MGA MGA turn signals
dwnuk
Need help on getting front turn signals to work on my 1957 MGA. Ran over metal debris on the road and it cut the wires for my right front wiring. Connect the obvious cut wires but turn signals do not work. Only have two wires competing out of parking/turn signal, how do I connect the ground. Also cannot find the ground on the right front side. I feel the ground is the problem but any other advice is appreciated. Thank you
Platinum
Ground should be established through the chassis. No "ground wire" per se. To determine if the bulb holder isn't getting good connection, run another wire from a solid point on the chassis to the bulb holder shell and see if the lights come on.
dwnuk
Two wires coming from the turn signal on right hand side. When I turn the lights on one wire is hot the other wire no power. I disconnected the no power wire to test and it did not effect the light being on. When I switched the turn signal on my test light connected to the non power wire blinked like a turn signal. When I reconnected the wires no turn signal light blinked but the test light still blinked. Since the left turn signal also does not work I don’t think it’s the bulbs. Also can’t find the ground doesn’t seem to be on the right side. Difficult to get at because of the radiator etc. any suggestions greatly appreciated.
barneymg
MGA front corner lamps should have three wires (including Black ground wire), but some replacement lamps in recent years only have two wires. Moss recently changed theirs to three wires.
With no ground wire, the fixture has to find ground through the mounting screws to the fender, kind of iffy once the rust bug sets in.
The front lens comes off with a push and twist anti-clockwise. Connect a jumper wire from the lamp shell to ground on the bumper to see if it lights up. Parking light power is red wire. Turn signal power is the striped wire. Check continuity from harness to lamp internal contacts (and the bulb of course).
martx-5 T-Series MGA Turn Signal Switch MG 2
ronzet MGA Troubleshooting the turn interuptor circuit.. MGA MG 29
Editor_Reid General MG GT-49, national annual meeting of the North American MGA Register MG 0
C For Sale MGA MG Classifieds 0
Editor_Reid MGA Seeking Items for MGA 1600 Mark II Tool Kit MG 0
TomMull MGA Rumble seat MGA MG 3
P For Sale MGA factory hardtop for sale. MG Classifieds 0
PAUL161 T-Series MGA pressure plate verses MGTF pressure plate? MG 6
T MGA MGA MG 6
J Wanted MGA Coupe rear window glass center section MG Classifieds 0
M MGA MGA Engine Rattle MG 10
DocDup1 MGA Wire Wheel Hubs For MGA MG 6
T Wanted Wanted : MGA rear deck cover MG Classifieds 0
M MGA RHD MGA dash finisher MG 0
BritFullHouse For Sale 56 MGA engine parts for free!! MG Classifieds 2
R MGA MGA Headrest fairing for R/H side MG 0
D MGA with T9 gearbox on a tow dolly MG 9
C MGA MGA Thoughts MG 20
C For Sale MGA wiring harness MG Classifieds 3
S For Sale MGA Factory Workshop Manuals on CD/ROM - All Models 1955 - 1962 MG Classifieds 0
Rut MGA MGA in Tuscaloosa, AL MG 3
P mga mint decklid 55to 63 MG Classifieds 1
K MGA 1960 MGA Vin MG 3
B MGA Mystery MGA chassis part MG 3
B For Sale MGA JAeger Fuel Gauge, Dual Safety Gauge, Speedometer and Tachometer MG Classifieds 0
HealeyRick MGA Interesting MGA Fastback MG 9
H MGA MGA engine weight? MG 3
doc50 MGA Decipher MGA engine Code MG 4
doc50 Nash Metro w/MGA 1500 discrepancy... Other British Cars 2
Alfred E. Neuman Red MGA MkII Spotted 1
JPSmit MGA - on a journey Spotted 9
A MGA MGA valance fastener MG 2
3798j MGA Coupe Spotted 1
glemon MGA MGA extravaganza MG 4
AngliaGT MGA Coupe Spotted 1
DrEntropy For Sale MGA carbs: AUC 784 MG Classifieds 0
DrEntropy For Sale MGA intake manifold [1500] MG Classifieds 0
oxford Healey vs MGA Austin Healey 31
busybrit For Sale 1960 MGA 1500 Restoration Project for sale. MG Classifieds 2
NutmegCT MGA MGA front grilles MG 4
NutmegCT MGA MGA opinions? MG 23
AngliaGT MGA Anyone Looking for an MGA Project? MG 8
Alfred E. Neuman MGA Question for the MGA coupe owners - will I fit? MG 8
S MGA 1956 MGA negative ground, True Spark Ignition distributor MG 3
S MGA 56 - early mga 1500drum brake car MG 5
S MGA MGA Wiring diagram MG 1
R MGA Experience buying an MGA from a US Vendor - Vendor Review forum? MG 8
RickB MGA Looks like a nice MGA grille, $50 on Seattle Craigslist MG 1
S MGA mga top and side curtains MG 4
M MGA MGA Swivel Pin Replacement MG 7
