Spridgets Classified 0
Zitch For Sale HD8 carbs and 2" intake Austin Healey Classifieds 9
jfarris For Sale SU H6 Carbs AUC 878 - SOLD Triumph Classifieds 0
Simmo TR6 Weber Carbs and Redline Air Cleaners Triumph 1
K TR2/3/3A Copper pipe from pump to carbs Triumph 9
I Wanted BN1 with H6 carbs : bodies of TR3 Austin Healey Classifieds 1
K TR2/3/3A Fuel line routing from pump to carbs Triumph 7
poolboy For Sale REBUILT Carbs for TR6 Triumph Classifieds 0
M TR2/3/3A 1960 TR3A--intake manifold-to-SUH6 carbs studs Triumph 3
steveg Healeys with Mikuni Carbs Austin Healey 13
P TR2/3/3A TR3B SU carbs Triumph 10
KVH General Tech Carbs Flooding While Car Sits Triumph 55
K 1966 Austin 1100 carbs? British Motor Corp 1
Basil Spitfire How do I adjust SU carbs on my Spitfire? Triumph 5
steveg HS vs HD series carbs Austin Healey 2
P For Sale v12 carbs Jaguar Classifieds 0
T TR6 My '74 TR6 Zenith Stromberg Carbs Float Bowls Leaking Gas Triumph 11
steveg TR6 HD6 carbs on TR6? Triumph 16
J For Sale Two used WEBER DGV 32/36 carbs for Triumph TR 2,3,4 Triumph Classifieds 0
K For Sale Two Rebuilt TR3 AUC 878 SU Carbs Triumph Classifieds 3
Michael Oritt Initial mixture setting for H6 carbs Austin Healey 3
Michael Oritt Leak from carbs Austin Healey 13
M BN1 with H6 carbs : what setting ? Austin Healey 56
D Starting After Carbs Rebuilt Austin Healey 30
T TR6 Carb Vacuum Port- TR6 Zenith-Stromberg Carbs Triumph 4
69MGC MGB Wanted: Pair of 67 or earlier Carbs MG 2
69MGC 65 to 67 carbs wanted MG Classifieds 4
K 66 Austin 1100 Carbs British Motor Corp 1
Carlos TR4/4A GROSE-JET or Viton-tip for SU HS6 carbs? Triumph 15
M Cooper's Air Filter on H1 Carbs Spridgets 5
S TR2/3/3A problem just rebuilt SU carbs Triumph 28
sundown TR6 carbs Triumph 2
doc50 Su carbs for a Metropolitan? Other British Cars 1
R TR2/3/3A Stromberg vs. SU carbs [discussion/advice] Triumph 17
D BJ8 Carbs Overflowing Austin Healey 20
T TR2/3/3A Will 5W/20 oil work ok in carbs Triumph 4
R TR2/3/3A Rebuilding H4 carbs Triumph 8
Martinld123 SU carbs lose fuel prime when not running Austin Healey 3
steveg Excellent source for info on and rebushing of SU carbs Restoration & Tools 0
Jim_Gruber Screws for HS-2 carbs Spridgets 5
Talon TR2/3/3A Float lever issue on SU type H carbs Triumph 1
D TR2/3/3A Fuel line run from pump to carbs Triumph 5
edkap2002 TR6 Topping up cd175 Carbs Triumph 8
doc50 Wanted H2 SU carbs / manifold for 1275 1973 MG MIdget Spridgets Classified 3
HighAltitudeTR3 TR2/3/3A SU H6 Carbs all out of whack!! Triumph 14
J Backfire through carbs Austin Healey 3
wangdango Colortune for HD8 Carbs? Austin Healey 55
DrEntropy For Sale MGA carbs: AUC 784 MG Classifieds 0
E TR4/4A Vacuum connection on SU-H6 carbs Triumph 4
C Ruddspeed carbs Austin Healey 28
